Question about Simrad Ap1601r Elect Only Ap16 Rc36 Rf300 Ac10
GPS/Fishfinder keeps dropping and restarting
I have a Simrad CE33 GPS Fishfinder.
It powers up ok but then drops and restarts itself. I have had a technician look at it and they replaced the feed power cable, but problem persists.
The set is about 5 years old.
Any ideas please.
Had an ongoing connection problem with EQ 40 fishfinder, new power cable did
not sort it completely. Cable now unavailable anyway. Resolved, permanently
I hope by my wife, the pins were not long enough to reach the sockets in the connecting plug. So I inserted a very fine spring into the sockets, reassembled the connecting plug, somewhat crunchily and it's working. The fine spring was robbed from my wifes jewellry making kit, stuff called "Tiger Tail" and used for re-inforcing necklace ends and suchlike girlie stuff. I claim no credit at all for this repair, it has had me stumped for seven years at least it was all down to my wife. Ok I'll stop grovelling now.
Posted on Mar 13, 2012
Do a software upgrade to the CE33 unit and then a master reset by unplugging the power cable , then press and hold PWR and CLR buttoms while plugging back the power cable. Wait a couple of second while the software reloads and should run smooth....
NOTICE: All the previous data as routes, waypoints, etc that you had will be lost by the master reset.
Posted on Sep 18, 2009
My fish finder shutsdown or restarts when I start my main motor
are they drawing power from the same bat? it maybe that starting the motor drop the voltage the finder receives
Apr 25, 2016 | Lowrance HDS 5 Fishfinder GPS Chart...
Simrad CE33, I have only a blue screen when I switch it on
First thing to do is remove all cables and charts from the machine except the power cable. Try powering on and see what happens. If the same issue occurs it sounds like a boot code failure has occurred. Unfortunately, if that is the case those machines are no longer supported by Simrad and I would recommend looking around ebay or craigslist for another.
Nov 03, 2014 | Boating
I have a Simrad CE33 GPS/fishfinder. It has a black spot on the screen and keeps growing.. What can do to resolve this.I
Most likely the unit needs the entire display replaced and moisture may have played a role in this.
Bad display depending on cost of unit may mean buying a new one.
Dec 10, 2012 | GPS
My Simrad GPS/sounder won't turn on.
assuming you have checked fuses etc you may have to use it as a lunch hook for your dingy...seriuosly..don't know ow old t is but a replacement is order methinks ...just like laptops they have improved greatly now and features abound screens are bigger and better...price has also dropped?
May 27, 2012 | Simrad GPS
I need a wiring diagram for a simrad qx44 sounder
simrad nse 12 with bsm 1 sounder does it need its own power or does it get it from the starter pack thanks richard
May 28, 2010 | Simrad CX33-E WAAS/CP/FF 4012150700 No...
GPS keeps freezing, then shuts off, then restarts again, and it goes through the same process over and over again
I had a similar problem with my Garmin Nuvi 255. What I found was I needed to downloaded Garmin Webupdater from their website (not sure of the url) and download the new GPS software to my computer and then into my GPS ( in that order, they insist).
Make sure beforehand that you have charged your GPS at least 3-5 hours so that it has enough power to stay on during the entire process otherwise it could be rendered inoperable from the download.
May 12, 2010 | Tomtom ONE GPS Receiver
I cannot get a position on my Simrad CE33 chartplotter/sounder
Ensure that the external position to be OFF, refer to manual below. See interface display in [MENU],7,2
Try resetting the Chart Plotter to factory settings. Use the Delete Memory and Factory Preset options as described in section 9 of the user manual below:
M A N U A L Simrad CP33 Chartplotter
Sep 05, 2009 | Simrad CE44 GPS Receiver
Navman 4500 FishFinder
Was there ever a solution to the Fishfinder 4500 going blank but still powered on????
Jul 19, 2008 | GPS
Navman 4150 fishfinder
Depth: Could be for a number of reasons, too deep for the sounder - check the manual for it's max depth. Dirty water, sounder unable to penetrate through to the bottom. Weed or other debris covering the transducer. Transducer on a swing mount & being pushed out of alignment then dropping back in once stopped.
Speed: Is the speed readout controlled by a GPS or paddlewheel? If it's GPS, check the power connection of the sounder, may be loose which would also cause the depth to 'drop out'. If it's paddlewheel, you're down to bad connections or faulty unit.
Oct 16, 2007 | Navman Fish 4150sx GPS Receiver
Simrad Ap1601r Elect Only Ap16 Rc36 Rf300 Ac10 Logo
303 people viewed this question
Top Simrad Boating Experts
Michael Vincent Cruz
Steve
Steve
ray gallant
Are you a Simrad Boating Expert? Answer questions, earn points and help others
