Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Does not want to slide in
It had been working fine. Then it didn't want to open. I gently insisted, and now it doesn't want to close. I don't want to force it. How do you remove the drawer to inspect the tracks?
  • Lee Ensminger Jan 23, 2013
    Figured out the solution to the problem. Turns out the top of the dish drawer clamps down when it is in use. It had not released for some reason. Running the unit through its 12 min. rinse cycle caused it to raise the lid again, freeing the drawer. Has worked perfectly ever since. Thanks to everyone who looked at my problem, though!
  • Fisher and P... Master
  • 3,247 Answers
I am a bit surprised it worked through 12 min cycle without drawer fully closed. If you had to force drawer to close position then I would suggest you inspect the lid seal for damage. It can cause leakage in future and shutdown dishwasher.
Posted on Jan 27, 2013
  • Lee Ensminger Jan 27, 2013
    Sam, thank you for responding. Indeed, I did slowly force it to close before running the 12 min. cycle. We've run several wash cycles since and not noticed any leakage, but I will take your advice and try to use a mirror to inspect the top seal. Can the drawer be taken off of the track to facilitate this? I tried lifting it like a file cabinet drawer to remove it and wasn't successful. I didn't insist. I did move the drawer very slowly when the top was down, and only did it one, so I'm hoping I got away with it without damaging the seal. Time, and a mirror inspection will tell. Thanks for your help! -Lee
  • Sam Jan 27, 2013
    It is quite easy to take the drawer out, but a bit complicated to put in back in. Take photos of the process as you go along. See instructions on this pagehttp://www.scribd.com/doc/14173354/Fishe... Make sure you do not drop the drawer when you slide it off the rails. The hoses and wiring at the base are very tight and delicately placed. Rest it on a stool or short drawer from filing cabinet underneath. Good luck.
  • 3247 Answers
SOURCE: I have a fisher & paykel dishwasher. It has 2
The lid seal of the top drawer is broken or has come off. To get to it you will have to take the two drawers out carefully along with the cables and hoses intact.
Then feel the top underside of the cabinet for the lid seal. Depending on the problem it will have to be replaced. There is an intricate mechanism of actuator arms and motors that drive it. I hope these are ok.
If you are lucky maybe the drawer has just come off the rails and you could put it back and it will be ok.
Please rate this solution if helpful otherwise drop a comment
Posted on Aug 16, 2010
Master_Tech
  • 770 Answers
SOURCE: How to delete User fault codes
yes what is your email so i can send you the tep by step
Posted on Aug 03, 2008
  • 19 Answers
SOURCE: top drawer seems to off track, tough to close, etc
check to see if wheel rollers are broken . Or off track . Then if off track allign it .
Posted on Aug 18, 2009
  • 2926 Answers
SOURCE: top drawer of 2 drawer
Hi,aside from any obstruction is thet DishDrawer® square and level?. Is the DishDrawer® fastened securely to the cabinetry to prevent flex or movement? If not, the square geometry this appliance requires with affect drawer performance when opening and closing.
This is the most common cause for your problem. I'm not 100% sure, but it is something to take into consideration. Just a thought.
Posted on Feb 11, 2010
  • 3247 Answers
SOURCE: I have a F & P Double Drawer. The top drawer
If none of the lights on the top drawer are on and it is not responding to the switches then the controller has lost power. This in turn has caused the lid seal motors to freeze and hence the reason why the drawer movement is stiff.
Controller power is lost if the thermal fuse located in the heater assembly is blown. This is a safety mechanism to protect the dishwasher if the temperature goes too high. Sometimes it can also mean the thermostat became faulty causing the heater to overheat.
In order to restore the controller power the heater assembly needs to be replaced as the thermal fuse is integral to it. This part looks like this.
Once the power is restored to the controller then it will pull the lid motors back unless these are out of position which means the seal has to be opened and the motors repositioned.
