Question about Sony FD Trinitron WEGA KV-36FV310 36" TV
Fix ocp problem
Tv turns on then turns off have tried unplgging for awhile doesn't work had unplugged for couple of months and plugged it back in and tv worked for few days then same problem can an ungrounded outlet cause this problem and if i ground the outlet will that fix the problem if not tell me what will have no $ to pay repair man to come
  • 4234 Answers
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Posted on Jul 07, 2008
SOURCE: Spilt Water
I have a Sharp 2006 TV Water got in it and i took hair dryer and dryed it out a long time its been around 6 days now all it will do when the romote is push on or click it just makes a noise like it comes on but nothing comes on light Crt no sound etc after a few seconds it makes another clicking sound..
Posted on Feb 17, 2009
rsheehan
  • 69 Answers
SOURCE: 36xbr800 sometimrs will turn on sometimes won't
it may be open contact on the flyback or
bad solder in standby power supply
Give it a smack open hand on the side
or better yet if you can have someone press
the power button as you rock it back and forth
this can tell you if its bad solder some times.
Posted on Jun 24, 2009
  • 476 Answers
SOURCE: SONY KV-36HS500 will not turn
the light blinking six times indicates a probable horizontal circuit failure usually a shorted horiz out transistors but this is not the only component located in this circuit that could create this problem, sorry but i am affraid you'll need to get a tech to diagnose it to the component level or get another pc board to repair it. hope this helps some.
Posted on Aug 12, 2009
Testimonial: "This TV expert was on the money and clear with instructions. While I couldn't fix my TV, the advice was accurate and I will hire a pro to fix my set."
SOURCE: TV will not turn on
Sounds like the power supply needs replacing.
TV repair is best done by a pro unless one has significant experience with it.
Charlie
Posted on Aug 15, 2009
Scepter 32". Received this for Christmas 2012. It's worked beautifully up until about a month ago. When you turn it on the blue light comes on but nothing happens. You can't turn it back off without...
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
It's not unusual for this type of electronics to only last a couple of years.
May 03, 2014 | Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
How to turn my sony tv back on
You are experiencing intermittent power supply failure
May 05, 2013 | Sony BRAVIA Televison & Video
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Lost the remote to my akai tv was able to turn off and on yesterday i couldn't get it to turn off so i unplged it from the wall later came back home plug the tv back up and now the power light doesn't
Hi Tamara,
Mosty likely when you turned it off from the wall,it must blown the fuse because of the way it was shut off suddenly.
If you can open it up if not than take it to a qualified Tech to get it fixed.
thanks,
G..
Nov 21, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
I have a zenith z42pq20 about a year and 3 month yesterday a hear a thunder, my tv was on, there.s a power failure and then the standbay light turn red but the tv doesn't turn on. The light doesn't...
Sounds like you took a hit. Unplug your set for 30 minutes and plug it bcck in. It could have just locked up the micro. If this does not fix, unplug the set and take the back off. Plug the set back in and check the powersupply for your 5 volts dc. If it is there, replace your main pcb.
Jul 20, 2011 | Televison & Video
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
LG 32 in. HDTV keeps turning off.
I Have the same problem, LG 32" , LC2D a couple of work arounds that work are
1) - never unplug the mains plug
2) - i noticed it does this when the clock time is --:-- , i find that switching to digital tv can stop this,
however these are only tempory fixes and the problem re surfices, as i have found out after having no problem for 12 months, i have accidently unplugged the mains, and now the tc keep turning itself off,
Oct 31, 2007 | LG 32LX3DC 32 in. LCD HDTV
Tv turns its self on or off at times
I tried to unplug mine for awhile then plug it back in that worked for awhile now it won't come at all. Hope this helps abit, although i'm sure your like me and have tried it all,8)
Jan 17, 2007 | RCA 27F650T 27" TV
Sony FD Trinitron WEGA KV-36FV310 36" TV Logo
134 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
