Where can i get ac powercord
Origenol too loose
    New Friend:
    Problem Solver:
  • 9 Answers
Try tigerdirect.com
Posted on Jan 21, 2013
It doesn't turn on, with or without the powercord.
Try removing the battery and unplugging the AC. Press the power button ON for 30 seconds. Re attach the battery and plug in the AC adapter, then power ON as normal.
Oct 22, 2010 | Acer Aspire 5315-2153 Notebook
I have a old tube cb base station gemtronics 5000gtx i found in trash years ago its missing the ac powercord but has the round plug that a powercord would be soldered onto was wondering how you would...
Hi, my name is John. The older tube type radios usually ran (ac) base or (dc) mobile, and would probably need a lot of work done to it to restore it, such as capacitors, they leak and no longer any good. You could be investing a lot of money in it. If you need further, I will be glad to help, I will post it here. Good luck... Hope this was very helpful..rate this solution on the 4 thumbs-up......John
Sep 06, 2010 | Radio Communications
Dear Sir/Mada, i have laptop Acer Aspire 2000. that laptop lcd is dark. i did not display screen.
  1. Check ur powercord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Aug 20, 2010 | Computers & Internet
My Eee PC 4G Surf wont power on what do i do
follow the steps:
1. check ur powercord & adapter.
2. if its working then check the battery, reseat the battery & check.
3. if available then check with another battery
4. if no, then remove the battery & switch on the PC in AC mode.
5. check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. if indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
ALL THE BEST
Aug 17, 2010 | ASUS Eee 4G Notebook
Latitude E6400 - power charging problem. Power button is not blinking and laptop is not booting up
follow the steps:
ALL THE BEST
Aug 17, 2010 | Dell Inspiron 5100 Notebook
W350i (T-6836) No machine boot or boot-up
it seems capacitor blown up.
follow the steps:
ALL THE BEST
Aug 17, 2010 | Gateway T-6836 Notebook
I plug in the powercord and the monitor of my
It sounds like the backlight inverter board has gone out, or the cable connector came loose fromt the inverter board, see example of laptop inverter board replacement guide: www.insidemylaptop.com
Mar 26, 2010 | AOC LM729 17" LCD Monitor
HP Pavillion HDX 9000- No Power I was using the laptop when suddenly I got a message saying I had mimimal battery power and I needed to plug in my AC power. But the AC power supply was already plugged in....
Sandytoo,
Sometimes the AC port on the motherboard can become loose or disconnected and will cause the powercord to not charge to the batteries or run power to the motherboard. If you changed out the Power adapter and that didn't help, then this would be my best assumption. The AC connection on the motherboard can be replaced pretty easy by someone knowledgable in motherboard repair with sodering. Most of the time with this issue, a motherboard replacement is not required, Even though its alot easier to just replace the board. Most Repair places will probably talk you into replacing the board, even though its really not necessary, with this issue.
Sep 22, 2009 | HP Pavilion dv9000z Notebook
Problem with booting my A205-S4577 with the powercord on
Have you tried a new power AC/DC convertor ? make sure you have the correct spec...see manual for power adaptor needed. Cost less if you can get a loan of one. other than this i would be looking into checking the power jack. hope this helps
Feb 15, 2009 | Toshiba Satellite A205-S4617 Notebook
PS2 problems
if it turns completely off without any indication of power LED then there is something loose connection in your powerboard or mains powercord is loose fitted.
Aug 11, 2007 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
