Phillips dvp3345 connecting to LG42LV4400 + can't get VCR audio to play
I finally got the video portion of the VHS tape to play, by moving the green/red/blue wires to the 'component' column from the DVD column, but no audio on the VHS/ fine audio on DVDs
  • 3,904 Answers
I tried looking up the image of your recorder online to help you out but I cannot find a clear image. If you can get me clear pictures of the unit I will help you out.
Posted on Jan 28, 2013
  • 3 Answers
SOURCE: Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Posted on Jun 05, 2007
  • 135 Answers
SOURCE: When I dub a vhs tape to DVD-R I'm getting a consistent
The 'BOUGHT VHS TAPES" have a copy guard on them- your home made ones do not
Posted on Jun 23, 2008
welcomejee
  • 10594 Answers
SOURCE: VCR will not play a VHS, just immediately ejects the tape
Please clean its Guides Loading Path and check Loading Belt, if foud lose, replace it,
Posted on Aug 02, 2008
VOTIT
  • 2071 Answers
SOURCE: JVC HR S8000U S-VHS VCR switch from stereo to mono during playing.
it is a tape head problem it is already near to run out,replace it with a new one,so it will back to normal..
hope this may help;
Posted on Aug 05, 2008
simplemitch
  • 752 Answers
SOURCE: External Tuner Device for VCR/DVD player
Just pick up an old used VCR that has a tuner built in. Only the very new ones don't have them (due to the DTV switch coming up in February).
Posted on Sep 09, 2008
No sound when playing dvd, connection to vhs player
tried to record coming from other tape and replace the audio cord.
Sep 15, 2012 | Televison & Video
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Mar 13, 2011 | Philips DVD740VR DVD Player/VCR
Audio Problems playing VHS tapes with Denon AVR 1910
Did it EVER work as expected with VCR audio through the HDMI or are we working through that right now assuming it can?
I don't have a detailed manual, but the rear panel clearly shows some analog-only outputs (and NO digital ones) for the section called DVD/VCR. Internally, I'm sure there are proper analog-digital-converters for recording VHS to the native DVD-R, but VHS VCR's are NOT inherently digital audio devices so I'm pretty sure you need to run an analog RCA pair for the VHS video.
Feb 22, 2010 | Denon AVR588 Receiver
Burn dvd from vhs
i'm assuming you have a vcr to play your vhs tapes, just plug your audio/video cord from your vcr(out), plug into the audio/video vc10(in), start playing vcr and press rec botton whenever you want to start to record. make sure you can only use dvd+r. choose the quality for the length of time, at the end press 'function' to finalize the disc, then you are done.
Sep 06, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Sansui vrdvd5000- need manual
Hi seemaile,
All my searches resulted to negative which leads me to believe that there no readily available user manual for the Sansui VR DVD5000.
Sorry.
May 26, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
VHS has audio but no video
we cannot get the vcr portion to work only the dvd player4.gif works what are we doing wrong?
Have the same problem? Click Here
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video1.gif (yellow) RCA jack and S-VIDEO jack. If you are using the Component jacks, the DVD side will work but the VCR will not. This is because the quality of video recorded on VHS tapes is so much lower than component quality video.
Thank you for rating this solution.
Nov 26, 2007 | Televison & Video
Philips vr630 vhs
I get the same problem with one tape (it's about 20 minutes long) .. it also shows a '4' ... when you press the power button it ejects the tape... some tapes are fine ...
Jul 14, 2006 | Philips VR630 VHS VCR
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Why does the VCR ejects my tape?
The VHS PlayPak adaptor uses 1 AA battery. When you place your VHS-C tape into the adaptor and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink-wrap has been removed from the battery.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
