Question about RCA P61939 61" Rear Projection Television
I have a RCA P61939 61 in. Rear Projection Television. Would not power on one day. Day before it would not power off and when the remote buttons were pressed they showed different then what was pressed (pressed 2 it would show the menu, etc). Was finally able to power it off, now it won't power on. I checked the fuse and it is OK. Now I was able to power it on and there is only sound no picture. About 20 minutes later the sound just cut out. Now nothing.Is this something I could fix myself? If not any ideas on how much it would cost? Thanks for any help.
  • RCA Master
  • 3,904 Answers
With what you are describing I would start with the power supply. This is going to be a board, not a brick. If you can find the part online this is certainly something you could do yourself. Before you do anything back there make sure it is unplugged and discharged. Televisions can pack a wallop of stored up power. Keep in mind that this is a logical starting poing but true diagnostics would require a tech to come out or drop it off at a shop. My guesstimate for a repair would be around $300.00.
Posted on Jan 21, 2013
SOURCE: RCA HDTV DLP Rear Projection TV wont turn on
RCA Projection tvs are trash,should be off the market.
Posted on Mar 29, 2009
ctf1800
  • 4402 Answers
SOURCE: hitachi ultravision digital projection television
First try a hard reset to see if that will unlock it. Unplug the power cord for 1 hour; the power
Posted on Jan 08, 2008
SOURCE: RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Posted on Nov 07, 2009
Slinteriors
  • 8617 Answers
SOURCE: I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Posted on Dec 04, 2009
Testimonial: "Thank you. I will try this. I just dont understand why it worked with all of the button pushing on the front of the tv. Is this going to be a hard job"
electronick
  • 505 Answers
SOURCE: I have a model HD52W59
A lot of these have bad capacitors in the power board. You can see them look puffy or bulged if you disassemble and look. look for caps that look like this
If they are bad, you just need to replace with similar value caps and the issue should be solved. They should be flat on top, not bulged like the picture. If you have a convergence issue too, this can also be fixed on the same board, let me know if you get to soldering..
you will need a set of TORX bits to open up, make sure you pull the ac power first. Look @ the left side when you get inside for the bad caps, you may need to use a mirror to see back behind the U shaped heat sink (there is a big one behind there that goes bad)..
best of luck, keep in touch
Posted on Aug 16, 2010
I have an RCA 52in Rear Projection TV. One day it
There is a sub-board in this set that powers the convergence circuit. Often a big Ic shorts, two diodes and finally the main fuse. not something you can fix yourself.
Nov 05, 2009 | RCA P52926 52" Rear Projection Television
RCA D52W20 WON'T COME ON
replace CP150 and CP114 on the deflection board
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
My 1995 RCA 52
Replace capacitors in power supply,( 4 cap. ) 2.2uf 100V, 39uf 100V, 470uf 25V, Ready!!
Apr 25, 2008 | RCA P52926 52" Rear Projection Television
Front buttens locked and no remote rca d52w19byx1 itc222
when using your remote once you get to where you want to Go to adjust press channel up & down buttons this will let you scroll up and down and then use vol- vol+ to make adjustments.use buttons on front of tv.ThankYou for using FixYa.Have a Nice Day.
Feb 05, 2008 | RCA D52W19 52" Rear Projection Television
No Power
Send the chassis# to billyjones@fletchersite.com
Jan 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
RCA P61927 61 in Rear Projection Television
Hello, Replace U14501. (Maybe) Best regards, Arpi
Apr 22, 2007 | RCA P61927 61" Rear Projection Television
RCA P61939 61" Rear Projection Television Logo
114 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
