Question about Poulan 14" Chainsaw
Remove gas tank poulan 25 - Poulan 14" Chainsaw
Have the same question on a 2450 poulan, my gas line rotted and need to somehow replace it.
Posted on Feb 10, 2013
PDoes the gas cap on a Poulan 25 CVA countervibe keep the engine from cranking
if the cap is a vented cap then yes it can. to check this start machine and when it starts to fail release the pressure by loosening your fuel cap. if this helps it run better then replace cap. if this doesn't help then check if you have a tank vent that is plugged. a tank vent usually looks like a button with five or six holes in the top and it will be on the fuel tank
Oct 01, 2014 | Garden
What is fuel mixture on a 25cc craftsman weedwacker
I always mix it 40:1 so that the piston will always be lubricated and after I finish cutting I empty the gas tank and then restart machine so as to keep the fuel filter clean.
David
Sep 21, 2014 | Poulan Pro BVM200VS 25 cc Gas Powered...
Fuel lines poulan bvm200vs gas blower
You need to split the entire unit to get to the fuel tank. Remove carb, remove exhaust, and remove right side of plastic enclosure. Check the cylinder to make sure it is tight, these units are notorious for the cylinder coming loose. Remove the tank and install your new fuel lines, leave them long then trim to fit once reassembled. Check to be sure the isolator mounts and starter rope ferrule are in place when reassembling
Jul 17, 2012 | Poulan Pro Gas BlowerVacuum ()
Lost my manual for my Poulan wild thing 2375 chainsaw and I want to fill it up with oil and fuel.
Fill the oil tank at the front of the saw with a non fling chain oil, or as thick an oil as you can get, fill the fuel tank with a 25-1 fuel oil mix, use a good, well known brand of two stroke oil designed to be used in chainsaws.
Jul 15, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Pressing the primer bulb on my Poulan 450 does not inject gasoline into the carburetor; I have removed the air filter to see, because the bulb felt "softer" than it should, and no gas was injected while...
Yes, most likely the diaphragm needs replacing. Remover the air filter. Remove the bolt holding the front (sparkplug end) of the tank to the bracket. Next remove the long bolt to the left side of the carb. Carefully remove the governor linkage from the carb. Take pictures if necessary. With the car/tank assembly on the bench, remove the 5 phillips headed screws from the base of the carb. The carb should now lift off the tank. CLEAN EVERYTHING. Be careful not to lose the small spring and screen from the bottom of the carb. Replace the diaphragm set. Not that the rubber piece goes down on the tank first, then the paper piece, then the carb. Install and tighten the 5 screws. Hook up the gov linkage and reinstall the tank. If you put gas in while on the bench, you can pre-test the primer. Just be careful where you are apraying the fuel.
Aug 20, 2010 | Poulan "Poulan" Push Mower
How do you fix a broken gas line to gas tank that was previously glued but does not hold and leaks gas to a Poulan GE21 weedeater?
Buy a new gas tank! Are you serious! Or buy a new weed eater, if you can't live without this one, those models are cheap, don't waste your time.
Apr 08, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
I need to replace all of the gas lines. Do I have
There is no reason to disassemble your saw, Please stop.
You can find a typical fuel system and a couple of suggestions here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
An IPL for a Poulan “PP3816 Gas Saw Type 2” can be found here - There are slightly different models. Please ensure this applies to your saw:
http://www.ordertree.com/modelinfo/PWE/PP3816-Gas-Saw-Type-2/75.PP3816-Gas-Saw-Type-2.1.59.1.html
The small hose goes between the filter and carburetor and from the IPL the carburetor and primer.
The large hose between the primer and fuel tank (return).
If the above is not the correct model it can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Hose can be purchased at any chainsaw outlet, Inquire about how much hose they recommend. I have not found a good hose stretcher and I have been looking. Good luck with your project. Any additional questions you may have can be asked below. I hope you found this most helpful.
Lou
Jan 31, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan 14" Chainsaw Logo
60 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
