Question about Novatel Art Explosion Publisher Pro 2.0 Full Version Mini Box for PC (PGW)
How do i get my publisher pro 2.0 to work with windows 7
It will not install correctly with windows 7 is thers some kind of patch to make it work from vista to windows 7
4 Suggested Answers
SOURCE: loading Art Explosion 2.0 publisher pro on windows
I had to download an upgrade from their website to allow Vista to operate properly.
Posted on Mar 08, 2009
Muzzi_123
  • 749 Answers
SOURCE: will not install on vista
hi try to run it in windows vista compatibility mode
START> Control Pannel> Programs> Use An older program with this version of windows
Hope it helps
Muzzi_123
Posted on Mar 31, 2009
  • 269 Answers
SOURCE: Disc 2 is missing a file on Publisher Pro 2.0,
here is full program download it and slap in your registration key and it should make you legal
http://download.cnet.com/Art-Explosion-Publisher-Pro/3000-6675_4-10361939.html
Melody
Posted on Jun 04, 2010
Unable to burn discs using Corel Video Studio X2. Program all OK until final phase of burning. Using Windows 7 on new PC. Could problem be Windows 7? Any help appreciated.
Make sure that you have all the patches installed from Corel's site, there is a known issue that the buttons will not show up on Windows 7 unless you have the latest patch.
If you have all the update installed there could be a few different issues.
1. update direct x from Microsoft
2. Make sure your video card drivers are up to date
3. Try rendering the project first and then burn the rendered file to the DVD
4. Try burning a Disc image, the option is on the final burn screen, if you are able to create the disc image try a different burning software that you may have installed on the system
Sep 11, 2011 | Corel Video Studio Pro X2 for PC
I have windows 7 and my disc will not load. Is there a patch for templates?
Sep 05, 2011 | StompSoft CD Stomper Pro Labeling
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
Trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit? any suggestions around...
Title: trying to install printmaster 95 on my windows 7. error message appears that it is non compatible with 64 bit. is ther a patch available to make pm 95 compatiable with 64 bit
First of all download compatiable driver for that printer for win 7and install it
May 08, 2011 | Computers & Internet
Does Photo Impact Pro version 13 work in Windows 7
This version of the software is currently not working on Windows 7, and the developers are not working on patching it. What you can try, is right clicking on the program, go so settings, look for "compactability" and choose "windows XP servicepack 3", and the running the program agein. This might solve your problem.
Mar 08, 2011 | Nova Development Photo Explosion Deluxe...
I have an older version of creatacard Gold2 with 32bit. I have a new windows 7 computer it said to call the vender. Is ther a patch to allow this to run.
You can try to run the software in compatibility mode, which means that you can tell Windows 7 to run the software as if it was any previous version of Windows. To do this, browse to the setup.exe or install.exe file on the disk, right-click and select "Properties". Go to the "Compatibility" Tab, tick the box and select a previous version of Windows - the back of the CD Case will tell you which is the best version.
Feb 28, 2011 | Broderbund American Greeting CreataCard...
Unable to use Micrografx Picture Publisher 10.0 with Win 7
Make sure that Micrografx Picture Publisher 10 pro installs into the X66 Program files folder.By default it will always install into the 64 bit program file if you have a 64bit installed.
If you have the 32 bit Windows 7 installed then right click with your mouse on the program before opening it up and select compatibility mode.Select XP SP3 compatibility mode.This works fine on my Windows 7 32bit. Use the first paragraph method if you have the 64bit Windows 7.
Regards Brian
Feb 14, 2011 | Micrografx Picture Publisher 10
Open Questions:
Novatel Art Explosion Publisher Pro 2.0 Full Version Mini Box for PC (PGW) Logo
55 people viewed this question
Top Novatel Computers & Internet Experts
ray gallant
Chris
Are you a Novatel Computer and Internet Expert? Answer questions, earn points and help others
