Have an AURIA EQ5588 55" TV .... would like to connect external speakers.
Would like to connect external speakers. Does it have an Audio Out jack? Will I have to go thru an amplifier ?? Thank you,
  • sdovi Jan 22, 2013
    I forgot to mention that the AURIA EQ5588 55" TV
    I forgot to mention that the AURIA EQ5588 55" TV does not have any jacks on the back marked "Audio Out"
    Top Expert:
  • Televison & ... Master
  • 47,716 Answers
Only you can look at the sides and back to see if it has audio output jack , we are not there you see
Posted on Nov 27, 2015
pgh_pa_guy
  • 2992 Answers
SOURCE: Which external speakers work with an Emerson 19" LCD digital TV?
Coaxial digital output is not a speaker-level signal, and you don't connect speakers directly to it. It's an output signal meant to feed an amplifier which takes that kind of input. You then connect the speakers to the amp and select the digital input, the same as you connect a CD player and select that when you want play a disc.
Posted on Feb 13, 2009
SOURCE: CANT CONNECT MY BOSE COMPANION 3 SPEAKER TO MY 42LG50 LCD TV
I have just brought the bose companion 3 speakers and i connected it to the headphone socket in my tv and it worked.
Hope this helps
Posted on Apr 15, 2009
SOURCE: No sound from external speakers system
Look into your monitor settings and computer settings and see if you can reverse the "input" and "output". If both are set to line in or line out then they pretty much cancell themselves out.
Posted on May 23, 2009
  • 171 Answers
SOURCE: connect external pc speakers to flat screen tv
get a 3.5mm -> rca adapter. You need to convert from the 3.5mm jack that your speakers uses to the rca jacks that your tv expects.
Like this:
http://ecx.images-amazon.com/images/I/31TelR%2BsCYL._SS400_.jpg
Posted on Aug 31, 2009
  • 120 Answers
SOURCE: what is easylink connection? Wireless? HDMI?
The Easylink is Philips name for HDMI CEC which allows multiple HDMI devices to control each other with one remote.
As for the sound...it looks like there is only one audio out and it's in the form of coaxial cable which isn't very helpful.
What I would suggest is that you tap the audio coming from the input. So I'm assuming your TV is connected to a cable/dish box. Use the audio out from that to power your headphones or external speakers. This will likely mean you can't use the HDMI or will need a splitter, but at least it will solve your issue.
Posted on Oct 16, 2009
How do you connect an auria eq5588 tv to a bose solo 15/10 tv sound system
Make the connection to the "Variable Audio" output jack of the TV.
Sep 08, 2016 | Televison & Video
How do I connect an external speaker
There are a couple different ways.you ca go
On the back of your tv you could have either,
1 - Optical Audio output
2 - RCA jack audio output ( Red and White color ports )
or
3 - 1/4 inch auido jack. audio out
When you find the jack that matches up to the deice you want to connect hook them up ad then go into your TV settings menu and turn on External speakers
Mar 04, 2015 | Televison & Video
I have a Sony Bravia KDL52S5100 , I connected my PS3 through HDMI and connected external speakers through the 3mm audio out on the side. It used to work fine but now the audio is not playing through my...
This information comes from the online reference book: Using the Sound Menu
Use the remote to open the TV menu. Select the Sound menu, and the "speakers" decision. From the two choices, "TV Speakers" tells the tv to use its built-in speakers. "Audio System" tells the TV to use an external audio system, and disables the internal speakers. Select "Audio System," and check to see if it works. If it still hasn't recognized that there is an external audio system plugged in, you may need to clean the stereo mini jack (3mm audio jack) with a small wooden toothpick or similar small diameter non-conducting device.
Feb 27, 2014 | Televison & Video
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
I want to connect external speakers to tv
If this unit has audio output jacks then these would be connected through an amplifier to provide your external speakers. Caution: Do not open the tv and connect additional speakers to installed speakers because you'll blow the small audio amp in the tv. I have seen this attempted many times
Dec 24, 2013 | Philips Magnavox 27MS343S 27" TV
On an auria eq4088p back panel which jacks are the audio OUT jacks
It is normally marked on the panel. The white and red RC sockets are normally the audio in/out.
Aug 28, 2012 | EQD EQ4088p LCD TV
Having problem with audio, with auria tv (when unplug headphones, sound will not come back on tv)
The socket for the jack on the set has a leaf connection that when you insert the jack moves aside routing sound to head phones and cutting it off to speakers= the socket for the jack is out of position inside, either needs to be replaced or tweaked inside just a little.
Not much else can cause this if the headphones work.
May 02, 2012 | EQD Auria EQ2488F 24 LCD TV
I just bought a Panasonic TV model TC L37E3 and I do not know how to coneect my external speakers. Please help me as I feel very frustrated by now. Carlos
Carlos, I just bought an LCD tv too. To connect external speakers to mine I had to buy some high end 5 channel pc speakers and connect them through the headphone jack(I know how stupid that sounds considering we spend $1000.00 on a TV and thats my only option for external speakers.I looked at your owners manual and didn't see a headphone jack though so you may have to opt for speakers that plug in with through the usb port. Some new tvs won't support external speakers unless you use complete home theater surround sound system which will connect through the rca cables (red,white)
May 22, 2011 | Panasonic Televison & Video
I just sold my surround sound system and now I can't get the on board speakers to work.
Just check the rear of the television if by chance you have left any cable still connected to the audio output jack. If there the TV might be trying to redirect the audio to an external device not present. Sometimes it could also be a simple setting to be changed , . Check if you have a switch at the back of the TV stating External or Internal speakers. From the manual i got
A/V Receiver: The TV can detect audio connections on the DIGITAL AUDIO OUT jack and the right (red) analog AVR AUDIO OUTPUT jack.
Note for Analog A/V Receivers: When you disconnect an analog A/V receiver, manually change the Speakers setting to TV to hear sound from the TV speakers.
Press Menu on the remote-> Goto AV
Select Audio by pressing the right key
Under that the first option of Speakers -> select and set to TV.
Only then will the TV speakers play the audio.
Hope this Helps.
Mar 04, 2011 | Mitsubishi Televison & Video
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Electro Med Services...
