Question about Fisher Paykel 884518P Refrigerator Evaporator Fan Motor
884518P Refrigerator Evaporator Fan Motor is running but fridge not cooling
    Problem Solver:
  • 6 Answers
Check the condenser coil, is it plugged? If not you may have a refrigerant leak
Posted on Jan 22, 2013
Samsung RB31F Fridge/Freezer - fridge temperature too high, freezer OK
1-The condenser coils are usually located under the refrigerator. They dissipate heat as refrigerant passes through them. If the condenser coils are dirty, they won't dissipate the heat effectively. As debris builds up on the coils, the refrigerator becomes less efficient, causing the refrigerator to work harder to cool down. If the coils are significantly dirty, the refrigerator will not be able to maintain the proper temperature. Check the condenser coils to determine if they are dirty-if the condenser coils are dirty, clean them.
2-The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Oct 29, 2017 | Samsung Refrigerators
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
Evaporator fan is running but refrigerator side still not cool
Possibly blocked vent between fridge and freezer. could be ice or frozen food that has gotten in vent, blocking air flow. Also you say the fan is running but can you SEE IT? I have had occasion where the MOTOR is running but the fan blade is loose on the motor shaft. especially top freezer models.
Feb 01, 2014 | Whirlpool Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
Mar 07, 2010 | Refrigerators
Kenmore Trio: the refridgerator is not getting cool
In the Freezer or Fridge compartment, there is the Evaporator Fan (& Motor) If the freezer is cold, the Evaporator fan motor most likely went bad. Check to see that when the compressor is running, so should be the fan motor. If not, you have to remove it & replace it. It is not an expensive repair unless you call for service on it. Make sure that you unplug the fridge when you replace the fan motor.
Mar 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge not cooling
Check and see if your evaporator fan motor is working in the freezer. Also, if your defrost system is not working and your evaporator coil is frosted up, you will not get any cold air to the refrigerator section. You should see alot of frost on the back wall of the freezer where the evaporator coil is located. If your evaporator fan motor is working and there is no frost build up on the coil, the air diffuser to the refrigerator section may be the problem. Put your hand in front of it when the evaporator fan motor is running and feel if any air is coming thru. There are a number of conditions that can cause your problem. This should get you started! Visit me on Ebay as username: themackshack. Good luck! Mack
Mar 23, 2008 | Refrigerators
Fisher Paykel 884518P Refrigerator Evaporator Fan Motor Logo
Top Fisher Paykel Refrigerators Experts
Bill Boyd
gbob59
Are you a Fisher Paykel Refrigerator Expert? Answer questions, earn points and help others
