Question about Zanussi FJ1254W Front Load Washer
I have a Zanussi fj1254 w. It was making a high pitched squeel when it was spinning. No when I turn it on water goes in but the drum does not turn. It turns freely when rotated by hand. i have checked the belt and that is fine.
  • Zanussi Master
  • 17,129 Answers
Possible that the drive output to the drum is not there and so there is no voltage when the cycle come to the spin mode.
Check for fault in the drive, capacitor to the motor.
Posted on Jan 22, 2013
  • 38 Answers
SOURCE: Zanussi IZ12 Washer won't spin.
check the motor carbons they r mounted on either side of the armiture you will find they r held on the motor with 2 screws or 2 5.5mm nuts make sure you unplug the machine before u start working on it good luck
Posted on Jul 24, 2007
  • 101 Answers
SOURCE: zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Posted on Apr 23, 2008
SOURCE: zanussi washing machine drum will not go round at all
i had a similar problem with a zanussi machine
a cheap bracelet got washed with some clothes and it found its way into the drum housing jamming the drum.
it may have been cheap to fix, but i just got rid of it cos it was 4 years old anyway
i now have a zanussi ZWF1231W just past its 1 wear warranty that has just died completely except for an "on indicator light"
the store inform me that i will have to pay the zanussi engineer a Euro 90 call out charge, plus labour costs, plus parts if needed.
im a little bit disappointed with zanussi to say the least
  • 22 Answers
SOURCE: zanussi aquacycle 1200 drum not turning
is the belt ok?
Posted on Nov 13, 2008
BIKER T
  • 909 Answers
SOURCE: Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Posted on Sep 20, 2009
Noisy squeel when simpson ezeset 550 washer is spin drying
You need to determine if it is the drain pump or not, these can squeal when pumping due to wear inside, if it is not coming from the pump then it could be either the belt or worse case it is the drum seal. It's just a matter of pinpointing the noise
Mar 10, 2012 | Washing Machines
Zanussi zwf 1221 will not turn drum, the end light flashes the water goes into the drum and drains out when a program is selected but the drum will not turn at all. You can turn it by hand and it moves...
you need to check the pressure switch inside the washing machine there a small hose connected with the pressure switch to sense that the level of water inside the drum is ok if this hose blocked the machine will not run
Oct 10, 2011 | Zanussi ZWF1430W Front Load Washer
Turns on, fills with water, but then won't spin and makes a high pitch squeel. Belt maybe?
While the belt IS a possibility, you should check to make sure that the drum is not out of balance or that it is wedged somehow.
When the drum is empty, try to manually turn the drum. You should only being turning the resistance of the motor and belt; and the internal working of the tub, so it should turn under some pressure. BUT don't put excessive force into trying to turn it! If it doesn't turn with moderate pressure then something has come loose and wedged the mechanism. Which means that the drum system would need disassembled and repaired.
Jun 25, 2011 | GE WCVH6260FWW
High pitched squeel
Squealing is a bad wash motor- it will need replacing. Nothing is blocked here.
Jun 05, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Wash. machine not agitating & high pitched squeel
Yep
A drive belt and when you replace it lube the gearing as well to keep them from seizing or grinding.
Jul 27, 2009 | Washing Machines
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Washing maching
replace the motor coupler...you have to remove the case and then the water pump, then the motor....the coupler in behind the motor
Sep 16, 2008 | KitchenAid KAWS850L Top Load Washer
Zanussi washing machine wont spin
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi FJ1254W Front Load Washer Logo
52 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
