Question about Seagate ST3000DM001 Barracuda 3TB 7200 RPM 64MB cache SATA 6.0Gb/s 3.5
Hard Drive seems to large for computer.
I purchased the Seagate Barracuda HDD 3 TB SATA-600 Upgrade for the eMachines ET1331-02 Desktop/PC based on recommendations from cruicial.com site; yet it seems to large for either of the HDD slots. Do I need a special enclosure etc or was their recommendation incorrect.
SOURCE: disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Posted on Mar 12, 2009
SOURCE: How to extact the data off the Seagate Barracuda 7200.10 320GB HD
if its your motherboard that crashed then ther is no problem with your hard disk. connect your hard disk to any other computer and you can access all the files in it.
if it is your harddsik that crashed then try recovery utilities like western digital data storege manger or any other disk recovery tool available for free. if still it fails then you can recover your data if you hand over your hard disk to the nearest service centre. but recover from a hard disk only if its very valuable. thay will charge you per MB of data recovered
Posted on Jul 04, 2009
graysand
  • 558 Answers
SOURCE: Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Posted on Oct 04, 2009
Testimonial: "Very helpful! Thank you!"
lserni
  • 466 Answers
SOURCE: Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Posted on Nov 25, 2009
  • 16 Answers
SOURCE: Seagate Barracuda 7200.10 250mb HDD - Spins up then spins down
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware/
Posted on Nov 30, 2009
How can i to connect a hard drive sata with sata to ide adapter on biostar u8668d motherboard?
you will need to purchase a serial ata adaptor card for pci slot with support for sata 1/2/3 I believe. Try ebuyer.com
Mar 31, 2015 | Seagate Barracuda 7200.10 (ST3750640AS)...
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate pipeline hdd 500 gb. can I remove it from a lorex dvr, and put it in my pc?
Any drive will work - but you have to make sure that its physical configuration matches your pc and that you reformat the drive since the format used for dvr use is not compatible .
Sep 21, 2017 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Recover data from seagate barracuda 7200.10
External hard drive case, which comes with its own PSU AC/DC power pack.
They come in IDE and SATA flavours, some with extra cables to convert IDE<>SATA.
Take HDD with to computer retailer so physical dimension can be matched.
Sep 07, 2012 | Seagate Barracuda 7200.10 ST3160215AS -...
Trying to make my seagate barracuda 7200.9 slave
1) Open your computer case
2) On the back of the drive where the connectors are, you have jumpers. These small plastic tabs change the function of your hard drive. All hard drives have a special setup procedure. The information about jumper settings is on the top of the hard drive.
3) Remove plastic tabs and put them according to "Slave" instructions.
4) Connect drive to middle connector of the cord.
5) Connect power supply cord.
6) Secure the drive in place and close computer case.
Also make sure that the main drive is not set as slave.
Apr 10, 2011 | Seagate Barracuda 7200.9 80 GB Hard Drive
Subject: SYBA SD-SATA-IDE-B Tuesday ? 25 August 2009 When I bought a SATA Hard Drive for my second computer IDE slot, I purchased the only type of IDE-SATA dongle they had in stock. As it turns out I got...
How I solved the SATA IDE Dongle problem: I looked up various devices that perform this task and I found that some of them are bidirectional with a switch attached to them to internally facilitate the necessary configuration change. I plan on buying a PCI card with SATA ports to accommodate my switchover as it makes it easier to have my previous secondary drive connected so I can easily transfer files and provides a means of having more than two hard drives on my computer should I find the need in the future.
Aug 25, 2009 | Seagate 1 TB SATA II Hard Drive
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Hp compaq dc7600sff
750GB Seagate Hard Disk Drive IDE ATA100 7200rpm 16MB
available at http://www.microdirect.co.uk/(17679)750GB-Seagate-Hard-Disk-Drive-IDE-ATA100.aspx
1TB (1000 GB) Seagate Barracuda SATA II 300 32MB cache
also available at http://www.microdirect.co.uk/(23250)1TB-1000-GB-Seagate-Barracuda-SATA-II-300.aspx
Both HDD`s are what i consider to be best in there range and very good value for money
Nov 19, 2007 | Computers & Internet
Seagate ST3000DM001 Barracuda 3TB 7200 RPM 64MB cache SATA 6.0Gb/s 3.5 Logo
13 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
