Question about Garden
How do I remove the wires from the old TRIGGER SWITCH for a REMINGTON Polesaw #077525S to install the new switch
burzerko
  • 254 Answers
SOURCE: Remington 10 Polesaw
S.A.E. non detergent 30 or chainsaw bar oil.
Hope this helps You
please rate me
Posted on Jul 24, 2008
rowdy45176
  • 2176 Answers
SOURCE: DW272 switch wiring
I would go to the mfr's website and download or look at the wiring breakdown. All these companies have breakdowns online
Posted on Dec 16, 2008
motor1258
  • 6674 Answers
SOURCE: 2001 chevy cavalier door contact switch install
If no screws or nuts holding it that you can see from outside, then just use a screwdriver or something and pry at the base where it is against metal.
Posted on Jan 04, 2009
RCtech
  • 55 Answers
SOURCE: how do i install a combination toggle & outlet
If I understand you question (if not please clarify) you have a switch and outlet combo and you have a box with a black and white coming in one side and a black and white going out the other side. Here's the deal the switch side only deals with the black (hot) lines but the outlet needs a common (white) line so there should be two brass posts the black coming in goes to the bottom brass post and the black going out to the light goes to the top. You should now have two silver posts and these take the white lines they are common to each other (electrically speaking that means they are two ends of the same wire to put it simply) In the event you only have one silver post tie both whites to that one. if this was a switch box the two whites would be tied together with a wire nut and shoved in the back.
good luck I hope this helps.
Posted on Mar 28, 2009
SOURCE: Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
Posted on May 27, 2009
077525s switch with lock down button does the button have threads
No it does not - it just snaps in. If you are replacing a blown switch and need to re-use the button, drill out the rivet on old switch that holds the switch body together, and tear it apart - you can then use a small punch or a filed-flat nail to punch out the button from the back side. That is what I did. I also read that you can carefully lever it loose with a large screwdriver.
Jul 10, 2014 | Remington Electric Pole Saw
How do you replace the trigger switch? I have a new one and have taken the saw apart but am having problems with how to attach the new switch wires.
I have not disassembled my Remington Pole saw but mine has a two-wire circuit (no ground) so it should not make any difference which wire is connected to which post. Preferably, though, you should match wire colors. There should be some kind of connector block linking the trigger switch to the incoming power wire and the wire that runs to the saw motor. Attaching the new wires should simply be a process of reversing the procedure you used to remove the original trigger switch. If you cut the wires to remove the old switch, hopefully, you left enough wire end to strip them and solder the end of the new switch to the old wire.
Oct 25, 2013 | Remington Electric Pole Saw
Took remington branch wizard out of box and it will not work
It could be a broken power cord, defective switch, or motor brush damage. Remington saws have gone out of business, so no warranty anyway. Procuring parts for these things is a hit or miss proposition at best--good luck!
May 29, 2010 | Remington Polesaw Wizard
My electric remington pole saw seems to have no power. Just had a new chain put on it but when I went to use I get no vibration or movement of any kind...just plain dead. Don't seem to have any places in...
Did you try a different outlet (circuit breaker) and extension cord? if those are good logical choices are brushes (NLA) or field windings (also NLA on most models) Remington is no longer in production and odds are very good replacement parts would not be available even if you found a repair shop. Sorry.
May I recommend a name brand replacement? Someone you expect to be in business for the next ten years. Often additional cost is defrayed by many fewer replacement parts over the life of the product.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 28, 2010 | Remington Polesaw Wizard
Broken trigger in botton handle , need parts
Part number is 077525s . You can order at 1-800-654-8534
Oct 01, 2009 | Remington Polesaw Wizard
Need a trigger switch
The part you need is a 077525S. Call Master Parts they have that part available. You can reach them toll free at 800-446-1446 or online at www.masterparts.net. I hope this helps!
Jul 12, 2009 | Remington Electric Pole Saw
Our new Pole Saw, (6 mo old, used 2 times) just stopped working. Not outlet or electrical connection to pole saw. It is a 10" Remington Pole Saw...
Check in the handle, the wire connection to the electrical switch could have came loose or disconnected. The switch may need to be replaced. Maybe part of the cord went bad, but I would think that would be less likely, but possible if you had a electrical surge.
If the wire connection is okay, then I suggest you try to purchase a new switch part # 077525S, that may do the trick. You can by one by calling Master Distributors at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Jul 10, 2009 | Remington Polesaw Wizard
Old saw model #100089-04 needs new switch
The part number you need is 077525S. Call Master Parts at 800-446-1446, they have the part available. You also can find them online at www.masterparts.net. I hope this helps!
Jul 09, 2009 | Remington Garden
Getting it started
There is probably another little button near the trigger that you also need to push in order to pull the trigger. Kinda like having to push on the brake before shifting out of park.
Jul 14, 2008 | Remington Polesaw Wizard
Remington Pole Saw
LOOK UP ( PARTS FOR.COM ) FOR THE TRIGGER SWITCH
Jul 04, 2008 | Remington Polesaw Wizard
Garden Logo
208 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
