Question about Dryers
I replaced the blower fuse in my kenmore dryer cuz it wouldn't come on. Now it comes on and it seems as if my dryer is not blowing out hot air. So I was wondering since I had to replace that fuse could it had possibly made my heating element go out or what else could it b?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
It appears that one or more safety limits have failed. You will need an OHM meter to determine which one has failed.
Posted on Jan 22, 2013
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
astruttman
  • 45 Answers
SOURCE: dryer blows house fuse --keeps tumbling--no heat
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
Now, if your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. You have to remove the entire front panel on some models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
Posted on Jan 11, 2009
TheMobilian
  • 8220 Answers
SOURCE: My Kenmore 80 series electric dryer won't heat. I
The bottom limit is engineered to open at 250F and the small top one is supposed to open at 300F. The bottom did not have time to click in and so it is considered weak. the kit comes with both thermostats in it Part number 279769
Posted on Mar 07, 2009
  • 15 Answers
SOURCE: my kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Posted on Jul 20, 2009
hunter19_46m
  • 7482 Answers
SOURCE: my kenmore dryer 66722 will
Hi bjay1973...
I know you have check and replaced some of these, but maybe you missed some of these solutions.
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Posted on Aug 26, 2011
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!!
Apr 28, 2015 | Kenmore Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
How to change the belt in the kenmore dryer model number 110.62822101. Dryer is not spinning so I would assume its the belt correct?
It is indeed a belt issue if the dryer blows hot air, which means the motor is running, but the drum does not turn. Otherwise, the thermal fuse (part number 3392519) mounted on the blower has failed. This thermal fuse is wired in series with the motor circuit and its failure results in the motor not running and the dryer not working at all.
Remove the dryer real panel to access the blower housing and check the continuity of the thermal fuse. Grab a volt-ohmmeter and set it to the R X 1 scale then disconnect one wire from the thermal fuse terminals then check the continuity of the thermal fuse. Replace the thermal fuse should it read open.
May 29, 2010 | Kenmore 64602 Electric Dryer
Kenmore Elite Sensor Smart Gas Dryer - no hot air
unplug the dryer,if you haven't cleaned out the dryer check the thermal fuse located on top of the blower wheel housing,remove bottom panel,then remove lint filter,now remove the duct that the lint filter slides down into,now you'll be able to check the thermal fuse located on the top right side of the blower wheel housing,there's also a thermister there too,the fuse is the one on the left,part number 3392519 or 3390719,remove one of the wires and read it out with your meter.also while your in there vac out the inside of dryer,if you have a shop vac put it on blow and blow off all the lint that's built up on the motor and you can also blow the lint that's in the back of dryer forwards so you won't have to pull the drum,if you have a long run on the vent line from the wall to the outside blow it out with a leaf blower,if there is any blocks in the vent line,the duct or lint inside the dryer you could have a fire so this should be done every year,now if the fuse is good you gonna have to read out the ignitor,the sensor and the gas coils,if you have parcial heat it's definetly the gas coils,when they heat up they stop working when they're bad,if you need anything else let me know,so check the thermal fuse first,then the ignitor,sensor and coils,if they are good check to see if power is coming down to fuse and ignitor,you have a computer board on this dryer but most of the time it's the fuse and a dryer clean out
Dec 16, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer doesn't get hot
unplug dryer,take bottom panel off and take out the lint filter,remove the blower wheel duct and clean out the lint,while you have the cover off read out the thermal fuse located on top of the blower wheel housing,remove one of the wires when you read it out, if the air isn't moving outside it will pop the fuse.vac out the inside of dryer and if you have a shop vac switch it on blow and blow off all the lint off of the motor,you should do this once a year so you don't have a fire.if the fuse is good,read out the ignitor,sensor and gas coils.when you get it running go outside and make sure the air is blowing out strong,if it isn't you could have a blocked vent line,if it's a long run use a leaf blower to blow out the vent line.
Nov 28, 2009 | Kenmore Dryers
Dryer not blowing hot air
you either have bad element or bad thermo disk or thermo fuse
Jul 01, 2009 | Kenmore 63942 Dryer
I have a kenmore dryer model #110-74212200 and it does not get hot?
need to check vent system. restricted air flow
will reduce the amount of heat unit will give in result dry time will be extended. if no heat is detected then the thermal fuse needs to be replaced. thermal fuse blows when there is not enough air flow over heating element. meaning there is a restriction in the venting system.
Jun 21, 2009 | Dryers
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
