Question about Samsung YP-Z5 MP3 Player
It wont come on and it freezes on the samsung sign and goes white
I own a Samsung un55es7500. TV powers up but after a minute or so the screen goes white with colored line across screen also I don't have sound.
freeze the IC on the T-con board when the problem shows,if disapear or you note any change on the picture that`s the board you have to replace.
Dec 29, 2014 | Samsung Televison & Video
Samsung ln26a330j1d lcd tv picture freezes or just goes to white screen
BAD CAPACITORS!!!!!!!!!!!!!!!!!!!! FIND'EM
SWOLLEN ON THE TOP!!!!
Nov 14, 2013 | Televison & Video
I have about five white spots on my screeen tv. what is that from?
That is the first sign of the DLP chip failing ,the number of white dots will increase as time goes on.
The only solution is to have the DLP chip replaced, but it is an expensive part. You can call Samsung at 1-800-samsung to find the nearest service center.
Jun 14, 2011 | Samsung HCM4215W 42" Rear Projection...
Freezes turns white then turns off then back on
IF YOUR IMAGE IS ALL WHITE YOUR LOGIC BOARD IS DEFECT BUT IM SAD TO SAY DO NOT REPLACE THE LOGIC IT WILL ONLY TEMPORARLY SOLVE THE PROBLEM THE PANEL IS OVERLOADING THE LOGIC BOARD PANEL IS BAD
Apr 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
Wont go past the lg sign on power up ,
try taking out the battery and leave it out for about 5 to 10 minutes. then put the battery back in, if it freezes again that means there is a hardware problem present. Call your service provider and ask for troubleshooting details, they'll either try to help you out or send you another phone. hope this helps
Sep 02, 2009 | LG KE500 Cellular Phone
Samsung HLN507W freezes with black and white specks
I had the same problem. It ended up being the DMD board, which is the mirror engine. cost about $1000 to fix. Better off buying a new tv.
Mar 23, 2008 | Televison & Video
Samsung hd protector television
i have found the lamp will cause sound no picture but if the picture freezes could be dmd bd or digital bd going bad
Oct 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung YP-Z5 MP3 Player Logo
35 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
