Fabric softener smart dispense is blocked - Washing Machines
  • rosewright
    rosewright Jan 22, 2013
    this is the softener dispenser housed in the pedestal drawer, we managed to get all the hoses off and flushed, the only place that we could not get to was the pump in the pedestal drawer to flush that too, tried to use it after all the flushing and still no softener, so it's gotta be plugged in the pump. That stuff solidifies in the hoses so I can imagine what the pump looks like. Any idea how to clean it??
  • Washing Mach... Master
  • 17,130 Answers
Please check this link: Dispenser.
Posted on Jan 22, 2013
3 Suggested Answers
  • 256 Answers
SOURCE: fabric softener dispenser fills up with clear water after
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Posted on Feb 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: fabric softener dispenser won't drain the fabric softener.
It appears your softener tray door solenoid has failed in this instance... or it may be gummed up.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
The fabric softener drawer is not emptying
Fabric softener is dispensed by syphon. If the softener is not dispensing there might be a blockage in the water inlet. There is usually a twin solenoid the lets water I to the machine. One to the detergent and one to the conditioner. The water path is most likely blocked with water "debris". Try cleaning the tray and housing completely then have another go
Jan 14, 2018 | Washing Machines
Water in slot for fabric softener wont drain. Always water in there. Lameez SA Jan2014
Remove the dispenser draw and wash it all out. The most likely cause is that fabric softener has congealed and blocked the dispenser. I hate what softeners do to machines with a vengeance. I would never put any fabric softener anywhere near my machine ever. They cause many problems that are not easily remedied.
Regards
John
Jan 30, 2014 | Bosch Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
When I put in my fabric softener it will not dispense into the washer during the cycle
One of two things either the motor the moves the valve form wash to fabric softener to bleach is bad or most likely the small hole in the top of the dispenser housing are clogged. I have never had any luck cleaning them out enough to work correctly,I have this same unit in my house and had the same issue with the dispenser just a couple of months ago.The fix is to replace the dispenser assy. and then leave the drawer open when not in use to air out the inside preventing the growth that blocks the passageways needed for fabric softener to work
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore elite HE, smart pack is not dispensing the fabric softner? Can you help?
The softener water flow is clogged. You know, open the dispenser while it's filling in the final rinse and look over the softener dispenser. Is there water flowing?
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
Jul 30, 2009 | Whirlpool WTW6400SW Top Load Washer
The fabric dispenser does not release softener into the tub
it may be the water supply to take the fab cond in is either blocked (holes) above the dispenser or the water valve is faulty.
Mar 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Fabric Softener not draining
its your dispenser motor or your ccu board had 1 few mouths ago same prob only fabric wouldn't work was ccu board about 300.00 for part labor 152.00, buy service smart warranty from sears wont go wrong
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softener doesn't empty
My husband just fixed ours after not seeing a solution on any other site. He pulled out the dispensing unit and pulled off the blue plastic piece on the top of the fabric softener and bleaching section. He then ran warm/hot water (not boiling hot) through the holes where the fabric softener is suppose to flow through. This cleaned out excess fabric softener that had coagulated in the elbow and blocked the flow of softener to the unit.
Feb 14, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
