Question about Polaroid 2611-TLXB TV
No power to polaroid 3211-tlxb - Polaroid 2611-TLXB TV
5 Suggested Answers
Garfunkel01
  • 56 Answers
SOURCE: Lost remote
what kind of universal remote are you trying? They're all different
Posted on Sep 12, 2007
tomswrldtech
  • 90 Answers
SOURCE: I have a Polaroid 3211-TLXB -It starts up
hi there, this may helps you a bit. Try to unscrew the back casing. visual check the power supply section. If you notice some electrolytic capacitors are bulgy or bloated, it needs to be replaced with same value and type. Felt the power transistors which one really heats up. Over heating of electronic components or part do affects the pictures. this also need to be replace. doing preventive repairs can extend the lifespan of your TV.
Adding exhaust fan may also lessen the heat builds up on the board. Proper ventilation also helps in the performance of the TV. If this do went well maintain the fan.
Please vote and rate. Good day
Posted on Mar 11, 2011
ekcnoel
  • 998 Answers
SOURCE: No Picture sound only Polaroid 3211-TLXB
Sir the problem of your tv has two possibility, the inverter board may be damage or there is no supply to the inverter board. To check the voltage input on your inverter board you should remove the back cover of your tv, the supply input is 24 volts dc. If you can do this let me know.
Posted on Aug 14, 2011
  • 1548 Answers
SOURCE: polaroid 3211-tlxb have power and sound but no picture. It did smell like smoke. Any recommendations? Unit is 2 years old.
If you can see a picture (dim and low contrast) when you shine a light on the screen from an angle, your backlight inverter may have a burned-out part.
After this test, whichever result you get, unplug the set and use your eyes and nose to search for overheated parts. I have found connectors that overheated because of a poor-quality solder connection on the circuit board. Note that parts, particularly resistors, can overheat because of a fault in another part.
It is common for solder connections to deteriorate if they are frequently run at high temperatures. Sometimes circuit boards "normally" turn brown from heat because of marginal thermal design. Check the solder connections on components in the hot areas.
Static electricity precaution: most digital electronics are easily damaged by static electricity discharge. Avoid touching the metal parts of the circuitry unless you first touch the metal frame of the set to discharge any voltage buildup on your body.
Posted on Nov 10, 2011
My polaroid 3211-tlxb tv wont power on
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 24, 2015 | Polaroid Televison & Video
Polaroid 3211-TLXB solarized / negative image
Just replace the T-Con board and you dont need any soldering at all. JUst be careful for the flex connector.
Jan 19, 2015 | Polaroid 3211TLXB 32 in. LCD Television
Polaroid 3211-TLXB has funny colored picture quality. Turns on and off fine and sound is fine.What could be the source of the problem??
Sounds like T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Polaroid Televison & Video
I have a Polaroid 3211-TLXB -It starts up fine-everything works great - then after 10-15 minutes it freezes + picture goes to crazy grey/white lines + volume goes to maximum-won't turn off-have to unplug -...
Mar 11, 2011 | Polaroid 3211TLXB 32 in. LCD Television
Hi Guys I have a 32' HD Widescreen LCD TV 3211-TLXB, The TV goes on ok but I have a line down the middle of the screen, on the right the reception is ok on the left side the tv seems to be loosing the...
its possible its coming from the digital board which you can get a a whole to exchange its around 400.00 or so or its the lcd panel which is as much as a new tv if you have a servicer there for polaroid you might talk to them
Oct 31, 2009 | Polaroid FLM-4201 42 in. LCD Television
I would like some help with my tv
My Polaroid TV 3211 TLXB (2007) was working fine, turned it off and now won't power up, volts on power supply are normal, red light is on. Control boxes are avaiable. Could this be the most likley problem and are they interchanable with other similsr sets. ? Thanks for any help
Feb 10, 2009 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Polaroid " 3211 TLXB red light no power up?Ive checked for Bad Caps,on the main power supply.I found none,that were swollen or leaking.It looks good.I checked volltage out to volltage inverter.all the out...
hi remove the supply to the main board & inverter, now power your psu if give you this same above voltages , go for new power supply unit. change your power
Oct 12, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Picture Size
check your picture setting if it is on zoom, you can set it back to auto cinemal or panorama
Sep 09, 2008 | Polaroid 3211TLXB 32 in. LCD Television
Lost remote
Sep 12, 2007 | Polaroid 3211TLXB 32 in. LCD Television
Polaroid 2611-TLXB TV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
