Question about Craftsman 3/8 in. Drill Press Bit, Mortising Chisel
Need the best bit for drilling through books without tearing internal pages
We are marking all of the books that are being moved into our honor system library by drilling a 3/8" hole in the upper left corner on a drill press. What is the best bit to use?
  • The Mission Library
    The Mission Library Jan 23, 2013
    Here's the solution I found, and it's working well.
    I used a DeWalt 5/16" "Brad Point" Drill bit (DW1708).
    The sharp point starts the hole without twisting paper and the steep groove pulls paper out rapidly.
    I periodically lubricate the bit with beeswax, wiping it clean before drilling again. Beeswax does not foul the pages like an oil might.
  • 843 Answers
If you use a brad point bit or forstner bit or any bit that cuts around the circumference of the hole, you will create a disc of paper (several pages thick) that will spin at the bottom of the hole and impede your drilling, so those are out. If you use a standard twist drill you get a very rough hole and the pages tend to lift up. The simplest and cheapest is a standard twist drill but with scraps wood above and below the book, clamping the book tight. You might try a plug cutter that has an exit hole for the little discs of paper. Or, use a paper drill bit, these are about $40 and I have never tried one.
Posted on Jan 27, 2013
    The Mission Library Jan 30, 2013
    This is an excellent answer. BTW a paper drill bit requires a special drill press that allows the scrap to come up through the center of the chuck.
rowdy45176
  • 2176 Answers
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Posted on Oct 08, 2009
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
rowdy45176
  • 2176 Answers
SOURCE: Craftsman Drill Press chuck problem
It is unless there is a tang on the end. What you need to do is thoroughly clean the parts with something like brake clean to remove all the oil and then wipe with a clean paper towel. What I do it put the arbor into the drill press or the chuck onto the arbor and then put a 2x4 on the table and press the parts together or if you have enough room fully retract the jaws and use the block of wood to "tap" the parts to seat them. Let me know if you need more assistance
Posted on Aug 25, 2009
Testimonial: "Thanks rowdy45176. Your solution was spot-on. I cleaned both sides and them , with the chuck jaws fully retracted, tapped it with a plastic mallet"
rowdy45176
  • 2176 Answers
SOURCE: How do you correct excessive drill wobble on a
First you have to determine if it is the spindle or the chuck assembly. I would go to ereplacementparts.com and look at a breakdown for this tool so you know what the parts look like and then go from there. I couldn't find the schematic on the Ryobi site.
Posted on Sep 19, 2009
SOURCE: Manual for 1950 Craftsman Drill Press
Not sure if you ever found the manual for this model number. I just picked one up at a garage sale last weekend and it actualy had the manual with it. Doesn't really go into any overhaul of the machine, but does have a exploded view of the parts.b329678.jpg
Posted on Jul 21, 2010
I have tried to turn the camshaft on a 2004 Suzuki Forenza to the timing mark but it would not line up it would not turn anymore what should I do
Not knowing how far your cam timing is off, your valves may be hitting the top one of a pistons. That may be why cam wont turn anymore.
May be best to back up the cam a bit, remove the spark plugs & with screw driver or wooden dowel probe the cylinders to see which piston is near the top.
Then rotate crank a bit to lower piston down the cylinders DO NOT USE STARTER to rotate engine while timing belt is off or valve damage may occur.
Jul 16, 2016 | 2004 Suzuki Forenza
How do I separate book pages stuck together without damaging the pages?
Just dampen the pages where the stain is and they will separate easily.
Sep 16, 2014 | Coffee Makers & Espresso Machines
I am trying to drill through old encyclopedias, but the drill bits keep snapping in the pages. What type of drill bit can I put on an hand-held drill that will get through the books without breaking?
rx-dk-diy054036_wood-drill-bits_s4x3_lg.jpgI've used 'regular' high speed drill bits for paper, and wood boring bits. I think the wood bits work better, but whatever bit is used the drill flutes have to be cleared out of material. This is done by drilling a little bit at a time and then lifting the drill out of the hole to clear the hole and the drill of shavings. This is essential to do to minimize heat buildup and binding of the drill bit. The drill bit should not break if you take it nice and easy, and drill in small increments .
Dec 17, 2013 | Hinge European Drilling Tool 35mm Cup ...
How do i use a spade bit?
I'm assuming you mean a spade drill bit?
For best results, try clamping a block of hardwood to the back side of the stock before drilling. When the bit approaches the end of the cut, it will be far less likely to blow through with another piece of wood to drill. However, if the stock placed on the back side is softer than the workpiece, or if it is not securely clamped to the workpiece, tear out can still occur.