Let me know if you want to fix this yourself or call the technician. I can give you some idea of how to access the heater assembly etc but it is not a trivial task to replace. The drawer is very compact and requires a fair bit of effort and patience to repair
Posted on Oct 05, 2010
The driver window doesn't slide down slightly when I open the door and close it ! Now the window bangs on the door frame when I close the door!
have you tried resetting the windows by powering them all the way down and keeping switched pressed the same all the way up. or could be microswitch in door latch
Mar 16, 2013 | 2005 Aston Martin DB9
My rexel stapler does not work, any help[
When you lift up the top of the stapler (as though you are going to put staples in), does the pusher slide freely back and forth? It might be getting stuck at some point and not pushing the staples (either due to a worn pusher spring, or friction). First (after removing the staples) try spraying some light oil on the mechanism and lifting the top part of the stapler up and down a few times and observe how easily it moves back and forth. Also, with the top open try GENTLY sliding back and forth a little - if it slides fine with no sticking, try loading staples and using stapler. If it slides ok, but doesn't quickly return to it's "normal position" when pulled so as to put tension on the spring, rhen the spring may be worn and need replacing.
Sep 11, 2012 | Office Equipment & Supplies
My projector will not show the slide.Everything else seems to be working.
I'm assuming the lamp is lit, the light is just not coming through the optics. You didn't specify the model, but most later manufactured Kodak projectors have a "dark shutter". This feature keeps the blinding light off the screen when you arrive at a spot in your slide tray without a slide in it. It senses a slide dropping into the slide gate, and pops the shutter open. Otherwise the shutter stays closed.
One of 2 things has happened:
1. The spring that "pops" the shutter open has fallen off.
2. The "dark shutter" latch needs adjusting.
You can find the Kodak Service Manuals that will give you instructions for adjustment and or replacing the spring at:
http://resources.kodak.com/support/pdf/en/manuals/slideProj/carousel_ServiceManual.pdf
Good Luck!!
Jim
Aug 13, 2012 | Office Equipment & Supplies
Need to use lock pick to open my 2005 gmc drivers door show directions, key isn't working
hose the lock with some oil or wd40 like stuff and work the key in it. should come free.. dont break the dang key in it!!
Mar 06, 2018 | 2005 GMC Sierra 1500HD
Interior fan want work
First, check the fuse block for an open / blown fuse. You didn't provide the make & model of your car, so you'll have to find out which fuse is used for the fan. Replace any open / blown fuse found with the correct size as determined by the manual. If it still doesn't work, keep reading:
Many cars and trucks use what is called a "resistor pack" that is used to determine various preset speeds for the heater & A/C blower or fan. When you switch the fan from one speed or another, power is passed through a different value of the resistor - which changes the voltage to the fan motor. The different voltages provides different speeds.
The resistor pack is usually the problem if the fan works at one or more - but not all speeds. It can be the problem if the fan doesn't work at all either. The location of the resistor pack varies with vehicle make and model, but is often very close to the motor itself and accessible from the passenger compartment. Consulting with a employee at an auto parts store or Chilton's (or similar) auto repair manual should get you to the right spot. Resistor packs are relatively inexpensive at about $25 or less.
I hope this helps & good luck!
Mar 25, 2012 | Cars & Trucks
My 2004 tiburon moonroof is stuck doesn't open or close i can hear the motor going but the moonroof just doesn't move at all, first it was closing all the way down but was making a funny noise as...
In order to find out what's causing the problem, the headliner must be dropped (removed) to access the sunroof motor so it can be inspected and removed to inspect the slide cables up inside the sunroof/moonroof assy. Until that's done, there's not much more I can do to help except speculate.
Aug 29, 2011 | Hyundai Tiburon Cars & Trucks
I drive Daihatsu 2007 Terios and it seem my A/C doesn't blow as it use to. I didn't clean any cabin filter for 3 years. Is there a filter? where it is?
In cabin air filters are usually located in the rear of the glovebox look for a small door or cover that can be opened to access it
Jul 23, 2011 | Daihatsu Rocky Cars & Trucks
My 1994 ultra classic shifts ok but the bike wont go over 35 mph.
Take the air filter off but leave the backing plate on. Start the engine and rev it up a bit while watching the slide inside the carb. It should move up and back down when you rev the engine. Now, don't rev it so high as to blow the engine up just up to about three thousand RPM or so. Don't get your face too close to the carb. If the slide doesn't move up and down, you've probably got a hole in the diaphragm that controls the movement of the slide. That's my best guess since you didn't say it was running badly just wouldn't run over 35 miles per hour.
Good luck
Steve
Jun 05, 2011 | Harley Davidson Bullet 125 Motorcycles
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
110 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
