Question about Nautilus Nb 3000 Upright Exercise Bike
I have a Nautilus 3000, its a 2000 year modle, and it sat outside for a long time now it wont light up when you ride it. What is the first thing you check for?
Price
a good tractor will cost between 5000 to 8000 these modles come with heavy duty decks that wont rust out in a couple of years
Sep 26, 2014 | John Deere Garden
How do I remove the cover to replace the light bulbs on a Round Nautilus brand bathroom exhaust fan from the 1980's.
Most exhaust fan covers use a spring steel wire in a V shaped configuration. The bottom of the V is attached to the cover. There is a slot in the fan housing and by pinching the tops of the V togetherand insert them in the slots the spring pressure pulls the cover up tight to the ceiling.Carefully pulling the cover down enough to reach over the cover and pinch thewires together should allow the cover to be removed. Hope this helps.
. Bob
Aug 09, 2014 | Broan nutone Broan/nautilus Bathroom...
1995 chvy lumina wont come out of park
This year and model has a park lock out device, it is tied into the brake light circuis the 1st thing to do is verify the brake lights work.
Apr 03, 2012 | Chevrolet Lumina APV Cars & Trucks
I changed my 1950 ford over to 12 volt and it sat for over 1 year now it wont start so I changed the solinoid ,and ignition switch ,battery,battery terminals and it still wont start and no lights
hey
Recheck the battery connections for crud.Clean battery post/cables and where cables connect to the frame and starter solenoid as sometimes the tractor power feed is at the solenoid.
Good Luck
O if you have a meter or 12volt trouble lamp you can measure across the connection for a voltage drop. With the lights in the on position.
Jan 27, 2011 | Ford Tractor 8n Front Emblem
1998 cutlass....... Theft System light blinking and car suddenly wont start
I have this same problem. It has been happening for about 3 years now. More so when it is cold but it really doesn't matter. The theft system light flashes and you have to wait 10 mins for it to reset and hope that it starts that time. I have sat for 3 1/2 hours before waiting every 10 mins to try again. I have no idea what is wrong with the stupid thing =(
Sep 28, 2010 | 1998 Oldsmobile Cutlass
2007 Craftsman riding mower 16.5 HP 1000LT model. It sat up for 2 years, Everything is working good, except now the reverse isn't working. any suggestions what to check for or how to solve this?
try putting mower in neutral and push backward and rock a few times,, then start it and put in reverse,,if it wont move have some one to push you, good luck ,, hope this help you,, trying to help you, this is not my strong point....
Aug 26, 2009 | Garden
Hazard signal
Make sure the hazard light is off because this will over ride the directionals. If you call the dealer the would tell you where it is on the modle.
Aug 02, 2009 | 2000 Dodge Durango
I need to find a repair manual for a craftsman riding lawn mower
SearsPartsDirect.com should have your answers
Apr 26, 2009 | Garden
Wont run
The problem may be with the distributor try to find a cheap used one at a junk yard, the same thing happened to my dads 1990 ramcharger
Feb 09, 2009 | 1985 Dodge Ramcharger
Pulsar Mens Wrist Watch
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
Jan 30, 2007 | Pulsar PXF216 Wrist Watch
Nautilus Nb 3000 Upright Exercise Bike Logo
29 people viewed this question
Top Nautilus Cycling Experts
John Egan
John Egan
Are you a Nautilus Cycling Expert? Answer questions, earn points and help others
