Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Start button plastic piece broken - Whirlpool Cabrio WTW6600SBT Top Load Washer
  • Whirlpool Master
  • 17,129 Answers
The only solution before the full unit is replaced is to try and use an instant glue to patch up the pieces with reinforment from within that will make this piece firm.
Posted on Jan 22, 2013
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
The start button on my lg tromm washer does not work
The plastic piece that you push may be broken or the switch that it pushes may be broke. Sometimes you have to hold the start button for a few seconds before the actual start will take place.
Feb 19, 2015 | LG Tromm Front Load Washer And Dryer Set
Start button wont work
did you feel the clicking sound when button is press ? if no clicking sound , then it's the switch broken/wire loosen, if you cann't feel the clicking, then the plastic behind the button broken
Apr 21, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
I have same tv but the on/off button has broken and cant start the tv
On some models, there's a plastic piece which pivots, pushing the actual button itself. If you can take the back panel off and inspect it, you may find you can replace the little piece of plastic with something similar or use super glue to fix the button itself. Or you might be able to swap out the "info" button (or some other button you don't use as much) with the power button
Mar 27, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I now have 2 H233H monitors that both have the same Problem. The cheap power switch has failed because the plastic ears have broken off of the button on both of them. Is there some kind of a fix for this?...
I took my soldering iron and melted nylon-plastic to the plastic (nylon) ears and plastic button which is also nylon. I now have a permanent and stronger plastic weld than what was made at the factory.
Repair shop wanted $125 dollars. I fixed it with weed-eater nylon string and soldering iron. Start at button first, after having a small glob of melted nylon on tip of iron. Then spread it to plastic ears, all the way back to the spot where ears attach to black trim piece. Good luck
Mar 26, 2011 | Acer H233H bmid Monitor
Where can I find a reset button that went bad on my model #51591 Toro Super Blower. Toro direct told me they don't have the part any longer. Not happy about this it's just a stupid little button that can...
I also had problems getting my toro 51591 to work. I too discover the safety/kill switch. i used a screwdriver to push it in the hole and activate the machine again. it started right up. I too was going to(and am) find something to put in the hole(like a screw/nail to override and keep the machine from stopping again.it would be nice if they would tell about these safety items. like that they exist ,& where they are located, and how they work. so first try to just rest it by using the screwdriver to push the rest button. it is located on the bottom . it is just a small rectangle where the plastic part is suppose to fit . mine showed a white color filler. plastic part probably broke off and is now too short. so need to do the nail/screw trick to fix it. with duct tape. good luck
Dec 02, 2010 | Toro "Toro" Super Blower/Vac
Car will start right up but will not go into gear
There is a possibility that the plastic pieces that allow the shifter to move and slide have broken. You need to remove the console shroud and pieces to be able to see the shifter. There should be two pieces of plastic usually pink or yellow in color with a spring attatched (the spring depresses when the button on the shifter is pressed). Sometimes these plastic pieces break and blocks the shifter from moving.
You can get a factory service manual with complete removal instructions and pictures from here. 2005 Dodge Magnum Service Manual.
Oct 09, 2009 | 2005 Dodge Magnum
Toro superblower will not start. Reset didn't help
I pushed the button and it didn't work either, but what I discovered was that there is a plastic piece on the cover that pushes the button in and works as a safety switch. That piece had broken off. I used a tiny screw and electrical tape and positioned it in the same place to hold the button down. Works just fine now.
Jul 04, 2009 | Toro "Toro" Super Blower/Vac
"Open" written on screen
There is supposed to be a little plastic piece that pushes down a button that tels it that it that the door is closed that plastic piece is broken off. Look for it and glue a little piece of plastic on it, should fix it.
Jun 04, 2008 | Toshiba SD-P1600 Portable DVD Player
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
