Question about Dryers
Belt and pully layout for 1991 - Dryers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Are you looking for a diagram for the belt and pulleys?
Posted on Jan 22, 2013
Replacing serpentine belt 91 stealth non turbo 3.0
take picture of how the belt runs over and around
the belt driven parts first
or have the correct layout diagram
find the tension pully
pivot it in the right direction
that take the tension off the old belt
and belt will fall away
fitting...its a bit tougher becasue its a new belt
pivot the tensior pully all the way to its max so th enew serp belt will fit
may not bee the same layout but is the 93 stealth
serp belt
May 29, 2016 | Cars & Trucks
Greetings for All I need Peugeot 405 Alternator/Power Steering Drive Belt diagram
a serp belt layout is what you require
is this your vehicles engine... if so
the tensioner needs to be moved and held so you can get the belt on
Apr 29, 2016 | Peugeot Cars & Trucks
One of my pullys broke last night. Im trying to find a layout of my pullies so i can figure out which pully broke.
Both Gates and Dayton have good diagrams on their websites that show belt routing, but you'll need to know the engine information for your car. www.gates.com, and then use the parts locator. You need to click on the photo icon next to the serpentine belt listing. Best Regards, SJV
Jan 31, 2011 | 2000 Chevrolet Cavalier
I have a Toro 13-38HXL riding mower model:28m707.The belt on the deck slipped off the pullies. I need to replace belt but do not know what size or the layout of how the belt is suppose to ride thru the...
go to www.jackssmallengine.com, it has a great parts look-up database, I have the same mower, I know that is called a "v-belt", not sure where you live but this will at least give you a manufacturer's part # so you can find it locally easier. This site also gives you an exploded diagram so you will see how the belt is routed on the deck assembly.
Jul 19, 2010 | Garden
Diagram of pullies and belts on 86 toyota mr2
If you are talking the a/c pulley and alternator pulley, I am pretty sure the belts are different sizes (different number of ribs in the belt). So, you can just look carefully at the ribs and put the right belt on the right pully. from memory, the A/C belt goes on first and all the pullies towards the front of the car are used for that belt. The Alternator belt goes on next, and all the pullies from the crank shaft toward the back of the car (from the crank pulley) go to that. I could have those reversed, but the ribs on the belt will show you for sure. have fun!
Mar 06, 2010 | 1986 Toyota MR2
Need to know the layout of the drive belt so it can be replaced
depending on your mower (assuming it's a garden tractor) usually there is a belt from the motor to the transmission with a tension pully and then a seperate belt from the motor to the deck with either an electric engage pully or a manual tensenior.
Oct 05, 2009 | Garden
How doe's the fan belt go around pully wheels on a Lreg merc c180 thanks
Tricky one...... however serpentine belts always double back on them selves to maximise friction and taughtness, as a rule these go round the pullies and the double back to go around the tensioner. Try placing them around the pullies and the pulling the belt between them towards the tensioner!
Sep 13, 2009 | 1991 Mercedes-Benz Mercedes Benz C Class
1991 mazda mvp
Yes, the front pully is the belt drive and that must come off to get to seal. The radiator has to come out to take the pully off. The pully should come off easily once retaining bolt is removed. It can only go back on one way. Goood luck
May 20, 2009 | 1991 Mazda MPV
Cant put on belt right
from front of engine looking back,belt around bottom of crank pully,water pump is just above,left side of belt comes around water pump going counter clock wise,put belt over alternator,then straight across to a/c compressor,(make sure belt goes under any idler pullies,smooth side of belt to smooth side of pully)find your belt tensioner,pry back on tensioner(be carefull)and carefully place belt under roller pully of the tensioner,release and check allignment of belt prior to starting.oh ya make sure belt is in good condition.
Mar 01, 2009 | 1991 Chevrolet C1500
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
