Question about Toshiba 57H82 57" Rear Projection Television
Hitachi loses color
My hitiach projection tv that is about 5 years old is starting to turn to black and white on me occasionly. Is this common and/or a easy fix?
    Genius:
  • 2,920 Answers
You are losing one of your color tubes for it to be goiing to black and white.
Posted on Jan 27, 2009
53-55 in high def tv, few yrs old. picture is way too red, wont adjust out. what are some possible solutions please
If a Hitachi rear projection it may be an adjustment inside the set--If you comment here with the model number and it is what I suspect--I will tell you a easy way to try to correct this.
As a first step go to black and white program or turn color all the way off and stand back and examine the screen/picture= if not black and white and mostly RED this is a common issue on their projection sets.
Apr 21, 2012 | Hitachi Televison & Video
I have what I think is a Hitachi 55 inch ultravision rear projection TV that is 12 years old. I think the model is 55UX58B. The color goes out and it becomes black and white. It comes back after a few...
When the tv is it totally black and white and the tv picture are good and clear wright?when the tv colors are fade in and out are clear up and when the tv picture it is in colors it is look good normal picture wright?Tv have no shadows of any kinds of colors when picture are good in colors wright?Yes,take ur hand make fist or take a wooden hamer bangs all around the tv bazel frame if the tv colors come back or tv stay in colors it is have good picture in colors.Tv it is still good just have components parts are cold soldering or CRT colors guns R,G,B just require resoldering works only.
Aug 22, 2011 | Hitachi 50UX57B 50" Rear Projection...
My Hitachi 51f510 projection tv just started to have a problem with the color. It appears that the tint is red/pink and I have no control over it.
For me to help you (I think I know what is wrong and it is fairly simple to correct) I need to ASK you something.
If you turn the color all the way to zero and go to a channel that is in black and white, what color is the screen?
If it is red or redish a simple adjustment will correct this problem.
Is the picture with color down to zero on a black and white channel (old movies) red looking?
Before you rate this information, let me know what you find. I am in California and will be available for a while.
SD TECH
Jul 15, 2011 | Hitachi 51F510 51" Rear Projection...
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
Hitachi 50 Rear Projection color TV
the easiest way is to turn the color all the way down to zero. Then notice the overall color of the screen, if it doesnt appear as a good black and white picture you will have to adjust the screens. To do that you have to remove the speaker grill cover and the small access panel, then depending on the chassis you will see a small square with 6 dials on it 3 on top and 3 on the bottom it will have screen stamped on it. adjust those 3 untill your screen appears the best black and white picture as possible. Now if your chassis only has 3 dials on the sgaure control box those are focusdont adjust them. . then the 3 CRT boards will have the dials you need adjust those for the best black and white picture. when your satisfied that you have a good black and white picture. then turn your color back up and adjust the tint.Let me know if you need more assistance.
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Color fades
HELLO. it sound's like you have a cold solder problem.!!! what that mean's is that when the set get hot .!!! it lose's it's contack.!!! you might try going over the chassis .!!! soldering the conteck's.!!! with a low watt. solder gun.!!! not over 40 watt's.!!! and use 40/60 rosin core solder.!!! hope this help's you .!!! "GOOD LUCK"
Mar 14, 2008 | Hitachi 50UX58B 50" Rear Projection...
Green picture and distorted
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Mar 11, 2008 | Hitachi 42V710 42" Rear Projection HDTV
HITACHI 51F59A PROJECTION COLOR TV
we have hitachi 51 inc projection tv model 51f59a for 2 yrs. we got problem adjusting the colors the screen is reddish. pls solve this .
Jan 08, 2008 | Hitachi Televison & Video
Toshiba 57H82 57" Rear Projection Television Logo
163 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
