Question about Acer Aspire 5720-6661 Notebook PC
Aspire zg5 i need to take it back to the factory settings
  • Acer Master
  • 27,725 Answers
Aspire netbook to factory defaults Save any files or folders on your Acer Aspire One with flash drives. Drag and drop files onto the icon of your flash drive. Go to "Start" > "Restart" to reboot your netbook. Hold down "Alt" and "F10" when you see the Acer logo on the screen. The recovery menu will load. Hit "Enter" and then "Next" to see your recovery options. Choose "Factory Restore" to set your netbook back to factory settings. Follow the instructions on the screen. Choose your time zone and language when the customization menu appears. Reboot the netbook when you are prompted. Restore your saved files from the flash drive. or Click on the Start menu. Then, select all programs, Acer Empowering Technology and Acer eRecovery Management. If this is the first time you have opened the program it will prompt you to set up a password and create a backup CD. Click the Restore button and select the option that reads "Restore system to factory defaults". Wait for the computer to finish the restore process and reboot. Restoring for the Boot Screen If your computer will not boot up properly, you can attempt to reach the restore option by pressing the Alt button and the F10 button at the same time. When the eRecovery menu appears, choose "restore system to factory defaults". Wait for the recovery process to complete and the computer to restart Hope this helps.
Posted on Jan 21, 2013
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
1alexh
  • 484 Answers
SOURCE: restore a acer aspire 4330 back to factory settings
Follow these instructions carefully:
To start the recovery process:
1. Restart the system.
2. While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3. Refer to the onscreen instructions to perform system recovery.
I copied the above from an Acer manual, and it works on my own system, which is not the same model as yours. But you must understand that this will basically restore your computer to the condition in which it was when you bought it, unpacked it from the box, and followed the instructions to set up a new computer.
This will give you your system back as if it were brandy new, but in most cases, anything you created, like DOCs, or XLS files, again … ANYthing you created since buying this computer, will also probably not be there any more.
You will have a pristine, clean as new, computer system.
Be careful, be absolutely sure this is what you want to do, and go ahead and do it.
-a.
Posted on Dec 15, 2009
SOURCE: i need to set acer aspire 3000 back to factory
Step 1 : Click “Start” menu.
Step 2 : Click “Programs.”
Step 3 : Click “Acer Recovery Management.”
Step 4 : Click the “Restore” button on the bottom of the dialog box that opens.
Step 5 : Click “Restore System to Factory Default.”
Step 6 : Click “Yes” in the warning dialog box which asks if you wish to continue the recovery process.
Step 7 : Click “Start” to restore the computer to the default factory settings.
Posted on Jan 16, 2010
KittyTech
  • 324 Answers
SOURCE: Need to bring computer back
Hi and welcome to FixYa!
This is an easy fix! To wipe it clean and make it run like new, while your computer is starting up, press Alt+F10 repeatedly. It will go to factory restore screen, which will ask you to confirm if you wish to completely restore it. Please be advised that if the computer goes to normal start up again, you must turn computer off and restart process as soon as it is starting up. I have done this to several Acers myself and it took me a few tries when i was 'new' to these steps. Also, please save any files or pics in email or upload them to a site if you wish to keep them. This will remove everything you have saved on your computer!
Please rate this solution if it was helpful!
KittyTech
Posted on Nov 15, 2010
subahar
  • 110 Answers
SOURCE: i need to set up my aspire netbook back to factory
Restart your system and then continuosly press the ALT+F10 and then choose factory default seting.
It will recover the your system and go with older stage.
Before you do one thing,Please backup the important data.
Posted on Nov 23, 2010
I need cmos password for acer aspire one zg5
CMOS does not have a factory default password. If there is a password, some person added it to the computer and you would need to ask them what the password is.
Sep 24, 2014 | Acer Aspire One AOA150-1570 Notebook PC
Restore laptop acer aspire zg5 to new
press and hold alt+f10 as you turn it on
Mar 10, 2014 | Computers & Internet
Enter current password aspire one zg5
Not yet. At boot can you , by using the F-10, and the Factory recovery partition, this will wipe out ALL data. Here is a procedure, at the bottom is the Factroy Recovery section. Maybe she should write down the password and store in a safe place? http://en.kioskea.net/faq/2040-acer-pc-restore-to-factory-settings
Dec 25, 2012 | Computers & Internet
Hello i have an Acer Aspire One model zg5 netbook
You're going to need to boot it from the Windows XP installation disk, which means if you don't have a CD drive you'll need to get an external CD-ROM drive. This will fix the problem.
Jul 16, 2010 | Acer Aspire One PC Notebook
Acer aspaire one zg5 laptop lan drivers required
Below you will find a site that offers the Acer Aspire one drivers. These drivers will work with your ZG5.
http://support.acer-euro.com/drivers/notebook/as_one_150.html
Let me know if you need further assistance.
Kerry L.
Mar 17, 2010 | Acer Aspire One PC Notebook
Can't find the equivalent model numbers for Aspire One ZG5
From ACER FAQs:
The Aspire One systems labeled with the model ZG5 are actually an Aspire One AOA110 or an Aspire One AOA150. Any information will be listed under AOA110 and AOA150, rather than ZG5.
The supportmodel number is located on the bottom of the netbook on a white label above the serial number. Alternatively, the support model number will be located in the BIOS which can be entered by pressing the F2 key when turning the netbook on. Once in the BIOS it will be under the Information tab to the right of Product Name
Aug 22, 2009 | Acer Aspire One PC Notebook
Wireless driver for acer aspire one series zg5
Hi there and welcome to FixYa,
I find that there is drivers for Linux, Vista and XP, go to:
this page
and choose you OS and all the drivers you need including your wireless driver :-)
Regards
/Teis
Don’t forget to vote if this was what you needed.
Thank you
Dec 17, 2008 | Computers & Internet
Help me find driver for my acer atom zg5...its xp Os
Hi and welcome to FixYa,
The driver for your Aspire Acer Atom zg5 (WinXp) can be downloaded here:
http://www.drivers-software-download.org/tag/acer-aspier-one-zg5-sound
regards
/Teis
--> dont forget to vote "FixYa" if this Fixed Your problem :-)
Dec 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5720-6661 Notebook PC Logo
223 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
