Question about Kettler APOLLO
Kettler apollo error 1 message - Kettler APOLLO
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: I need a training manual for a kettler apollo
The Kettler Apollo Gravity System inversion table allows you to hang upside down. Inversion table proponents claim that the exercise machine aids in the relief of several ailments, most notably back pain. As with any exercise equipment, you must operate the Kettler Apollo Gravity System correctly to get the full benefit of the inversion table and to avoid injury.
  1. Pull the pin out of the Kettler Apollo frame next to the left arm and insert it into one of the six maximum inclination holes. Place the pin on the right side of the frame into the corresponding hole. The maximum inclination holes determine how far back the Kettler Apollo swings when leaning back. When pins are in the uppermost holes, the table will stop at a horizontal position. Each subsequent hole increases the backward inclination of the table. The sixth hole is the maximum inclination on the Kettler Apollo.
  2. Press down on the foot grip handle and move it forward to open the foot grip. Stand on the foot rest and rest your back against the table. Note the location of your head on the table. The top of your head should rest near the top of the table back without hanging over.
  3. Loosen the foot rest screw by hand and move the foot rest up to a higher hole if your head rests far below the top of the table or down if your head hangs over the table. Tighten the screw in the hole and check the placement of your head again until your body is in the correct position.
  4. Open the foot grip by the handle, stand on the Kettler Apollo and pull the foot grip handle toward your body. The foot grip keeps your body attached to the chair when you lean backward.
  5. Raise one of your arms slowly to change your body's center of gravity and start the table leaning backward. Lift your second arm into the air slowly if the table does not move after raising your first arm.
  6. Grip the left and right handles with your hands when leaning backward and pull up to change your center of gravity and return to the starting position.
Regards.
Posted on Jun 17, 2011
Kenapa kettler treadmill dengan error 11?
If you wish to get some details about treadmill Error codes; check the site linked here. http://electro-medical.blogspot.com/
Nov 10, 2016 | Kettler Exercise & Fitness
Kettler crosstrainer UNIX PX error e2
intl.sport.kettler.net/service.../error-messages-troubleshooting.html
https://www.kettlerusa.com/manuals
Sep 09, 2014 | Sport & Outdoor - Others
Treadmill KETTLER PACER error code E7, what I have to do?
see the next steps and fix it. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 28, 2012 | Kettler treadmill Pacer
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Windows 7 gives a error 43 and does not recognize Imation Apollo Pro UX 1 TB USB Hard Drive
Try in another machine. Does not work?
Remove the drive from the case (only if there is no more warantee) and connect the drive directly to your system to determine if the problem is the drive or the enclousure.
Sep 12, 2011 | Imation Products - imation - Apollo Pro UX...
What is the power supply for a kettler apollo exercise bike?
I have no reference for that bike but if was bought in U SA contact them @ KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email info@kettlerusa.com
Or www.kettler.co.uk Customer Services sales@kettler.co.uk
Tel: 01527 588995
AfterSales aftersales@kettler.co.uk
Tel: 01527 591901 - select Option 1
May 12, 2010 | Cycling
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Reg. Installation of Apollo P-1200 Printer on Windows XP
This driver is provided by Microsoft and is included with the Windows XP os.
Installation instructions:
1: Click START, then click on PRINTERS & FAXES
2: Click on ADD A PRINTER
3: At Welcome screen click NEXT
4: Select LOCAL PRINTER (if printer is attached directly to computer) and click NEXT
5: Choose LPT1 (in most situations) or a different port if not LPT1 then click NEXT
6: Select Apollo in left window
7: Select Apollo P-1200 in right window
8: Click NEXT
9: Type name for printer or accept default name
10: Click No to "Do you want to print test page".
11: Click FINISH
12: Test printer by sending a print job to printer.
If you experience problems after installing this driver, please consultthe printer user manual for proper lpt bios settings. eg: spp, ecp,etc. and change the lpt pc bios settings to match manufacturer'ssuggested settings. quote.gif Jerry K View Public Profile Send a private message to Jerry K Find all posts by Jerry K reply.gif
Mar 04, 2008 | Pitney Bowes Hewlett Packard HRK-300 Black...
Kettler APOLLO Logo
51 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
