Question about Maytag Washing Machines
What year is Performa washer model PAVT910AWW
Performa Model PAVT910AWW; Serial number 2699449J6
  • Maytag Master
  • 17,130 Answers
Please check this with the dealer or from the website.
Magtag performa
Posted on Jan 22, 2013
SOURCE: I have a Maytag Performa
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Posted on Jun 20, 2011
  • 1937 Answers
SOURCE: kenmore (Inglis) washer leaking oil model
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
See the Whirlpool parts list for their commercial washers, the consumer model is essentially the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The problem is likely either the transmission cover or the gearcase cover seal or the spin pinion seal.
Following is a good description from GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
When you pull the transmission, you should be able to tell where it is leaking.
In order to pull off the cover, pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 16Oz of oil
Posted on Sep 22, 2009
ginko
  • 19396 Answers
SOURCE: GE WASHER MODEL NUMBER WHDSR316GOWW,
Here you find all parts for your appliance.
Click on the diagrams to get the exploded view.
Posted on Sep 02, 2008
aborcass
  • 2651 Answers
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
SOURCE: performa PAVT910Aww
1. I assume all the water is out of the tub. If that is true the pump is ok.
2. Check the belt since this is a common "replacement" item.
3. Also watch the spin cycle by opening the door and manually actuating the door switch.
(keep your hands out).
a. The pump will pump all the water out of the tub before beginning to spin the tub.
b. Watch the time of spin also.
4. Remember a big load of towels will hold a lot of water.
Posted on Jan 26, 2009
How old is Model #PAVT910AWW
If you go to the following website and fill in the information it will give you an approximate age of your machine. You will also need your serial number as well as the model. http://www.appliance411.com/service/date-code.php
Jul 30, 2014 | Maytag Performa PAV2200
We have a maytag performa electric stove, probabley about 6 years old, and last time we did the self clean on the oven we had a lot of stains that ran down between the inside and outside door panel. This,...
Can anyone please give me the serial number and product number to a 6 year old Maytag Performa glass top stove?? I just broke the ceramic top and need to replace it but don't have a serial number.
Thanks
Liliana.
Dec 12, 2010 | Maytag PER5710 Performa Electric Kitchen...
I have a maytag performa ceramic top stove andwhen I turn on the oven it will only heat up to 230 degrees
I have a Maytag Performa Ceramic stove top which I have "washed" the serial number, I broke the glass top and need to replace it, but I don't have the model/serial number. If anyone has one please give me the numbers. Thank you
lilkadoc@hotmail.com
Apr 27, 2010 | Maytag Kitchen Ranges
Washer wont agitate or spin
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Apr 21, 2009 | Maytag Performa PAV3200
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
My pavt910aww is full of water and has no power it seems???
You most likely have a bad lid switch.
Check the switch with a volt/ohm meter set for continuity.
No reading on the meter is a bad switch.
Feb 25, 2009 | Maytag Performa PAV3200
Wash mach. will not agetate only hums
MOTOR LOCKUP?REMOVE FRONT PANEL AND CHECK MOTOR WATER PUMP,TRANS,LET ME KNOW-MIKE
Oct 11, 2008 | Maytag Performa PAV3200
Performa PAVT910Aww
CHECK YOUR WATER PUMP FOR A CLOG,LET ME KNOW-MIKE
Apr 01, 2008 | Maytag Performa PAV3200
Washing Machines Logo
364 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
