Question about Garden
Can I use power steering fluid instead of non detergent in my pressure washer pump?
    Scholar:
    New Friend:
  • 90 Answers
No, you might dissolve your seals and not have the proper lubricating properties. Power steering fluid is flowing against pressure and the 30 wt is simply lubricating at no pressure.
walmart and autozone carry 30 wt non detergent oil
Posted on Jan 22, 2013
  • 313 Answers
SOURCE: hooking up detergent to pressure washer
detergent can only be **** from the container only on low pressure.
Posted on Jul 08, 2008
  • 1388 Answers
SOURCE: Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Posted on Dec 01, 2008
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
redbeard00
  • 957 Answers
SOURCE: Coleman Powermate pressure washer PW0872400.01
The systems are simple but if they aunt stored correctly(allowed to freeze) or the air isn't purged out of it. It can result in damage to the machine.If water is dripping out of the pump it is damaged. if not then it could be air (purge system), or a damaged or stuck check valve.
Posted on Apr 26, 2009
  • 199 Answers
SOURCE: Troy-Bilt pressure washer will not pick up cleaning fluid
put the washer on low presure it will pick it up then. doesn't make since but that is how they designe them. thay make a high presurre add on device i have seen them them in local home inproverment places.
Posted on Jul 20, 2009
What kind of pump oil for simpson gcv190
I need to know the model of the pump you have. You are giving us the model of the engine which is a Honda GCV190. Can you tell me the model on the pump itself. It is more than likely an AR pump but I need to know . It is more than likely going to take 30 weight non detergent but some pumps take specific oil. You can also call Barens at Pressure washer parts catalog quick links Pressure Washers High Pressure... They can hook you up with the correct oil for your pump. Good luckOADXAV
Feb 21, 2015 | Simpson Garden
Do you use 4 cycle oil or 2 cycle oil for pressure washer EXH2425?
For your model pressure washer you should not be using 2 or 4 cycle oil. You need to use the following:
Model # EXH2425 P 2400PSI 2.5GPM 5.0HP HO
PUMP TYPE OIL TYPE OIL CAPACITY
**Annovi Reverberi (XMV) 30W non detergent 13.5 oz.
**Annovi Reverberi (RKV) 30W non detergent 18.54 oz.
Aug 15, 2011 | Garden
I have a Honda GX340 power washer and would like to know what types of oil and quantities I need for the engine and pump
The Honda engine will use standard 30W. the pump will use 30W non-detergent.
Sincerely,
Aron Kerr
Landa Northwest
www.landanw.com
Mar 09, 2011 | Honda Pressure Washer PSI 3000
MINI ONE POWER STEERING COMES AND GOES AFTER PUMP REPLACED
2 posible solutions to your problemone is that the rack and pinion unit has a restriction inside. if you remove the return line to the power steering pump and hold over a pan start engine and the pump will push old fluid into the pan instead of recirculating back into the system. you must keep power steering pump full of fluid because the return fluid is being pumped out of the system.also some models have an electric sensor switch on the pressure line that adjusts pressure by how fast the car is going.faster the car travels less power steering pressure
Feb 14, 2011 | 2003 Mini Cooper
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
The engine oil is 10W30
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
Oct 07, 2010 | Simpson PowerShot Commercial-Duty Gas...
What type of oil goes in a comet axd 3020 pressure washer pump?
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
Jul 14, 2010 | Comet GXD2527G Pressure Washer Pump
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Garden Logo
280 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
