Question about Dryers
LG DLEX2450R NOT HEATINF AND AIRFLOW SENSOR ERROR
NOT HEATING AIRFLOW SENSOR CODE
    New Friend:
  • 169 Answers
Make sure the exhaust vent going outside is not clogged. If it is open make sure the air way in the unit is free from excess lint also. If all is clear you may have a faulty sensor.
Posted on Jan 22, 2013
I have an LG mimi split ductless model# LAN245HV. I have an error code CH 46 what does that mean
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Nov 20, 2017 | LG Heating & Cooling
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
LSN181HSV. Why is it indicating code 61?
LG error code 61:
Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condensables.
This would suggest it is not faulty thermistors but blocked heat exchanger in the outdoor unit. Or possibly an issue with the refrigerant level.
Aug 11, 2015 | LG Heating & Cooling
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
DLEX2450R NOT HEATING AND AIRFLOW SENSOR CODE
Check the continuity of the element, check the connection to the element and also the voltage when the cycle proceeds to heat.
click this link: heating element
Jan 21, 2013 | LG DLEX2450R 7.3 CF Steam Electric Dryer:...
Code 157
Error code 157 on your vehicle indicates a problem with your mass airflow sensor. The mass airflow sensor gives a reading based on the air intake and output within the engine compartment. A properly functioning sensor will contribute to better fuel economy. In some instances, you may be able to clean your mass airflow sensor to clear the error code, but the error will most likely return in a short time. Fortunately, replacing the mass airflow sensor is a reasonably simple repair.
Read more: How to Correct Engine Code 157 ' eHow.com http://www.ehow.com/how_7982654_correct-engine-code-157.html#ixzz2IH5Ki64X
Jan 17, 2013 | Ford Windstar Cars & Trucks
Error codes
Here are the common error codes for the LG machines.
LG Washing Machine Error or Fault Codes
If you have a LG Washing Machine you may see an error code come up and wonder what it is. Here are the common error or fault codes that will be displayed on the LG machine.
OE
This means that the washer has tried for ten minutes to drain the water out of your machine and the water did not drain out.
UE
This means that the load in the drum is out of balance causing excessive vibration when spinning.
IE
This means that the washer has not filled with water in 8 minutes.
LE
This means that the motor and the control panel are not talking to each other properly
PF
Power Failure – The power has gone out to the machine and then has come back on
FE
This means that there is too much water in the machine
PE
This means that the water level sensor is not working properly
CE
The washer motor has received and over current condition
TE
This means that your heating sensor is not working properly
SE
This means that you had a temporary sensor error
HE
This means that you had a temporary heater problem
DHE
This means that you had a temporary dry heater problem
This will give you a basic idea of what has caused your error code.
Heatman101
Mar 15, 2010 | LG WM2277H Front Load Washer
No heat but drum turns
The most common reasons of no heat is oe of 2 problems. either your heatinf element is out or your limit switch is out not allowing the heating element to switch on. your limit switch is on the heating element. it will have 2 wires on it. it looks like a button on the side of it. tht is the fastest and cheapestway to go first. if that does not work thqn i would check the heating element.
Apr 16, 2009 | GE Dryers
Dryers Logo
Top Dryers Experts
