Question about Whirlpool Ovens
Oven in whirlpool model rf366bxd will not heat
Oven does not heat to desired temperature setting
  • 249 Answers
SOURCE: Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Posted on Dec 18, 2007
  • 110 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
Posted on May 30, 2008
  • 71 Answers
SOURCE: MY GAS OVEN TOOK 2 HOURS TO REACH THE DESIRED TEMPERATURE OF 350.
the ignitor is prolly bad (not pulling enough amps)
Posted on Dec 24, 2008
barkencoa
  • 3463 Answers
SOURCE: fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Posted on Dec 15, 2009
  • 523 Answers
SOURCE: GE Wall Oven won't hold temperature and sometimes shuts off
t stat
Posted on May 27, 2010
Whirlpool RF375PXDN oven will not heat to desired or set temperature
The problem with the oven temperature not matching the set temperature could be caused by a bad temperature sensor. You can check the resistance of the temperature sensor with a volt/ohm meter. Unplug the range and remove the temperature sensor from the inside of the oven.Here is a link to the part.
Jan 22, 2011 | Ovens
I dont no how to pre heat the oven
To pre-heat an oven is to simply turn it on to the desired temperature and wait 5 to 10 minutes. If you have a timer then set the timer for the desired time you want to pre-heat then begin baking as usual.
There is no magic to pre-heating an oven and everyone that bakes has a different opinion.
Sep 23, 2010 | Ovens
Whirlpool Oven will not heat
Hello there:Usually,
when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. bullet.jpg If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. bullet.jpg Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. bullet.jpg Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. bullet.jpg If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jul 22, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a whirlpool range. During preheating the
sounds like you may have a bad bake element. try to see if the unit will get hot when set to broil. if it does then try the bake again. if you get no red hot heat from the bake element then you may need to replace it.
when an element is working properly it will heat to a red hot glow.
Jan 12, 2010 | Ovens
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Ovens Logo
19 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
