Question about Brother Sewing Machines
Xr-9000 When I start sewing, the thread gets tangled below the needle and makes a horrible noise. Currently, I can't even sew. The machine says E1 in the window. (I'm not at home to look up the code.)
  • 323 Answers
SOURCE: Thread breaking.
Rethread the machine following these directions:
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
Make sure the thread is through the take up lever.
sewman7
Sewman7
Posted on Jul 10, 2008
Pnutgllry
  • 57 Answers
SOURCE: sewing machine, strange noise
Is the needle in right? There is a front and back to a needle. Also is it the right needle for the machine?
Posted on Jan 05, 2009
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: Kenmore 385 sewing machine won't sew
try oiling the machine
Posted on Jan 06, 2009
Mongo32
  • 111 Answers
SOURCE: When sewing the bobin thread tangles and jams
upper tension/threading wrong?
Posted on Jul 08, 2009
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Bobbin thread keeps catching under the plate
Your needle may be new, but Is needle correct size for fabric you are sewing? If so, is needle all the way up as far as it will go in needle bar shaft, flat side in back & more rounded side facing you? Stretch knits and wovens, denims, and leather do not use same needle size. Jimmy
Apr 09, 2012 | Singer Quantum 9940 Computerized Sewing...
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
Sewing in reverse cuts top thread, help? Please!
the fabric & thread & needle may not be compatable
try changing the needle- it may be damaged
the horrible grinding noise needs to be check --the machine needs to be serviced
check for burrs on the needle plate & on the bobbin
some sewing machines don't do with strong material
Mar 18, 2012 | Sewing Machines
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
I attached the walking foot , but the needle will sew through the fabric
this is what my instruction book says
Lo---a button is pressed when the machine halts due to overload
wait for at least 15 seconds to recover
if thread jamming causes overload, remove the tangled threads
Jan 17, 2012 | Janome Memory Craft 9000 Computerized...
Jammed thread.
To address my needle thread tangling (horribly) in the bobbin compartment, I rethreaded the bobbin. I cleaned the bobbin and the feeder feet, I changed the bobbin and the thread. I changed the tension on the needle thread and the bobbin thread. NO FIX! Then, I changed the needle - the problem was fixed instantly. I sewed awhile and then put the original needle back in. No problem. I think perhaps that the problem is being caused by the needle getting out of alignment somehow during sewing. If you are having the same issue, try it. It can't hurt!
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Janome 9000
The heavy "knitting" on the backside of the fabric sounds like a tension issue due to your thread catcher or other. You may want to look at this link:
http://reviews.ebay.com/SEWING-MACHINE-COMMON-TROUBLES-HELPFUL-HINTS_W0QQugidZ10000000007548289
The fuse issue may very well be unrelated, just coincidental.
Aug 19, 2008 | Janome Memory Craft 9000 Computerized...
Tons of loops on bottom
Check your threading.
Berhaps your thread is not between the discs.
Mar 09, 2007 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
19 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
