Question about Canon PIXMA MP530 All-In-One InkJet Printer
Communication error has occurred - Canon PIXMA MP530 All-In-One InkJet Printer
  • 64 Answers
Try uninstalling and reinstalling printer software from Canon website. Pick OS version and download.
Posted on Aug 22, 2014
My ricoh aficio MP3351 machine has a error problem SC672, plz kindly tell me what i can do???
SC672 occured when controller-to-operation panel communication error at startup After powering on the machine, the communication circuit between the controller and the operation panel is not opened, or communication with controller is interrupted after a normal startup.
.Controller stalled
.Controller board installed
incorrectly
.Controller board defective
.Operation panel connector
loose or defective
Make sure that the MBU is seated correctly. If not, SC672 occurs look at the picture to see what im talking about.
Sep 29, 2017 | Ricoh Office Equipment & Supplies
Tip
Kenmore Elite, Whirlpool Duet, Maytag Epic series Error Codes
The following are common error codes, with general definitions, associated with Whirlpool Duet series, Duet Sport series, Steam series, Kenmore Elite series and Maytag Epic series FRONT LOADING washing machines. The error codes pertaining to the washer you have, will be determined by the specific model number. All error codes are listed in the technical data sheet associated with the appliance.
F/H/F20 - NO WATER DETECT ERROR. No water detected entering the machine, or the pressure switch has not tripped after 6 minutes.
F01/F14 - EEPROM ERROR. Communication problem between the Central Control Unit (CCU) and Motor Control Unit (MCU), or inability to read the EEPROM data on the CCU.
F02/F21 - LONG DRAIN. Commonly associated with a drain pump failure or clog in the drainage system. Occurs when the drain time exceeds 8 minutes.
F03 - HEATER SHORT CIRCUIT TO GROUND. Occurs if there is a short circuit to ground detect on the heater.
F05/F24 - WATER TEMPERATURE SENSOR ERROR. Associated with NTC sensor out of range or heating circuit failure.
F06/F25 - DRIVE MOTOR TACHOMETER ERROR/STEAMER DEFECT. Occurs when the motor speed cannot be detected by either the MCU or the CCU. Or, for steam models, the steamer temperature has not reached the correct value.
F07/F15 - MOTOR CONTROL UNIT ERROR. An internal failure with the Motor Control Unit has been detected by the Central Control Unit.
F09/F27 - OVERFLOW CONDITION. Occurs when the Overflow Contact on the Pressure Switch is closed for more than 60 seconds. When an overflow condition is generated, the door remains locked and the drain pump will run constantly. Pressing PAUSE/CANCEL will clear the display, but often will not shut off the pump. UNPLUG washer to service.
F10/F31 - MOTOR CONTROL UNIT HEAT SINK TRIP. Occurs when the thermal protector on the MCU gets too hot.
F11/F28 - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
F13/F30 - DISPENSER CIRCUIT ERROR. Occurs when the dispenser motor is not in the proper position.
Fdl/F22 - DOOR LOCK ERROR. Occurs when the door fails to latch after 6 attempts.
F23 - HEATER FAILURE. Occurs when the water temperature increase is less than 86 degrees F during the first 40 minutes.
F26 - DOOR SWITCH ERROR. Occurs when the door has not be opened for three consecutive cycles. Or, if the door switch remains open for more than 5 seconds while the door is locked.
Fdu/F29 - DOOR UNLOCK ERROR. Occurs when the door fails to unlock after 6 attempts.
F32 - PRESSURE SWITCH FAILURE. Occurs when no electrical supply from the CCU to the pressure switch is detected. Or, if the pressure switch contacts are worn out.
F33 - PUMP DRIVE SYSTEM ERROR. Occurs when the connection between the pump and the Central Control Unit (CCU) is lost.
F34 - UNLOAD. This failure is only for information purposes and is displayed in the error log history during diagnostics. Occurs when a load was detected in the drum during a clean cycle and the cycle had to be interrupted.
F35 - ANALOG PRESSURE SWITCH FAILURE. Occurs when there is a malfunction of the steamer component detected by the steamer electronic control board.
F42 - MOTOR CONTROL UNIT ERROR, REPETITIVE UNDERVOLTAGE. Occurs when 4 under voltage conditions are detected by the MCU during the wash cycle.
F61 - STEAMER COMMUNICATION FAILURE. Occurs when incorrect communication is detected between the CCU and steamer electronic board. Error should reset after running diagnostics.
F62 - STEAMER ELECTRONIC BOARD RELAY ERROR. Occurs when one of the steamer board relays (K1, K2, K3, K4) fails. Error should reset after running diagnostics.
F63 - TOTAL STEAMER FAILURE. Occurs when the steamer will no longer function and needs to be replaced.
F64 - STEAMER INLET VALVE FAILURE. Occurs when the steamer valve or flush valve becomes blocked. Error should reset after running diagnostics.
F65 - STEAMER TIMEOUT. Occurs when there is no communication between the CCU and Steamer Electronic Board. Error should reset after running diagnostics.
F70 - CENTRAL CONTROL UNIT (CCU) HEARTBEAT FAILURE. Occurs when no communication data is detected from the CCU to the front panel user interface.
F71 - USER INTERFACE HEARTBEAT FAILURE. Occurs in conjunction with F70 error due to no communications detected from the User Interface to the CCU.
F99 - NOT SUPPORTED. Mismatch of the User Interface and Central Control Unit (CCU). Or, corrupted EEPROM.
rL - WASH LOAD DETECTED INSIDE WASH TUB DURING CLEAN CYCLE. Detects any garments (by weight) that may be left inside the wash tub during a clean cycle. NOTE: Wash tub is to remain empty during a Clean Cycle.
