Question about Anne Klein WRIST WATCH 10 / 8275 - Y121E
Watch has stopped -
Battery not the problem
Watch is a man's Collection Tango. After 2 years, a new battery. Soon after, the first battery, watch stopped. another new battery. certified watch maker, a new battery. has stopped again. Now, w?hat?
Sorry but I have no idea what brand of battery these are or if that is unusual for this model watch to use so much power. Use name brand batteries only. Duracell is the best for long life.
May 01, 2017 | The Watches
Watch stopped .flat battery ? Timex Indiglo watch
it the battery is more than 2 years old --probably
if it has a light on the dial then definitely as that uses battery up
if fairly new then take it in for a check up
Jun 04, 2016 | Timex Indiglo Watches
I have replaced the batery several times and the watch does not keep time and stops.Lucien Piccard 26489
mcdevito75 Here, hopefully you didn"t buy the batteries all from the same store, as watch batteries and all batteries have a shelf life of not too long. You may have bought weak batteries if all were bought from the same store, nothing to do about that as who knows the strength of packaged batteries. If you did buy all the batteries from one store, try another store and buy another battery, If the watch still stops and goes, your watch may be wearing out, specially if the watch is over 10 years old.
Sep 13, 2010 | Watches
Battery is good, but watch stopped.
You need to hold in reset and mode to make it go back on.
Dec 31, 2009 | Novelty Watches
I just bought my wife a michele csx-36 watch. Its brand new. The watch runs for about one day then stops . What do you think it is. We did replace the battery already. Thanks
that happened to me too...the watch repair man told me that I had the stop watch on. The stop watch should serve as a stop watch, not the second hand. The second time on your watch is the small dial at the bottom middle of the face. Once I turned off the stop watch feature, my battery life is fine...I have not had to change my battery in over 2 years now. HOpe this helps.
Dec 14, 2009 | Michele CSX Diamond watch
I have gone through 3 different watches, 2 fossils and one Bulova. All of them would just stop after a couple of months. I would replace batteries, then they would stop again. Is there any truth to the...
This is not a myth, but reality. Every living thing has it's own electric field and so do the humans. The difference is in density of that field - some has stronger, some weaker. And this is the cause of fast battery discharge and mciromotor stoping. Very few people has this field so dense, that the battery driven watch stops as soon as this person touches the watch. Most common is the case when the wearer of the watch needs to replace watch battery very frequently,so, I suggest you are one of them.
Consider of buying an automatic mechanical watch (spring driven). These watches are more expensive then their battery driven counterparts, but they can last for generations if looked after.
Do not buy kinetic or solar powered watches as you will expierence the same struggle as with battery driven watch.
Rate me, please.
Mar 19, 2009 | Watches
Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Feb 09, 2009 | Relic 0504648FA
Swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
Sep 09, 2008 | Watches
Anne Klein WRIST WATCH 10 / 8275 - Y121E Logo
22 people viewed this question
Top Anne Klein Watches Experts
Ansel Alberto
Ansel Alberto
Andrew Taylor
Andrew Taylor
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
