Question about GE Dryers
What does a thermal fuse look like on a GE dryer
  • Lora Evans
    Lora Evans Jan 21, 2013
    It is electric dryer not gas
    President:
  • GE Master
  • 1,922 Answers
Its located looking at the front of the dryer with the front cover & drum removed at 2 o'clock behind the heater element it has 2 wires coning out of it and its about the diameter of a dime
Posted on Feb 12, 2013
3 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: ge dryer model# DPSR473GW1WW
Sorry, didn't realize you had a gas dryer. (Dissregard looking for 240 volts, only need 120 for gas model) There are still two thermostats on the back area I described, but not at top center. They both should have continuity. Again, make sure belt is not broken as this would kill power to motor, as would a door switch problem.
Posted on Nov 29, 2008
heatman101
  • 43501 Answers
SOURCE: Model #LGR5620KQ1 thermostat and thermal fuse are
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 16, 2010
Where is the thermal fuse located on this dryer? please
Hello Leslie
I don't know what is the brand of you dryer. I will make you a preference this brand.
In GE dryers, the thermal fuse--sometimes called a safety thermostat--is located behind the drum on the inside of the dryer. To access the thermal fuse you will need to open the dryer from the top. Though it may sound a bit daunting, opening the top of the dryer to reveal its inner workings is surprisingly simple. To open the dryer top you will need a flat-head screwdriver, putty knife or similar tool. Insert the screwdriver or putty knife underneath the dryer's top panel. Slide the putty knife along the bottom of the panel until you locate the two clips that hold it in place. These clips are usually located about four inches in from either side of the top dryer panel. Apply pressure to the clips to release them. Once the clips have been released, lift up the top panel and use the supports to keep it upright. Look inside the dryer, behind the drum, to find what looks like a round metal pan. This metal pan is actually the dryer's heating element housing. The thermal fuse will be located next to the heating element housing. Look for a white strip with two wires connected to it and you've located the thermal fuse in your GE dryer.
Best Regards
Neciforo Llanto
Oct 01, 2013 | GE Profile DPSB620GCWW Gas Dryer
DWSR483GG WONT START
the thermal fuse located on the inside rear wall of the dryer to the right side of the heating element behind the drum is open,on any GE dryer of this type if this fuse opens it kills the whole dryer operation..........no nothing,nada
Dec 09, 2012 | GE DRSR483EGWW Dryer
GE DPSE810EG won't start
You will need to check and see if the dryer has a bad thermal fuse on it. If so, it will cause the dryer not to start.
The thermal fuse should read closed for continuity. The thermostat is number 507 on this diagram. It is located on the top of the heating element housing.
Here is the part to order.
Regards,
Richard Roth
http://appliancecafe.com
Nov 15, 2012 | GE Profile 7.0 cu. ft. Electric Super...
Dryer runs but no heat. My husband is pretty smart with appliance fixes. Do you think that this thermal fuse solution would be easier enough for him to fix or should we get a repairman?
The thermal fuse is not going to be the problem...when the thermal fuse has gone out the dryer will not start so since it runs the thermal fuse is good. The number one thing that is wrong with a gas dryer when it doesn't heat is going to be a broken igniter,this tip i wrote explains what to check when a gas dryer doesn't heat http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Sep 12, 2011 | GE DBXR463GD Gas Dryer
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
Ge dryer spins but got no heat
Thermal fuse is probably bad. Disconnect power to appliance, remove wiring to the thermal fuse and jumper them or join them together. If elements come on , then the thermal fuse is bad. Cost; 10 bucks or so.
Jun 30, 2009 | Dryers
DRYER TUMBLES BUT WILL NOT HEAT
If this is a gas dryer the MOST COMMON problem would be a thermal fuse usually located in the back of the dryer. you would have to remove the back panel their is only 9 screws securing it. The thermal fuse is going to be white with 2 wires and 1 screw . Unplug the dryer remove the wires from thermal fuse and put them together temporary using tape make sure metal ends make contact and they do not touch any thing else. plug dryer back in and turn on. if every thing works than replace the thermal fuse and clean out your duct
Jan 18, 2009 | GE DBXR463GD Gas Dryer
G.e. Profile gas dryer, wont turn on but has power
Some GE dryers use a non-resettable thermal fuse. It is a dime sized object with two wires attached on the top of the element housing. (Unplug dryer, take screws out or push in clips holding dryer top down at the front of the dryer top, swing top back, see thermal fuse near very back) Newer dryers use an automatic resetting thermal fuse. The replacement part for either will be the same auto resetting one. Your problem could be several other spots, however. Check for 240 volts at dryer. (not just 120) When you swing that top up, make sure the belt is there going around the drum. (if belt broke, it switches off power on most dryers) Could be a door switch, internal motor switch, timer contacts, bad start switch, burnt off / broken wire, maybe just a stripped over start knob.
If you find that the thermal fuse was the problem, you still should clean out the vent and eliminate all or as much flex duct as possible to prevent the thermal fuse from tripping again.
Nov 29, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
71 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