Sd/SUD - SUDS LOCK ERROR. Occurs when too much detergent is used. Or, occurs in conjunction with F02/F21 error (Long Drain) due to obstructions in drain cycle.
The first step in troubleshooting any error code is to press PAUSE/CANCEL twice to clear, and verify your installation. Make sure the water inlet valves are turned on and connected correctly. If the error code remains, UNPLUG the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit. In many cases a simple CCU reset will correct any momentary glitches or erroneous errors. If the error returns following a CCU reset, a legitimate error condition exists and must be corrected in order to return the appliance to normal operation. For more specific information and troubleshooting advice on how to remedy most problems, refer to the technical data sheet.
NOTE: EACH ONE OF THESE APPLIANCES COME WITH A TECHNICAL DATA SHEET INSIDE. THIS IS THE SAME SHEET AN APPLIANCE REPAIRMAN WILL REFERENCE ON A SERVICE CALL. REFER TO THE TECH SHEET FOR MORE DETAILED TROUBLESHOOTING INFORMATION.
The tech sheet contains troubleshooting data, wiring diagrams, diagnostics procedures, component illustrations and all error code definitions.
To access, you will need to remove the lower toe panel directly below the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access to the screws (a 2x4 works well for this). With the screws removed, the panel should drop down, and come off. If the tech sheet isn't directly behind the toe panel, it will be affixed to one of the interior cabinet walls.
It is recommended that the tech sheet be placed back inside the appliance when repairs are completed in order avoid losing and to keep this pertinent info for future use.
on Apr 20, 2011 | Washing Machines
Please help me with ricoh sc 681-07 on mp 3003
Type Details (Symptom, Possible Cause, Troubleshooting Procedures)
D RFI Communication error
Communication error occurs when the RFID starts to communicate with the RFID receiver.
Retry of RFID communication fails three times after the machine has detected the RFID communication error.
Defective RFID reader and writer
Disconnected ASAP I / F
No memory chip on the toner cartridge
Noise
Replace the RFID controller board.
Replace the toner cartridge.
Still, have issues please call me at 1800-204-4427 toll-free.
Aug 29, 2017 | Ricoh Office Equipment & Supplies
Plz help sc 681 in ricoh mpc 4500
• NoiseRFID: Communication error • Communication error occurs when the RFID starts to communicate with the RFID receptor. • Retry of RFID communication fails three times after the machine has detected the RFID communication error.
The problem is Defective RFID reader and writer • Disconnected ASAP I/F • No memory chip on the toner cartridge • Noise
Mar 14, 2015 | Ricoh Aficio MPC3500
Error E 732 0001
E732-0001 Error Code: Reader Controller PCB is faulty
[ Case in the field ]
Description
E732-0001 can be displayed when a communication error occurs.
Cause
In the field, this symptom occurred because the Reader Controller PCB was faulty.
Field Remedy
1. Make sure that the connector between the host machine and the reader unit is securely fitted.
2. Make sure that the connectors on the Reader Controller PCB are securely fitted or there is no pinched cables.
3. Remove and insert the Main Controller PCB (Sub) from the Main Controller PCB (Main). If the symptom still recurs, go to the Step 4.
4. Replace the Reader Controller PCB with a new one.
E732-0001 Error Code: locks up during copying
E732-0001 can be displayed when a reader communication error occurs.
Cause
As a result of inspection, it was found that this symptom occurred because of poor soldering of J1302-34pin on the Main Controller PCB (Sub).
Field Remedy
1. Make sure that the connectors are securely fitted between J1302 on the Main Controller PCB (Sub) and J502 on the Reader Controller PCB and that
there is no pinched cable.
2. If no problem is found, replace the Main Controller PCB (Sub) with a new one.
E732-0001 Error Code: Because of poor contact of SDRAM
Description
E732-0001 indicates that a reader communication error has occurred.
Field Remedy
As a result of inspection, it was found that this symptom occurred because the SDRAM was not securely fitted on the Main Controller PCB. So, remove
and insert the SDRAM once again.
Sep 26, 2013 | Canon imageRUNNER C3200 Copier
"An error occurred during communication
As the name implies this is a DNS error. Try replacing the default DNS with IP addresses from the OpenDNS project, which supplies free DNS. Here are a couple to try: 208.67.222.222 or/and 208.67.220.220
Aug 23, 2011 | Sony Playstation 3 (PS3) Console
I have canon c2620n and when i turn it on give E 732-0001 i need help pleas
Description
Cause
Field Remedy
Cause
Field Remedy
Description
Field Remedy
Jan 31, 2011 | Canon imageRUNNER C3200 Copier
Sharp m205 error u2 Problem, what does mean?
press 0 U2 if 04 occurs EEPROM read/write error (serial communicationerror) if 11 occurs Counter check sum error (EEPROM) if 12 occurs Adjustment value check sum error (EEPROM) if 40 occurs CRUM chip communication error
Jan 11, 2011 | Sharp AR-M205 Copier
When i try to log in to my Facebook application communication error occur.....
Communication error problem are coming from your telephone provider. Call them and tell them that you are having a communication error while accessing facebook. Only your telephone provider can fix you problem. Have a good day.
Dec 01, 2010 | Nokia C3 Cell Phone
I get the message "communication error occured" on my bizhub 250
this error usually occurs when the machine fails to make any connection with the computer or any other network, for example to send an email, through smtp, or while scanning using smb, if this message appears without these above mentioned reasons then its "communication board" problem.
Dec 17, 2008 | Konica Minolta bizhub C250 All-In-One...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
60 people viewed this question
old marine
old marine
