Question about Amana Refrigerators
Refrigerator freezer stuck - Amana Refrigerators
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
I am guessing you are saying the freezer door is stuck closed and will not open? If this is the case you may need to pour some warm water around the seal until it is loose enough to open. After getting it open check the seal around the door, if there are places the seal is not completely sealed, then the seal needs replaced. Sometimes when the seal fails to seal properly moisture in the air seeps in and freezes next to the seal, eventually freezing the door to the box.
Posted on Jan 21, 2013
Refrigerator bottom is not working well. the freezer is still freezing but not as good.
Your defrost terminator and heater are where the problem lies. The evaporator coil is probably iced up. The ice is acting as an insulation shield. So the freezer will remain cold, but not as cold as it should be. Unplugging the refrigerator and letting it defrost, will solve the problem temporarily. The refrigerator will work for a couple days. But the root of the problem will still need to be fixed.
Feb 27, 2011 | Magic Chef CTB1922 Top Freezer...
Refrigerator seems to be stuck in defrost mode
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator is warm but freezer is fine - what is the problem and can it be fixed?
It sounds like its a stuck baffle, yes it can be fixed. The air from the freezer cant get into the fresh food section when the baffle is stuck.
Nov 09, 2010 | Kenmore 73503 Stainless Steel Bottom...
The freezer was showing high temperature, then defrosted overnight...why
Defrost timer/control stuck....
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 19, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
Freezer leak, Ice inside the freezer (AMADA ARB220ZC)
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 08, 2010 | Amana ARB220ZC Bottom Freezer Refrigerator
Refrigerator is stuck in defrost mode.
If the compressor is running and not getting cold I would say that you have burnt out your compressor.
If it was stuck in defrost you wouldn't hear the frig running. When in defrost the compressor stops while the frig defrosts.
Dec 29, 2009 | Refrigerators
Frezzer stuck in defrost cycle
You have a bad thermostat . The piece the refrig temp knob is on ( not the freezer knob , it works off an adjusting rod ) .
Nov 12, 2009 | Kenmore Refrigerators
My refrigerator/freezer is not get cold
If the compressor and the fans are not working then the ref is stuck in defrost. Check the defrost timer
Aug 11, 2009 | Maytag MTB1953HE Top Freezer Refrigerator
My freezer control in my ge side by side refrigerator is stuck
change the termostat that control temperature . is burned out. you need new one.
Apr 05, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Refrigerators Logo
100 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
