Question about Kitchen Ranges
Kenmore oven temperature is incorrect - Kitchen Ranges
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
What is the make and model number of your unit?
Posted on Jan 21, 2013
  • 3 more comments
  • Robert Daley Jan 21, 2013
    richard, i have an odd situation. the manual that came with the range shows models 665.75822, 665.75824 and 665.75829. however, the model number tagged the range says 665.5002101.
    i should have added. the wife put an oven thermometer in the oven and it measured 15 degrees less than set temp
  • Richard Roth
    Richard Roth Jan 21, 2013
    You will need to replace the temperature probe. Here is the part to order.http://bit.ly/10N6LbC There is also a video on that parts page to show you how to replace the probe. Keep me posted!
  • Robert Daley Jan 28, 2013
    Richard, you were absolutly correct. Got the sensor, installed it and wife says temp is spot-on now. Thank you for th assistance.
  • Richard Roth
    Richard Roth Jan 28, 2013
    I am glad I could help you. Thanks for using FixYa!
Kenmore electric range 911.95575. What part controls the oven temperature
It's a "joint venture" between the electronic oven control and the temperature sensor (temperature probe) located inside the oven cavity.
Jan 26, 2015 | Kenmore Kitchen Ranges
Why will my kenmore oven only heat to 212 degrees after 2 houres?
Why is the oven temperature incorrect?
The oven temperature control is usually controlled by a thermostat that uses a capillary and liquid filled bulb. When the bulb's liquid gets heated up, it expands and puts pressure on a diaphragm which opens and closes a switch that controls the gas to the burner. Just set the dial to what you need the temperature to be. Over time, it is possible for your thermostat to lose its calibration. Sometimes, the thermostat sensing bulb comes loose from the holder. If it is out of place, the thermostat may be getting faulty readings. If this is the problem, re-aligning the bulb properly will take care of this problem.
Digital display models use a sensor to control temperature. If this is faulty, replace it. Other ovens use a mechanical system to control the temperature.
On many models, you can adjust your oven thermostat using a small screwdriver. The adjusting screw is located on the thermostat valve stem. Remove the knob and you'll see the screw underneath it. You want to turn the oven on and run it through at least two cycles while watching a calibrating thermometer in the oven for high and low temperatures. Adjust the screw as necessary to fine tune the temperature.
Some models don't have an adjustable thermostat, and you will have to replace the thermostat if you want to resolve the problem.
May 28, 2014 | Kenmore Ovens
I have a Kenmore Gas Range Model 665.72012102. It has never baked correctly despite that I purchased brand new. The past couple of years the amount of time needed to pre-heat is up to approx. 25 minut
That is a long time to heat up. I would check to make sure both your broil and bake ignitors are working. On some, but not all, both come on to preheat, and then the broil shuts off. Another, and more likely culprit would be the temperature sensor located in the oven itself. Its the silverish metal rod protruding from the back wall inside the oven. It could be bad and not converting heat/elsectrical signal properly causing the main control to regulate the temperature incorrectly.
Apr 24, 2012 | Kenmore Kitchen Ranges
What does error E1 F3 mean kenmore range oven
Hi....F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Apr 12, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Display on kenmore electric double oven flashes F3 soon after setting temperature and oven turns off
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%%
Jul 19, 2010 | Kenmore 41389 Electric Double Oven
Kenmore oven showing an F3 and later F5
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven model 665, oven temperature goes up
need to check oven sensor probe located inside of oven will be in left or right hand corner. the tech sheet should still be on the back panel of oven it will have instructions how too...
Sep 30, 2009 | Kenmore Kitchen Ranges
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
F 10 code when I try using oven
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Please rate and have a great day:)
May 18, 2009 | Kenmore Ovens
Digital oven temperate is wrong
Yes, that is the probe that sends info to the controller.
If it's not bad, then the controller is, but normally it's the probe.
Check that the controller has not been incorrectly calibrated before you change the probe out, although most do not allow a swing of more than 15-20 degrees. Yours may allow more though.
I am guessing you measured the actual temperature, to the set point temperature, with a know good thermometer.
Jan 30, 2009 | Frigidaire FGB24S5A Gas Single Oven
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
