Question about HP LaserJet 4000 Printer
Want to connect two computers (both have the 25 pin connect) to my HP Laserjet 4000 printer. Printer only has one connection port. I need a splitter (female) ends on all for my printer. Where to fi
Back connection port is a female port connect. The opposite end of each cord is the 25 pin male connect. Need a splitter to put on my printer so I can connect both computers.....thus I need a splitter that has one female connect and then splits to two female connect ends.
    Genius:
  • 1,003 Answers
Use a print server !
Posted on Jan 21, 2013
SOURCE: connect to usb on laptop
The Easy affordable solution:
www.sewelldirect.com or (801)356-3823
* USB to Parallel Adapter, part # SW-1302 ($14.95) + * Centronics to Mini Centronics, Part # SW-2104 ($12.95).
I ordered before 2pm EST and received two days later.
Plug usb into computer, wait, then plug in printer. Voila! Instantly worked!!
PS: Found this site after www.monoprice.com Product ID: 2277 (parallel to USB) and ID 257 (male to mini) - $15
Posted on Nov 06, 2007
shaggyrat
  • 1224 Answers
SOURCE: serial port on HP Laserjet 4M Plus
buy the adaptor for this these ports are called lpt ports they make adapters to run down to size
they also make a lpt printer port switch this is connected easy connect from printer to switch one printer cord then buy 2 other printer cords to hook to other computers
this is not a converter this is a switch
the printer cords can either be made on spot at most computer store or bought from fry's electronics they always have these in stock the proper lines your looking for
Posted on May 17, 2008
normdoty
  • 36 Answers
SOURCE: want to connect to my computer
hello
you will need to use the parallel printer port on your pc.
this is the default type of interface built into the hp printer.
it will be a 25 pin female connector probably built onto the motherboard.
a standard parallel cable is whats required.
25 pin male plug on one end and a 36 pin male "D" style connector on the other.
25 pin mates with pc 36 pin mates with printer, all newer versions of windows
have the hp lj 4 driver supplied on the install disk.
ps if your system does'nt have a parallel port you can install an aftermarket one,
but ill bet your 25 pin connector is a parallel port.
check it out thru windows.
----- START > SETTINGS > CONTROL PANEL > SYSTEM > HARDWARE TAB >
DEVICE MANAGER > PORTS.
this will list the ser and par ports if any on your system.
good luck.
Posted on Nov 05, 2008
SOURCE: HP PSC 500 printer
HP has the worst customer support policies known to man. I have a faulty monitor that was 2 months past warranty. Found out that the capacitors on the power board were swollen. Also found out that many people had the same problem. Aside from my hp psc 500, which is a work horse for 10 years now, I would never buy a hp product again. When I called, they gave me the same line of BS. (buy another one) Told them why should I buy another product from you if you wont help me with my current problem.
Anyways, my solution for you would be to use or buy a cheap computer with xp and share that printer on your network. Good luck.
Posted on Jan 28, 2009
  • 18 Answers
SOURCE: I have a HP Laser Jet 4 Plus and recently
You have a parallel interface on the printer. It was commonly referred to as a Centronics 36 pin cable. Your computer probably doesn't have the interface to support it. The fix is to get a cable that will work from your computer to the printer. For this you will need a USB to Parallel (Centronics) cable.
It will be hard to go to a store and locate one but I know you can find them all day long on eBay for under $10.
Try searching for "USB to Parallel" cable and see what you come up with. If you're savvy on eBay, you might want to pick up some extra toner while your there as well. The part # for your printers toner is C3903A.
Nice black and white printer that should serve you well for quite a while. Not to great doing graphics but B&W it does rather well.
Good Luck
Posted on Oct 25, 2010
Testimonial: "MisterMr - Thank you for your quick and detailed feedback! "
Connecting my printer phone line to computer. The printer says it is not connected. Also do not have installation disk to connect printer to computer and computer does not have program already installed.
You can download drivers from HP web site. Are you connecting the PC modem through the printer to a phone line? If you need to connect the PC for dial-up, I'd recommend doing it through a splitter instead of the pass-through port on the printer.
Sep 19, 2011 | HP Officejet 5610 All-In-One InkJet...
I have HP Laserjet 4000 PCL6 printer with parallel port only. I purchased a parallel to USB cable to try and get it to work, but there seems to be no way to get it to print. There is no option for setting...
Many USB to Parallel, and USB to Serial adapters/cables just don't work well, due to the processing 'overhead' in the software of the drivers for these devices.
The parallel (or serial) device at the end of the cable just doesn't 'see' responses quick enough, so asumes it not to be connected to anything.
Network adapters are plentiful and cheap for these printers. Perhaps this is the solution.
Mar 18, 2010 | HP LaserJet 4000 Printer
Can I connect my HP laserjet 5p with a 25 pin connector to my laptop which only has USB connection
On the back of the printer where the cable connects is actually a 36 pin connector, the end going to the computer is the 25pin end. What you will need to do is get a USB to parallel cable, they run $15-25, this will have the USB plug on one end and the 36pin centronix printer connection on the other end. This cable will allow your printer to be connected to the laptop. Office Depot and Staples should have the cable you need, if not you can do a google search for it and order one online.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 26, 2010 | HP LaserJet 5p Printer
HP Laserjet 4050Tn can't be found by network computers (XP)
To install the HP as a network printer you need to do the following -
1. Configure the HP's IP address so it matches the IP range of your network. eg if your IP's are 192.168.0.xxx then set the HP to a high number say 100.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer to the network hub/router and power up the printer.
4. Click on Printers an Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standart TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP's IP address.
8. Click OK and tick Enable bidirectional support and then OK
You need to setup the HP printer the same way on every computer on your network.
You can now print from any computer on your network
Sep 02, 2009 | HP LaserJet 4050tn Printer
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
My hp laserjet 1000 doesn't turn on.
are the leds on at the front?
check the fuse inside the plug
Jan 25, 2009 | HP LaserJet 1000 Printer
Hp laserjet 4001n
The cable you need to connect to your pc is a regular parallel cable. It is called, IEEE 1284 Bi-directional Parallel Cable.
If you intend to use the a USB port this is what you need; USB to DB-25. The printer connection of the cable is the same the only diffrence here is the USB female adapter for the pc.
Nov 14, 2008 | HP LaserJet 4100n Printer
Want to connect to my computer
What connector/interface does your PC has
9-pin or 25-pin connector
If it has 9-pin connector: use the following:
DB-9 RS-232 Serial Connection
or
DB-25 RS-232 Serial Connection
If it has 25-pin connector: use the following:
DB-25 Serial Connection
or
If you are configuring the computer to use an RS-422A serial port, you need a special cable. Contact the computer or printer network manufacturer to see if an RS-422A cable is available. If no cable is available, contact your computer manufacturer for your computer pin assignments and have a cable constructed.
The default configuration for the serial port on the printer is for RS-232C serial communication. To set the printer to use RS-422A serial communication, change the control panel Serial Menu’s SERIAL setting to SERIAL=RS-422.
Oct 29, 2008 | HP LaserJet 4 plus Printer
Serial port on HP Laserjet 4M Plus
May 17, 2008 | HP LaserJet 4 plus Printer
Connection
only if your laptop has that many pins..most are 9 or 25 pin connections, in my experience..
Mar 25, 2008 | HP LaserJet 4000 Printer
HP LaserJet 4000 Printer Logo
124 people viewed this question
Seeker5211
Seeker5211
