Question about Nintendo DSi Matte Blue Console
Nintendo dsi error 051101-1
It says " a security key is needed to connect to this access point,enter security key then tap okay
5 Suggested Answers
  • 17 Answers
SOURCE: What is a security key it says unable to connect
The security key is the password that protects your internet from other people connecting to your internet connection. To find out what your secuity key is there are three things you can do.
1. Check the back of your router, The security key is usually printed on there.
2. If it is not on the back of your router and are not very good with a pc or laptop contact your internet service provider they can usualy tell you the key.
3. If you are good on a computer and it is connected to the internet connection you want to use, turn it on then once everything is loaded a signal bar should appear in the bottom right hand corner of your screen. left click on that and a pop up box should appear. Right click on the network you use and click on status. Another pop up box should appear with your network settings, Click on the button that says wireless properties. Another pop up box will appear and at the top of the box click security. There should then be your security key but it will be hidden like a password. At the bottom there should be a check box that says show characters, tick that box and your security key should appear.
hope this helps
Posted on Jan 09, 2011
Da Goose
  • 66 Answers
SOURCE: We're trying to set up
I'm think that you need to enter a code, I have attach a doc that should help you out. I found this link at Nintend.com
Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
Posted on Jan 23, 2011
  • 55 Answers
SOURCE: internet access on the nintendo
The nintendo dsi needs a wireless router transmitting in MIXED mode, meaning that it transmits using B mode as well as G or for newer routers N mode. If it is setup to transmit in G or N only, then the DSI will not detect it.
Also, the DSI is not compatible with WPA security. You need to set up a weaker WEP security code or turn off wifi security altogether.
Also, make sure the router is broadcasting the SSID name which is the name of the wireless router.
for more information: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=051099&system=DS&locale=en_US
Posted on Mar 05, 2011
CaptainHawk1
  • 345 Answers
SOURCE: My nintendo dsi pink console
You need to have an accessible Wifi router in order to connect to the Internet. The message means that there isn't one.
Posted on May 08, 2011
Im not able to use Nintendo Wi-Fi Conection because of a communication error.My error code is:51099
Turn on the Nintendo DSi then Click on the wrench icon to access "System Settings." Select "Internet" on the third page of System Settings. Select "Connection Settings" and tap the "None" bar in "Connection 1." You have the option of setting up a connection manually, or searching for available connections in the area. The easiest thing to do is select "Search for an Access Point." Your Nintendo DSi will list the names of any wireless access points in range. A gold, unlocked icon next to the connection's name signifies an unlocked WEP (Wired Equivalent Privacy) connection that can be accessed immediately. A locked gold icon signifies an encrypted WEP connection that requires a WEP key (password).
If you are accessing a locked/encrypted connection, enter your WEP key. You may also click "Change Security Settings" to enter a WPA (Wi-Fi Protected Access) key. If your WEP key is correct, your Nintendo DSi should connect. You can test your connection to verify. You're set! Now you can surf the Internet, purchase games and add-ons in the Nintendo DSi Shop, and play games that allow wireless access and competition (with WEP connections, only).
Note Most Nintendo DS and DSi owners can get online by searching for an access point, but some might have to resort to manual setup.The Nintendo DSi can go online with a WPA connection, but actually playing DSi games online requires a WEP connection.
Jun 26, 2011 | Nintendo DS Lite
Tip
How to connect your Nintendo DSi to the internet
In this guide I will go over the steps you will need to take in order to connect your DSi to the internet. You must first be in range of a wireless access point in order to use it. If you do not have wireless internet at home, you can use local hot spots that do such as coffee shops and school libraries. <br /><br />-Turn on your DSi and click on the wrench icon which will take you to System Settings. <br />-Go to page 3 and select "Internet", and click on "Connection Settings"<br />-Click "None" to the right of "Connection 1"<br />-Click "Search for an Access Point"<br /><br />This will bring up any wireless access points within range of your DSi. Any access points that have a gold lock that is unlocked means this access point does not require a security key. If you are going to use a access point that requires a security key, you will need to enter this key in. <br /><br />-Go back to the "Connection Settings" page and select "Advanced Setup". You will then be prompted for your wireless access point security information. Enter it in here.<br /><br />Okay. You should be connected and ready to enjoy your DSi. Good luck! <br /><br />G33k
on May 11, 2011 | Nintendo DSi Black Console
Everytime I try to connect the internet to my dsi it dosn't let me and i never ever get any signal its always red and when it dosn't connect it says to visit support.nintendo.com and it also says...
