Question about Car Audio & Video
Axer IDC-5100 - Car Audio & Video
How can solve error p 5 idc sensor in konica minolta bizhub c450
P5 front IDC sensor failure.Wipe clean the surface of the transfer belt if it is dirty with a soft cloth or change the transfer belt unit is damaged.Reinstall or reconnect IDC sensor shutter or connector for every color unit and clean the sensors when vacuum cleaner after remove the all imaging units and the transfer belt unit.
Mar 25, 2014 | Konica Minolta bizhub Office Equipment &...
Need the code for Blaupunkt IDC A09
Ask here for free advice and code
www.ukbookshelf.co.uk
Jun 12, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Entered code says wait 1 hour
When you add an IDC-A09 changer to a pre-2004 car, you should not need to enter any code, it should just plug and play. If you have added an IDC-A09 changer to a post 2004 car the you have probably got the wrong changer. Post 2004 cars *usually* need the IDC-A04 changer, which looks identical.
The IDC-A04 uses CAN-bus while the IDC-A09 uses VAN-bus wiring. The two are not interchangable.
Apr 03, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC A09
hi whats your email?
will email you.
mark
Jul 19, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Axer orbicam
Try to update driver from acer or manufactures site.
Dec 06, 2007 | Acer Aspire 5100 Notebook
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
