Question about Air Purifiers
Price of a lancaster air purifier filter modle # KF15F-B
Modle # is KJ15F-B and the brand name is lancaster Air Purifier. I'm looking for a price & location to buy in Canada New Brunswick Frederiction
Cerfer39
  • 709 Answers
SOURCE: replacing uv lamp in Ecoquest air purifier
Hi FCfogl, Here's you answer. Go to the URl below for detailed instructions with pictures. http://www.airpurifierrepair.com/PageInfo.aspx?page=ReplaceUV Hope this helps
Posted on Sep 26, 2007
SOURCE: Kenmore Progressive 335
HEPA Filter Replacement Part No. 83376 and Pre-filter Replacement Part No. 83378
Posted on Feb 25, 2008
SOURCE: Panasonic F-P10HU1 Air Purifier
I found one on Google - the part number for this is the F-Y15XS. A number of small online stores have it. Good luck!
Posted on Sep 22, 2008
SOURCE: kenmore air purifier- model 85500
Power Off the unit then Press and HOLD the Off-Timer and Function buttons at the same time WHILE Powering the unit back On. The Replace Filter light will blink for 5 seconds than go out. Now you can release the the buttons.
Just to make sure everything is working fine power off and on the unit.
On a side note if you are a tight wad like me you may want to just smak the filter layers against the ground a few times to clean them and re-use them / make them last longer. When the replace fileter light comes on too often then it is time to replace the filter.
No worries ;o)
CDA
Posted on Nov 16, 2008
  • 8 Answers
SOURCE: My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
Posted on Dec 25, 2009
I cleaned purifier plate and filters and purifier still won't workon my fresh air machine
The air purifier filters which need to be washed lose their efficiency very fast and need replacement every few months . I think its time you switched to a better air purifier like this with superior filters which last longer and can be cleaned using a vacuum cleaner Premium Air Purifiers with e2f technology
Oct 22, 2014 | Air Purifiers
Alpine Air XL-15 Air Purifier - never taken out of box - won't turn on whatsoever. Plate is accurately placed and the rear filter is properly fitted.
Is the fuse in properly? Try popping it out and put it back in, also check it when it is out..just to be redundant since you did it already. push on the bottom of the filter the switch pushes in . I at pushed down my first time.
Jul 06, 2012 | Alpine Air XL-15 Air Purifier
Parts for S1697
Good luck with that.
Here is the information that I have for your air purifier. You may want to check it out.
"NOTE: THE OLD SHARPER IMAGE COMPANY IS BANKRUPT AND GONE! & THE NEW SHARPER IMAGE NAME COMPANY OWNERS WILL NOT WARRANTY, FIX OR REPAIR YOUR OLD IONIC BREEZE AIR PURIFIER!"
Source: http://www.aircleaners.com/sharperimage.phtml
"Ionic Breeze Suit Drives Sharper Image into Bankruptcy"
Source: http://www.consumeraffairs.com/news04/2008/02/sharper_image.html
Jan 08, 2012 | Sharper Image Ionic Breeze 3.0 Air...
I am not sure when or how to change the filter for my ecoquest air purifier. I moved into a house with brand new carpets, floors, paint etc. and then had a flood. I was running the purifier fairly...
If you have a HEPA filter, it may need cleaning. Every month at least. If you figured you don't NEED one because of the machines abilities to knock down particulates, you're most likely right. HEPA "filters" tend to grow their OWN nasties after a short time with ANY moisture around at all. The plate may have VOC's crystallizing on the plate. Check the lint screen and if it doesn't smell bad(musty) and you can see light thru it when you hold it up to a light, it's probably only needing a vacuuming. Some people rinse them in warm soapy water. Make sure it's DRY before putting it back in.
Jun 13, 2011 | Ecoquest Fresh Air Air Purifier
Modle ruud model ugra09ezajs issues keeps poping 3 amp fuses. A coils is clean and so is outside unit. all new bourd 2 months old
Hello,Only 2 things it could be (1 )the wire to the outside unit is shorted someware.Run a new one or locate where it is touching.OR (2) the contactor coil is SHOT replace contactor (outside unit).
Sep 21, 2010 | Aranizer HVAC-1 Air Purifier
I have a Kenmore Progressive 295 air purifier. I
Hi, are you sure about amazon?! I found your part there for 15$ (less than your budget of 25-30$). Take a look again here:
Amazon com kenmore charcoal filter. I hope this was helpful. Cheers
Jan 04, 2010 | Kenmore 295 Air Purifier
IS THIS PURIFIER REALLY WORKING IS IT a hepa or carbon filter?
Most particles in the air are neutral in charge. Meaning they have the same amount of negatively charged electrons, and positively charged protons. A common type of air purifier uses what is called corona discharge air purifier. These type of air purifier create molecules called ions. When particles pass through these air purifiers electric current makes these particle either positively charged or negatively charged. Once these "ionized" particles from the air makes contact with objects that are opposite of thier charged, they stick to them instead of lingering in the air, or they may clump with other particle untill they are too heavy and fall to the ground. Filter types air purifier are not so good since they require periodic filter replacement. These type of air purifier are usually part of the air conditioning system. The purifier picture I see are the ones i just mentioned, and they are not filter types.
Nov 25, 2009 | Sharper Image Professional Plus Ionic...
Users Manual for Kenmore HEPA Air Cleaner Model No 85244
I have an kenmore air purifier and cannot locate where to find a replacement filter or manual for it? Can you help. It is Model # D42M32957
Apr 06, 2008 | Kenmore 85244 Air Purifier
Hi, filters can be found at amazon, click here and take a look: 1 HEPA Kenmore Air Purifier Filter Fits Kenmore models 83200 83202... I hope this was helpful. Cheers
Jan 18, 2008 | Kenmore 335 CADR Air Purifier
Air Purifiers Logo
94 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