Jun 25, 2011 | Nintendo Video Game Consoles & Games
No internet
  1. Turn on your Nintendo DSi and access your system settings by clicking on the wrench icon.
  2. Scroll over to the third page, and select "Internet."
  3. Now choose "Connection Settings."
  4. Click on "None" in "Connection 1."
  5. Then click "Search for an Access Point"
The system will then display the name of any wireless access point within range. If nothing shows up, try moving to another location.
If The access point has a gold, unlocked icon, tap the access point's name, and then "OK." The system will then establish a connection with your router.
If The access point has a gold, locked icon, the Nintendo DSi has detected WEP/WPA key security on your router:
  1. Tap the Access Point name.
  2. You can either enter your WEP Key, or click "Change Security Settings" to enter a WPA key.
  3. Tap "OK" again and the system will then establish a connection with your router.
If The access point has a gray, locked icon, the system has determined your router is set to WPA security. You need to access the Advanced Setup area of the system to connect with this security method.
  • Instead of tapping "None" in "Connection 1", click "Advanced Setup", then click "None" in "Connection 5".
Feb 15, 2011 | Nintendo Dsi Pink Console
How do i get on the internet?
Jan 30, 2011 | Nintendo DSi Blue Console
Error code 051099
It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
What we need to do is try creating a new connection with your system.
1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
4. Click on "None" for "Connection 1." (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
5. Click on "Search for an Access Point."
6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Look for your wireless network.
7.What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
You will now have 3 options
A. GOLD UNLOCKED LOCK (No security - Tap on your network name to save the settings and begin a connection test.)
B. GOLD LOCKED LOCK
WEP security - Your wireless network is secured with WEP and requires a security key.
Follow the steps now depending on your option
A.
Select "OK," "Save Settings," and then "Yes." The connection test was successful - Your Nintendo DSi is now connected online.
The connection test was not successful - If the test was not successful, you will receive an error code. LET ME KNOW WHAT IT IS
B. WEP security - Your wireless network is secured with WEP and requires a security key.
Enter your WEP key
On the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300 or 51099: This means the security code entered into the Nintendo DSi is not the same one the router is set to. Scroll back up to step #3 of this page for the step-by-step directions. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Let me know what it is.
  • Jan 15, 2011 | Nintendo DSi (0.25 GB) Blue Console
    How do I do internet setup for my Nintendo DSI XL? Can I do it or will I need a computer Tech to set it up? Thank You!!!
    Jan 06, 2011 | Nintendo Video Game Consoles & Games
    How to get internet on dsi
    Jan 04, 2011 | Nintendo DSi White Console
    How do i connect the internet to my DSi?
    NOTE: All information taken from http://www.nintendo.com/consumer/systems/dsi/en_na/usb/index.jsp
    Oct 09, 2010 | Nintendo DSi Black Console
    Error code 051101
    Error Code: 051101 The WEP key for the Access Point you are attempting to connect to has changed since you last connected.
    What to do: Verify the Access Point's WEP Key is entered correctly into the Nintendo DS. If your router has slots for more than one WEP key, the first (#1) must be the one selected on your router. If you need assistance, click here and select your router manufacturer and model number. If available, our router pages can provide specific steps and information that may help you with your router's WEP Key.
    If you have multiple connection files saved to your Nintendo DS, the error message you received can help determine which connection file may be experiencing a problem:
    • Errors ending in 0 = connection file 1
    • Errors ending in 1 = connection file 2
    • Errors ending in 2 = connection file 3
    • Errors ending in 3 = Nintendo Wi-Fi USB Connector
    Feb 03, 2010 | Nintendo DSi Black Console
    Nintendo DSi Matte Blue Console Logo
    101 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
