Question about E-Machines eMachines Desktop PC
My emachine T3624 i bought used, and i cant get norton off of it,
Norton fire wall wont let me connect to internet how do i get it off and or reboot as new, its not like my dell on new reboot to factory i can do that but not on this dang machine,can u help?
it tells me to go to norton site for help but cant get out to go there.i cant get out to any where with my ie7
also by clicking on send to drive E on my desk top items to save them will this save the file or just the desk top i-con?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Norton has a habit of being so good that it interferes with some normal activities. Should you wish to uninstall a Norton product and if at all possible, download and run the Norton Removal Tool. Soon as the Norton Product is un-installed, remove the remaining Symantec folders in Common Shared folders. Thereafter, pls follow below procedures:
  1. On the Windows taskbar, click Start > Programs > Accessories > Windows Explorer.
  2. Delete the program installation folders for all Symantec program that were installed.
  3. If you accepted the defaults, the installation folders will be in C:Program Files and will have the name of the program that you installed.
Below listed are the default program folder names and locations listed by program:
  • C:Program FilesNorton Internet Security
  • C:Program FilesNorton SystemWorks
It would help to configure Windows to show all files.
  • Click on "Windows Key" and select Control Panel
  • Double click on Folder options.
  • Click on View Tab
  • Un-check "Hide file extensions for known file types."
  • Under the "Hidden files" folder, click "Show hidden files and folders."
  • Click on Apply
  • Click on OK.
Having performed the above, search for and delete all Symantec folders.
  1. Click on "Windows Key" and select Computer.
  2. Double click on C Drive
  3. Go to the following locations and delete the following folders.
  • c:Program FilesNorton Internet Security
  • c:Program FilesCommon FilesSymantec Shared
  • C:ProgramDataSymantec
and delete all the 3 folders.
Finish by cleaning up the Registry:
CAUTION: you must back up the registry before you make any changes to it. Incorrect changes to the registry can result in permanent data loss or corrupted files. Modify only the keys that are specified.
  • Click Start and then Run.
  • Type REGEDIT into the Run dialog box when it comes up and then click OK.
  • The Registry Editor will open.
  • Navigate to and select the following key:
HKEY_LOCAL_MACHINESOFTWARESymantec
  • Press the Delete key on your keyboard and click Yes to confirm.
HKEY_CURRENT_USERSoftwareSymantec
  • Click on File in the top toolbar and then click Exit.
  • If the error message is still there, go to Start and search for SymAddln and if found one entry in C:/Users/user name/Favorites/Internet Shortcut and delete it and reboot your computer.
Pls post back results. Good luck and thank you for using FixYa.
Posted on Jan 27, 2009
    Brigadier General:
  • 8,619 Answers
Hi
If you are using Norton Personal firewall then follow these simple steps :
Turn on or turn off Norton Personal Firewall 1 Start Norton Personal Firewall. 2 In the left pane, click Status & Settings. 3 Click Security. 4 Click Turn on or Turn off.
If you are using Norton Internet Security then follow this steps :
STEP 1 Log on using the Supervisor account 1 Start Norton Internet Security. 2 In the Norton Internet Security window, in the left pane, click User Accounts. 3 The account that you are logged on as is displayed after "you are logged on as:"
  • If you are logged on as Supervisor, go to "To turn on or turn off Norton Internet Security."
  • If you are not logged on as Supervisor, go to line 4 of this STEP.
4 Click Log Off.
5 In the Confirm dialog box, click Yes. 6 Click Log On. 7 In the Log on dialog box, in the Account Name list, click Supervisor. 8 In the Password field, type your password. If you have never assigned a password to the Supervisor account, leave this field blank. 9 Click OK. You should see the text "You are logged on as: Supervisor." STEP 2 Turn on or turn off Norton Internet Security 1 Start Norton Internet Security. 2 In the left pane, click Status & Settings. 3 Click Security. 4 Click Turn on or Turn off.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Jan 27, 2009
    I had the same issue with my IE 7 and I followed these steps and it worked :
    3 Click Security.
    Scholar:
  • 49 Answers
The best way to get rid of stubborn software is to boot into safe mode and then uninstall it.  This way it is not being used and can be uninstalled.  Reboot your computer and after the beep starting hitting F8.  When a boot menu appears, select Safe Mode (no networking).  Once the system boots up, it may look a bit different.  Go to Add/Remove Software and remove all Norton products.  When it is done, reboot normally and you should be good to go.
