Question about Dishwashers
I have a Hotpoint bf1260 dishwasher. There was some waater in the filter and i drained it out. now the only wash cycle available is eco and it won't move on to any other. even when i choose eco it
SOURCE: hotpoint fdw60 eco error code
I had this problem too, but discovered the cause and the remedy.
The flashing eco light signifies that the drain sump has water in it. Before the machine takes on water it checks a float located in the sump. If the float says that there is water in the sump then the machine presumes that there has been a problem when draining and decides not to take on any more water.
In my particular case, the sump collected extra water after the machine has last drained itself because the bottom spray arm has come off and allowed some water to enter the machine. Make sure that you check that!
The simple solution is to empty the sump of water. Do this by tipping the machine onto its right side. Warning! You will get wet feet! There was about a 1/4 pint of water in my dishwasher.
After that you should find that your dishwasher works perfectly again! Why Hotpoint couldn't include this simple task in their manual I'll never know! Health & Safety I guess...
HTH!
Posted on Sep 21, 2008
  • 157 Answers
SOURCE: HOTPOINT AQUARIUS FDW60 ECO LIGHT FLASHING
Check pump is running
Posted on Dec 19, 2008
SOURCE: Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Posted on Feb 24, 2009
SOURCE: Hotpoint BF1620
What you will find is that the plastic nut fixed on the back panel that the top drawer pushes into has lost the rubber inner layer. Replace and your problem is solved
Kamal
Posted on Mar 12, 2009
  • 15 Answers
SOURCE: Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Posted on Apr 10, 2009
Dishwasher will not empty after cycle and motor makes humming noise hotpoint dishwasher bf1260
The motor is frozen. Remove the bottom kick plate and with unit in off position take a screw driver or use your hands to turn the motor. You will feel the motor when it lets go. Close door and turn on dishwasher and you should be fine. Very common with the GE made dish washers.
Apr 27, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
Dec 21, 2009 | Dishwashers
When I switch on my dishwasher setting it at normal wash cycle it appears to start as normal then after few seconds goes onto to Eco 45 c wash - the light flashes but nothing happens i.e. no water comes...
you may want to check and clear the pump
you have something slowing your drain
but for giggles make sure your float valve is free to go up and down like it should
all dishwashers attempt to drain first
so you have a conflict between the float position and the pump sensor
Oct 08, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint dish washer aquarius
I had the same problem with my Hotpoint Aquarius the eco and fast light flashing, it would go through the pre wash cycle and stop.
I cleaned the filters etc; and it still didn’t work.
I turned the machine off and unplugged it at the mains,
I drained all the water, turned the machine on the side and took the bottom off, I removed the drain pump off the bottom (this was held on with a single screw after taking the screw out slightly turn it to one side as its like a bayonet fit on a light bulb also remove the wire connection and a rubber drain pipe)
Once the pump was removed I could clearly see the impellor it was very tight and I couldn’t spin it after a closer examination I could see a foreign object jamming it I removed this with a pair of tweezers, replaced the pump and put it all back together and it now works perfectly.
I hope this can be of some help.
Peter.
Aug 26, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Eco light flashing on Global 300
drained out where the float is, haven't run a full cycle yet but a partial cycle worked. i think definitely drain the float tank.
Apr 18, 2008 | Dishwashers
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Dishwasher just draines and nothing else??
this sounds like it could be the heater element has gone faulty, it is quite difficult to get to test it with it being built in, but basically gain access to the underneath of the appliance and you can test it with a test meter for open circuit, it is also possible that a wire has either come off or broken, the pump pumping out is like a safety mechanism, the eco wash may work because this uses no heat? (some models) the answer i have given you is based on the info you have supplied if i have helped please rate me, thank you, please work safe unplug when working on appliances
Sep 22, 2007 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
112 people viewed this question
Top Dishwashers Experts
