Question about Dryers
GE dryer will not start the push button was messed up and when i was fixing it sparks flew and now it wont come on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Check the breaker panel and make sure you did not trip the breaker to the dryer.
Posted on Jan 22, 2013
watugot
  • 290 Answers
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Posted on Nov 25, 2007
  • 262 Answers
SOURCE: my dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Posted on Dec 29, 2007
ronpar
  • 27 Answers
SOURCE: Dryer wont start
look under control panel look for a burned spot or burned wires some thing is throwing the breaker under the control panel one of the controls may be bad with this kind of dryer may have to replace controls
Posted on Jun 29, 2008
  • 1122 Answers
SOURCE: GE Six Cycle Automatic Dryer just buzzes when I push start
most of the time when the syary button just busses it means the motor is gone,you can take it apart and clean and lube itmake sure nothing stuck in it,let me know if you need more help-mike
Posted on Mar 21, 2009
erpaalai
  • 999 Answers
SOURCE: kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Posted on Aug 08, 2009
I push start button and then I click saw. Why do lights flash a couple of times?
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Oct 14, 2011 - Uploaded by PartSelect
Plugged up dryer saw sparks...noticed the burn area near the grounding ... I could hear a click til around the 8th turn then tried it and it worked. ... My dryer doesn't initially turn on when I push thestart button, only when I put ...
How To Fix Dryer That Won't Start ' Dryer Repair - PartSelect
www.partselect.com/Repair/Dryer/Will-Not-Start/
When the dryer won't start then troubleshoot common parts and problems like ... On alldryers, the door switch allows the dryer to start tumbling only when the door ... Gas and electric dryers have a motor that turns the blower and the dryer drum. ... and Stratton Parts · Echo Parts · Frigidaire Parts · GE Parts · Husqvarna Parts ...Missing: saw
Dec 25, 2015 | Frigidaire Dryers
WHEN I PUSH START BUTTON DRYER HUMMS BUT WONT START
check the push start switch, the door switch and the thermal shut off fuse
Jun 24, 2014 | GE DRSR495EGWW Dryer
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
Dryer does not heat up
No pilot light, you can generally hear a faint hiss as it burns, if there were one. The burner is ignited electrically, similar to when you push that button on a gas BBQ, only a dryer does it automatically (push to start button) when turned on (and the door is closed). If you remove the bottom panel, you should see the igniter spark, if working properly.
Jul 31, 2010 | GE DBSR453EBWW Electric Dryer
I have a GE profile dryer dpsr610egwt wont start just buzzes when i push the start button
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 18, 2010 | GE Dryers
When i push the start button it just buzzes and
It sounds like your motor has gone bad....it will buzz really bad when it is tring to start and cannot...
heatman101
Asker's Testimonial " Thanks so much for your help. Now that you'v mentioned it, the buzzing does sound like it's coming from the motor. I'm,now, more comfortable in call "
Apr 10, 2010 | Maytag Dryers
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Problem with Push to Start Button on my GE Gas Dryer
This dryer is under warranty. Call the store where you purchased it as they are obligated to fix it for free or take it back.
May 07, 2009 | General Electric DCVH640GJ Gas Dryer
Open Questions:
Dryers Logo
35 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
