Question about LG DLEX2450R 7.3 CF Steam Electric Dryer: DLEX2450R Dryer Red
DLEX2450R NOT HEATING AND AIRFLOW SENSOR CODE
NOT HEATING AIRFLOW SENSOR CODE
  • LG Master
  • 17,130 Answers
Check the continuity of the element, check the connection to the element and also the voltage when the cycle proceeds to heat.
click this link: heating element
Posted on Jan 22, 2013
I have a 2003 Jeep Liberty Sport 3.7 engine. giving a code of P1299, say high air flow. which sensor is this?
The computer logs this code when the mass airflow sensor indicates more airflow than expected. Is the engine idling high? It could be that the idle air control valve is jammed open. Or, there could be another excessive air flow path downstream of the airflow sensor. Check all hoses connected to the inlet duct between the airflow sensor and the throttle body. Are any of them connected to the intake manifold?
Mar 04, 2018 | Jeep Cars & Trucks
95 toyota camry engine trouble code 26 means what
Trouble code 26 has a number of reasons:-
Rich Air/Fuel Mixture / Loose Ground, Injector or Circuit, Fuel Pressure, Ignition System, Coolant Temp. Sensor (CTS), Airflow Meter (MAF), Vacuum Sensor (MAP), Heated Oxygen Sensor (HO2S) or Circuit, Cold Start Injector or Circuit,Compression Pressure, Electronic Control Module malfunction (ECM PCM)
Oct 21, 2014 | Engines & Components for Toyota 4Runner
Hello, i have an hyundai car XG3000 that detected code p0172 and p0106.
Possible causes
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Faulty Mass Air Flow (MAF) sensor
P0106 is for the Mass Airflow Sensor, so I'd look at the MAF as your failure. Only fix is to double check the wiring and if that is ok, replace the sensor.
Read more: http://engine-codes.com/p0172_hyundai.html#ixzz33nEtGOJP
May 11, 2014 | Cars & Trucks
LG DLEX2450R NOT HEATINF AND AIRFLOW SENSOR ERROR
Make sure the exhaust vent going outside is not clogged. If it is open make sure the air way in the unit is free from excess lint also. If all is clear you may have a faulty sensor.
Jan 21, 2013 | Dryers
Code 157
Error code 157 on your vehicle indicates a problem with your mass airflow sensor. The mass airflow sensor gives a reading based on the air intake and output within the engine compartment. A properly functioning sensor will contribute to better fuel economy. In some instances, you may be able to clean your mass airflow sensor to clear the error code, but the error will most likely return in a short time. Fortunately, replacing the mass airflow sensor is a reasonably simple repair.
Read more: How to Correct Engine Code 157 ' eHow.com http://www.ehow.com/how_7982654_correct-engine-code-157.html#ixzz2IH5Ki64X
Jan 17, 2013 | Ford Windstar Cars & Trucks
I recently had problems with my 2005 Mazda MPV stalling. I came to this great site and changed the IAC and it stopped stalling. But 2 days later my check engine light came on. The codes are P2197 P2195...
The descriptions for your codes are:
P2197 - H02S (RF) signal stuck lean
P2195 - H02S (RF) signal stuck lean
P2187 - Fuel System too lean at idle
P0102 - MAF circuit low input
Essentially what's happening is that your MPV is running too lean when at idle. Too much air and not enough fuel. As you speed up - it forces more air into the system which alleviates the problem.
Examine your mass airflow sensor. It should be completely clean - no fuzzies on it at all. If so - purchase some mass airflow sensor cleaner to clean the sensor. ONLY USE THE PROPER CLEANER TO AVOID DAMAGING THE SENSOR. Disconnect the battery to reset the system and turn off check engine light.
Otherwise you will need a scan tool to look at the voltages being supplied to/from the PCM for each of the Heated Oxygen Sensors and the Mass Airflow Sensor to determine which part is creating the problem.
May 25, 2011 | 2005 Mazda MPV
I have both Codes Po171 and Po 172 on I was told this is caused by a faulty Mass airflow sensor can anybody confirm these codes apply to this component. Thanks in advance
The describtion of both codes is similar.Check: intake system blocked or leak; Fuel pressure; EVAP canister purge valve;MAF sensor or HO2S heated oxigen sensor.
Apr 19, 2010 | 2001 Volkswagen Golf
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
01 nissan pathfinder
The mass airflow can get dirty and you will get trouble codes for everything under the hood except for the mass airflow. Try unplugging your mass airflow and driving the vehicle, if your problem goes away you need to clean the sensor. Buy some mass airflow cleaner though because other cleaners can damage the coating on the sensor.
Feb 26, 2009 | 1995 Nissan Pathfinder
LG DLEX2450R 7.3 CF Steam Electric Dryer: DLEX2450R Dryer Red Logo
43 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
