Question about Minn Kota Maxxum 101/BG/Hand Freshwater Bow Mount - 36v-101lb.-52 (Minn Kota)
Broken pivot bolt on Minn kota Maxxum 101 mount
How do i get the bolt out since it broke off in the bracket?
  • 2920 Answers
SOURCE: MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
Posted on Sep 21, 2008
tbirdfan1
  • 3051 Answers
SOURCE: Where can I get installation manuel for Minn Kota bow mount maxx?
Hi there
if you go to the web site of the manufacture they havre a printable version of the manual there is even a phone number to call for help please try this ok and let me know how this works for you
best regards mike
Posted on Mar 06, 2009
sleprocks
  • 147 Answers
SOURCE: Why does my 65lbs minn kota maxxum not run quite?
Fishing string on shaft, runing while out of water(will burn up seals so fast), bent shaft, off balance prop, bad rotor in the electric motor. lots of variables. I bought one that was noisy out of the box, vibrated very bad from the get go
Posted on Oct 22, 2009
SOURCE: need a shematic of minn kota maxxum 55 lb bow
the pin that holds the handle up broke, Is this a big expense to fix?
Posted on Jan 21, 2010
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
How do i release 101 fortrex motor from mounting bracket
There is a pin that goes through the shaft, a small circle clip that holds it in place. Remove the clip and pull out the pin. This may require a hammer and drift as they tend to corrode in the aluminum. don't forget to pull the rope and release the catch.
Jun 02, 2014 | Minn Kota Maxxum 101/BG/Hand Freshwater...
Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
Looking for parts brakesdown minnkota 101
Google the Make and model...dozens of web sites, including MinnKota,
Dec 16, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
TOOK THE BOLTS OUT OF MINN KOTA AND CANT GET THEM IN. 2 SHORT.
Hi!
Here's a schematic:
Max 74 Bowmount
Make sure the end housing #7has a small mark in it pointed to the bottom (towards the skeg). The bolts can be a pain to line up!
Also make sure the armature is all the way forward it can go....past the brushes is the toughest part to get through and lined up. Keep it up, you'll get it!
Best of luck
Mike
Jul 05, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Where can i get a circuit board for my minn kota foot pedal Part # is 9901-200c
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
I lost istallation manual for minn kota power drive v2 50# thrust bow mount tolling motor, where can I find instruction manual?
Contact the people at this Email address. Minn Kota <Motors@johnsonoutdoors.com> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
Minn Kota Maxxum 101/BG/Hand Freshwater Bow Mount - 36v-101lb.-52 (Minn Kota) Logo
29 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
