Question about Canon PIXMA MG5320 All-in-One Printer
Mg5320 no ink idicator
Light on the larger black ink blinks says empty but its full this what i have tried already.. brand new print head opened 2 new inks uninstalled printer. thank you for reading
    Genius:
  • 1,019 Answers
Sounds like the little canon needs serviced.
Posted on Jan 25, 2013
  • lind Jan 25, 2013
    sounds like it would be cheaper to just get another one lol
2 Suggested Answers
  • 65 Answers
SOURCE: ink usage problems
from service manual:
To perform a NVRAM init
1 Turn the printer off.
2 Press and hold the GO button.
3 Turn the printer on and continue to hold the GO button.
4 After the Go, Ready, and Attention LEDs turn on, continue holding for at least 20 seconds.
During this process, the Attention, Ready, and Go LEDs will each turn off.
5 Release the GO button.
6 The device LEDs will begin cycling from front to back. The NVRAM-init process runs until the
printer is in the Ready state.
Posted on Jul 13, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I have a HP Designjet100 Plus. The black went from ok to light to nothing. I have cleaned the printer head manually and thru the maintainance setting on the machine. Any suggestions? Do i need to buy a new...
You can try to disassemble the printhead and check for contamination.
First remove cap 1
than using a small flat screwdriver disassemble printhead (engagement points 2 and 3)
Warning - a printhead is filled with 8 ml ink
After disassembly - clean the printhead with fluid compatible with pigment ink (for black color) or compatible with water based ink (color printheads)
during reassembly - don't forget to fill the printhead with ink (2/3 of its volume)
May 19, 2011 | HP DesignJet 100 Plus InkJet Printer
I replaced the clear ink tank on mx7600 and the message "the clear ink is empty" will not go away nor will it print in black. The brand new Canon brand clear ink can be seen on the ink tank itself and in...
Yeah, me too. I fiddled with cycling the power, removing and reinserting the tank, doing maintenance tasks like cleaning the jets, yadda, yadda, no dice. New full Canon tank displays empty. Boo.
I figured "What the heck, I'll try printing anyway" and sent a test page on plain paper. It warned me the tank was empty, then did a bunch of those cartridge moves it likes to do (you hear the carriage moving around cleaning or something). After like 90? seconds of cleaning noises, it figured out that the tank was full, the status went to full, and it printed the page fine.
So my advice is, try printing a page anyway.
Oct 20, 2010 | Canon PIXMA MX7600 Multifunction inkjet
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Cartridge light blinks
Try cleaning the print head first in the software options on the printer and then lightly with a qtip and alcohol or electronics cleaner. The ink jets sometimes dry up and cause the nozzels to get plugged.
Sep 02, 2009 | HP DeskJet 845c Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Nov 22, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Canon PIXMA MG5320 All-in-One Printer Logo
128 people viewed this question
old marine
old marine
