Question about Brother 925D Serger
Serger locked. My sergers handwheel is locked. I have removed and cleaned out, lint, threads. and oiled the machine. how can i get it to unlock.
  • 109 Answers
Unfortunately my experience has been whenever a serger gets "locked up" or "frozen" it requires a trip to the service department or getting a new machine. Best bet call your repairman and tell him what the problem is. You won't be able to fix it yourself.
Posted on Aug 22, 2010
My 1034d brother serger froze up. How do I unfreeze it
If it is a mechanical (not computerized) model, it most likely needs a good cleaning and oiling. (Use only good quality serger oil or Tri-Flow Synthetic Lube.)
Or it could have some threads hung up somewhere.
May be best to take it for service.
Remember, a serger requires frequent cleaning and oiling to keep it operating--more frequent than a sewing machine because there are so many moving parts and so much more lint produced.
Sep 20, 2016 | Brother 1034D Serger Sewing Machine
I bought a second hand babylock eclipse serger, the pproblem is the width sticth adjusment is stack, how do I slove it.
Just guessing the machine may need cleaning and oiling. Consult the owner's manual. Sergers usually require frequent oiling (more than sewing machines) because of the speed and complexity of moving parts in a serger. Apply 1-2 drops of fresh, good quality oil for your machine--some brands use a specific weight oil.
If in doubt, take it for service. It could probably use a very good check-up by a professional anyway. At least then you will be starting out with a tuned up, working machine.
cleaning your serger (avoid using compressed air as sometimes it will force lint and debris farther into the machine!)
Cleaning Your Serger
Serger Cleaning and Oiling
Serger Troubleshooting For Any Serger Serger Machine Series Ep 4
Since your issue is with the stitch width function, you may want to focus more on that mechanism and work at getting it released. Sometimes applying heated air from a handheld hairdryer will loosen stuck mechanisms.
Jun 10, 2016 | Baby Lock Eclipse Serger
The hand wheel on the serger won't turn and I have oiled everything and there is no thread stuck in the machine. how do I fix this without taking it to a repair shop?
If it is a non-computerized machine, you can probably remove the case (depends on the model how you would do that--my machine's case bottom comes off). Then wiggle the handwheel and see what metal parts move and apply a couple drops of oil. You can also probably try the hairdryer trick to see if that helps. NOTE: use only oil specifically for your serger!
It was working now it seems to be frozen the needle part wont move
Feb 14, 2016 | Sewing Machines
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Jan 01, 2013 | Sewing Machines
Serger motor locked up completely
I suggest taking the machine in to be serviced
Jun 09, 2012 | Juki MO-644D Mechanical Sewing Machine
Hello I just got a new home My Lock 334D machine. It has Seized intermittenly. could we troubleshoot the problem & fix it together?
Un-thread and then see if the machine will run without thread.
If not, it needs to go into the shop for repair.
If it does, refer to the manual. Or, the guide that should be printed on the inside of the serger's door.
Raise the thread antenna to it's highest position. Keep it at this position when serging. If lowered for storage, and threaded, be sure the thread does not tangle around the antenna arms.
Raise the presser foot.
Open/set the tensions to zero.
Raise the loopers to their highest level - there may be an indicator mark on the side of the serger to match with a mark on the handwheel to help with this.
Start threading from the right to the left; upper looper first.
After threading, reset the tensions to a medium number, lower the presser foot and stitch a chain to test the stitching.
Serge a scrap and adjust the tension as necessary.
Once you get the serger working as it should - don't run out of thread. Tie off, open the tension, raise presser foot and gently guide the new thread through the threading process.
When changing the thread or removing the thread to store the serger, cut the thread at the antenna, leaving thread tails for tying off the new thread.
If you do not have Nancy Zieman's "Serge with Confidence", you will find it much more informative than the average serger manual.
May 01, 2010 | Sewing Machines
How do you thread a elna L-5 sewing machine
I found two sites with a manual for this model. Both are around $15.00 - sew4less and sewusa.
If you open the front of the serger, there should be a threading guide printed on the serger or on the inside of the door.
Set the tensions to zero and raise the presser foot.
Turn the handwheel until the loopers are at their highest position - the handwheel may have a mark on it that aligns with one on the side of the serger to help with this.
Starting at the right, thread the upper looper first.
After threading, reset the tensions back to approximately mid-range.
Lower the presser foot and stitch a chain of thread to make sure the serger is stitching as it should.
I bendt my needles, and after changing them it wont sew. the threads just come out without getting sewn together.. just 4 straight threads..
Once the thread breaks, the serger usually has to be re-threaded - all four components of the serger.
Raise the antenna to it's highest position.
Open the tensions to zero.
Turn the handwheel so the the loopers are at their highest position. Some sergers have a mark on the handwheel that aligns with a mark on the side of the serger for this step.
Thread according the the sequence indicated on the threading guide - this is either on the inside of the door or on the serger.
Mar 14, 2010 | Janome MyLock 644D
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
Sewing Machines Logo
584 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