    Genius:
  • 2,035 Answers
Start Norton Internet Security or Norton Personal Firewall. 2 In the left pane, click Status & Settings. 3 In the right pane, click Security. 4 Click Turn Off.And try to connect ...Good luck..
    Genius:
  • 2,920 Answers
Have yougone to add remove programs toremove norton? it should allow you to take it off that way. you might try it and see if that helps or not. if you had reboot disks you could restart the whole system and start it over again.
    Master:
  • 416 Answers
You can just uninstall the Norton Antivirus Folder in program files
and reboot the PC. But you will need to get antother antivirus then.
Then you send file to E it will place the copy of the file you sending where.
Good Luck
    Sergeant:
    Novelist:
  • 326 Answers
Just uninstall the program if u dont want it.go to control panel-then add/remove programs -then scroll for this norton and click remove.thanks.
My computer wont load new programmes unless i disable my anti virus
I would suggest to get rid of Norton via control panel - Remove programs reboot computer and then install Free AVG. anti virus program seems more flexible with current software then the previous minimizing fire wall conflicts and issues.May get ti here or Cnet.com
http://www.avg.com/us-en/trustav_bt_ppc?ctype=ppc&utm_source=google&utm_medium=cpc&utm_term=free%20avg&utm_campaign=US%20AVG%20Free&gclid=CPO635vKxLICFQQ3nAodA1sACw
Sep 20, 2012 | Acer Aspire One A150-1006 Notebook
How can i guet the ethernet controler for a emachines t3624
Hi
thank you for your query
Please go to the following link
http://www.emachines.com/support/drivers.html
Then choose Desktop> T Series > T3624
You will be rpesented for all your drivers, download and install the ethernet drivers
Regards
shauqat
Apr 28, 2010 | E-Machines T3624 PC Desktop
T3624 MB not turning on
try to reset and clean the memory located in mainboard memory slot, that is the first ideal step to fixed that problem
Oct 11, 2009 | E-Machines T3624 PC Desktop
Have T3624 need drivers for nic card
Try going to eMachines driver support page and see if you can download the drivers for your system.
ALSO TRY:
Here are the drivers for emachines t3624 ethernet: http://downloadfinder.intel.com/scri...nm=PL2KXPM.EXE
Jul 12, 2009 | E-Machines Computers & Internet
Emachine T3624 has no power at all
sounds like the power supply may have gone. try replacing it. or using a old PSU lying about
Jun 09, 2009 | E-Machines eMachines Desktop PC
Need drivers
Have you tried here?
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T3624
Apr 18, 2009 | Computers & Internet
Emachines T3624 Ethernet controler
well, if you have a built-in NIC card, usually you should have a CD that has the driver for you ethernet controller.
or you might want to visit the link below to download your driver
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3624
I think the one you need is that Intel 845GV Chipset Driver
Mar 25, 2009 | E-Machines eMachines Desktop PC
T3624 MB someone pulled off the 3 wire pairs to the front bezel. What's the pin out for the 2 leds & power on??
According to the internet, your computer has an Intel 845GV chipset motherboard. Intel tends to use a generic pattern for connecting the front panel connectors. A description can be found on intel's site.
If this doesn't solve your problem, comment back with the motherboard model number. Look on the board, it should be printed somewhere, and it should start with D845GV...something something...
Steven
Sep 17, 2008 | E-Machines (308714) Motherboard
Cant get internet
ok call your computer manufacturer let them no ,then call your internet service provider and also try to use any other disc.
May 28, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
344 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
