My Pioneer PDP-507XD does not save the dvt-channels. Everytime when I switch off my television the channels are deleted! can anyone help me?
I install them. then i switch the tv off when i switch it on again the channels are deleted
    Genius:
  • 1,003 Answers
Replaced the mainboard in this set.
Posted on Jan 21, 2013
4 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: We cannot switch on our
First, remove the TV plug from the wall, fix it back in and try again. If that doesn't solve the problem, then it means your TV is having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Apr 01, 2011
DrewPalmer04
  • 325 Answers
SOURCE: We have had problems switching
I've been running across a lot of plasma tvs where the power supplies are not bad, but the X & Y-sustain boards are faulty. My advice is to change those boards out as they are responcible for lighting the plasma gasses in the tv. You can attempt to replace one at a time (cost reasons), but it is recommended to changed both at once.
Hope this helps, please rate. :)
Posted on Apr 11, 2011
SOURCE: Pioneer PDP-r06xe 50 in. Plasma Television
I have a green block of colour all the way along the top half of the screen can this be fixed and if so how .
Posted on Apr 08, 2012
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
I'm Italian and I live close to Gorizia, I can't see some DVB channel with my PDP-4270XD TV plasma. Other TV set haven't any problem. It's necessary to make a new Download? Please give me a...
You might try this.
Go to the Scan for More Channels option in TV Signal Setup.
First delete all the channels shown and then do a rescan.
This worked for me when my cable company switched to all digital.
For some reason WMC picked up the old channel map on the existing
channels and I could not tune them even though they showed in the guide.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jun 26, 2011 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
We have had problems switching on our Pioneer PDP-507XD plasma tv. The standby light just flashes. We were advised to change the power supply unit. We hav4e done this and it has not solved the problem ...
Apr 11, 2011 | Pioneer PDP-507XD 50 in. Plasma Television
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
None of the HDMI inputs work
Tries the S-Video cable.Use that connections?
Check the HDMI input on the menu must be on or auto.
Aug 13, 2009 | Pioneer PDP-507XD 50 in. Plasma Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
