Question about Acer Aspire X1430 Desktop Computer
Keyboard not working
Only a few function keys at end of row work and dvd controls at top. that whole row works
  • Acer Master
  • 27,725 Answers
Gather your supplies. There are commercial kits available, but a can of compressed air, a lint-free cloth or wipes, mild dishwashing liquid, and a vacuum cleaner with a soft brush are all you really need for a basic cleaning. After turning off your computer and unplugging your keyboard, gently shake the keyboard upside down over some newspaper to dislodge loose crumbs and particles. Use the can of compressed air to blow a stream of air between the keys. Repeat Step 2. Dampen a lint-free cloth with a diluted solution of dishwashing liquid and water to wipe down the keys. Use the vacuum cleaner brush attachment to suck away any remaining dirt or debris. If you have a membrane-type keyboard (it doesn\'t have a spring under each key) and the keys are truly grungy, you can remove the keys with a small screwdriver and use cotton swabs and 90% isopropyl alcohol or methylated spirits to get it sparkling clean
Hope this helps.
Posted on Jan 22, 2013
2 Suggested Answers
skdeepak88
  • 232 Answers
SOURCE: Wont boot- no signal on screen after a few moments
The problem is with your RAM. Dust it and re install it. It may work. If you cant get it fixed get your friends RAM and see if it is working. Check if you get any beep sound from the PC. If so the problem is with RAM and need to be changed. Thanks!
Posted on Aug 16, 2009
Why doesnt the third row of keys on my keyboard do not workk
The keyboard itself is defective. The keys are "strung" together in groupings. The T just happens to be on another string then the top row.. To verify you can easly hook up an external keyboard and verify that it works. Once verified it all works then the problem itself will be in the keyboard. Replace the keyboard. You can easly find them online and are not that expensive or hard to replace.
May 15, 2014 | HEWLETT-PACKARD ProBook 6460B
My computer laptop model is Toshiba satellite P750. The FN key doesn't work. Nothing happen when i touch it.
The "Fn" key is a function key, it works with the top row of F1 to F12 keys.
By pressing and holding down the "Fn" key, then pressing one of the top
row "F" keys,
I'v provided a link for you to go to for the full list of "F" functions and what they
do for you as well as how to operate them on your Toshiba Laptop.
http://www.ehow.com/list_5941452_laptop-keyboard-functions.html
Aug 27, 2011 | Computers & Internet
Using F keys- What is used for the Fn key?
FN key is to be used in combination with the function keys like F1, F2 , F3 and so on to launch or initiate a specific function on your computer and utilities or features that came with in.
Dec 31, 2010 | HP P2360AA Keyboard/Mouse
Mouse pad stopped working
If you are referring to the "touch pad" on Laptop/notebook, if the touchpad on your laptop is not working and is unresponsive, it's not broken, you or someone else has accidently deactivated it with the function key.
Then you can try this,
Most laptops (if not all) come with a function key. The function key is labelled "Fn" and usually stands out from the rest - either the "Fn" is in a different color or the key as a whole. The function key works in conjunction with other keys on the keyboard especially the ones in the top row marked "F1" to "F12". The combination of function key with these keys lets you perform various tasks quickly such as shutting the screen, putting the computer in sleep mode, switching the wireless connection on and off etc.
By keeping the function key pressed and then hitting one of the keys ("F1" to "F12"), activates a task. You can activate and deactivate the touchpad by using the function key with the "F8" key.
Hope it helps.
Dec 11, 2010 | Computers & Internet
I have an Acer Aspire 5517. Just the other day, my touchpad and keyboard stopped working. What do I do?
1 . Look for Fn function key - Most laptops have this special key Fn that is next to the Ctrl key on the keyboard. It should have a blue or green color, easy to find.
2 . Look for F1 to F12 functions keys, they are on the top row of the keypad. Look for one has an icon that looks like the touch pad, which is to control the touch pad of your laptop. It maybe F8 or F9 depends on each make of your laptop. These function keys also control the brightness, sound, wireless etc.
3 . Now hold down the Fn key and the F10 key to enable the touch pad, in this example, the Toshiba laptops. You press them again to disable it
4 . If none of the above works, plug in an USB mouse, then check into the Control Panel -> touch pad or mouse configurations. Also, check Device Manager if the touch pad driver is installed and working properly.
Thanks.Have a great day.
Oct 17, 2010 | Acer NSK8458AN Keyboard
Laptop Certain Keys Non Responsive on keyboard
if it was just water ...shut it down and blow with cool air from a hair dryer until it will work ...not with hot air cause it has some plastic sheets inside..just let it dry ...and will work ,,if it was something else ..with sugar ..like beer..juice or so...it will need opening and clean well and dry and after that will work ..if it has permanent damages needs a keyboard replacing ...
meanwhile if it loosing its functions...just connect a usb based kayboard and use it instead..until replacement ..if the functions will not came after drying ..but if it was just water will get back after it will dry completeli and no longer make false contacts/..
Mar 29, 2010 | Computers & Internet
I have a sony vaio lalptop and some letters are not working at all: 9,o,l,,,. (I am on another laptop). Help
Hi treborswindl
Look on the keyboard to see whether any of the function keys on the top row are on. If so, you have to turn it off.
How do you do it?
Locate the [FN] key at the bottom (this is the function key between the [CTRL] and [WIN] keys.
Hold down the [FN] key and the numbered function key which is on ( for example F11 ) the top row which is lit.
Goto Microsoft word or Notepad and try out your keys.
Hope this will work for you.
Good luck
luciana44
Dec 02, 2009 | Sony VAIO VGP-WKB1 Keyboard
THE SCREEN IS NOT WORKING,BUT YOU CAN SEE VERY DARK ON THE SCREEN THAT THE COMPUTER IS WORKING, I TRIED TO CONECT A EXTERNAL MONITOR, BUT IS NOT WORKING, DO I NEED TO PUSH SOMETHING, AFTER CONECT THE...
Your keyboard has a special "Function key" (printed in blue). It is probably on the lower-left, next to the special Windows key or control key.
You also have several keys along the top row, also blue.
Hold the blue [Fn] and press the upper key that resembles a monitor. Release the two keys and wait a few seconds. If the monitor does not come on, wait a few more seconds, the press the two blue keys again. It will work.
By the way, the fluorescent lamp that creates the "backlight" for your laptop screen has burned out or the cable may be loose.
Oct 05, 2009 | Computers & Internet
How do I get my belkin keyboard to acknowledge the top row functions etc favourites music folders. They used to work and now they don't. Either does the home and end buttons. Thanx in advance
You must have got a CD with the keyboard. Just insert it and install the software. The keys would work again. If you do not have the CD, let me know the model of the keyboard and I will be able to give you a link to download the software.
May 13, 2009 | Belkin Wireless Keyboard/Optical Mouse...
Acer Aspire X1430 Desktop Computer Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