To use a spade drill bit, mark the center point of the hole to be drilled on the wood, and install the shank of the bit into the drill. Align the point of the pilot tip of the spade drill bit with the mark on the wood, and adjust the angle of the handheld drill so that the shank of the bit is square to the surface of the wood. (Of course, if you're using a drill press, the bit's angle should already be square to the surface of the wood, unless your drill table is not square to the motor).
Depress the trigger of your drill slightly to engage the motor and turn the bit slowly. Hold the drill as still as possible so that the pilot point stays aligned with the mark on the wood. Because pilot tips can often "walk" away from the intended center point of the hole, some woodworkers will pre-drill the pilot hole using a small-diameter twist drill bit that is less likely to walk, and then proceed with the spade drill bit's pilot tip into the pre-drilled pilot hole.
Once the pilot tip is in place and engaged with the wood, increase the speed and proceed to drill the large diameter hole with the spade drill bit. Continue drilling until you reach the opposite side of the wood and the bit pokes out through the completed hole. Slow the speed of the motor, and pull the drill bit out of the completed hole.
For more details, check out my source: (link)
Mar 23, 2013 | YouTube Videos
Internal phone storage space nearly full
How to Transfer Apps Pictures From Internal Storage to Micro SD Card...
The above page shows a method to move files to an SD card without you having to install an app. That should free up space. There are apps that can assist with this process but you may be so short of space that you need to move some with the above method (before you can even install another app). Note that you can actually move applications to a SD card as well as photos or books or music. Some versions of operating systems restrict access to SD cards. If you experience a difficulty, you may want to access the help and support for your particular phone model and operating system version. Check for that on the brand site.
If you find this helpful, please tick the helpful box.
Oct 10, 2017 | Samsung Cell Phones
What internal mechanism cause a cordless drill to switch from forward to rever
It is usually controlled by a lever that moves a piece on the top of the switch. Without knowing a brand and model number that is the best guess I can give you.
Jul 26, 2012 | Drills
We are concernened about screwing the tub into the floor for stability. We have to go through tile and into wood. There are no instructions included for this. Included were 5/16 lag bolt and feet but we do...
The main reason to screw the feet to the floor is to keep the tub from moving which could cause the pipes to leak (either the supply or the drain) Authentic old clawfoot cast iron tubs were usually bolted to the floor because they were so heavy that it took a significant effort to move them, especially on a wood floor. If your tub is light enough that you could move it without a pretty significant push, then you had best bolt it to the floor in at least two places. Drilling holes through tile can be intimidating, but it's not as hard as you might think using an inexpensive masonry drill bit and a carbide tipped scratch awl. I will leave it to you to figure out how to assemble the claw feet to the tub, but here are a couple of important tips for drilling the holes through tile: Mark the hole locations with a felt-tip marker. Then use the carbide tipped scratch awl to gouge a starter divot in the tile. This divot can be pretty small, but it's essential for being able to drill a hole in tile in the right place. Use a variable-speed drill at fairly low speed to drill the hole - don't use a hammer-drill. Also keep a puddle of water where you are drilling to prevent the tile from heating up in one spot and causing the tile to crack. Once you get the hole through to the wood below, switch to a regular drill bit of a smaller size. Good luck, Al K
Aug 24, 2010 | American Standard Reminiscence...
How do I bolt down Sentry Safe S3310 to the floor?
All of the instructions can also be found at www.SentrySafeShop.com
The link is:
http://www.sentrysafeshop.com//kb_results.asp?ID=7
Required Tools:
Drill, Wrench, 7/16" (11.0mm) bit, for wood anchoring: 9/32" (7.20mm) bit, for masonry
anchoring: 3/8" (9.5Omm) masonry drill bit.
The steps are as follows:
1. Tip the safe on its right side. (Door hinges horizontal with the floor)
2. Unlock the safe and open the door.
3. Look on the bottom (outside) of the safe for two indentations in opposite corners. Using a
7/16" (11.0mm) bit, drill a hole through each indentation perpendicular to the bottom of the
safe.
4. Close the door and tip the safe upright. Place it where desired and reopen the door.
5. Use a screw or drill bit to mark the floor through both holes.
6. Move the safe aside to clear both marked spots for drilling.
7. Drill into the floor:
a. For wood:
i. Using a 9/32" (7.2mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
b. For masonry:
i. Using a 3/8" (9.50 mm) bit drill a hole 2 Y2" (64mm) deep in each marked
spot.
ii. Install a masonry anchor in each hole.
8. Replace the safe in the desired position, with the holes in the safe aligned with those in
the floor.
9. Securing the safe:
a. For wood:
i. Pass each lag screw through a washer, then through the safe and into a hole. .
ii. Tighten with a wrench. ,
b. For masonry:
masonry anchor.
Jun 27, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
I,m getting ready to mount luggage rack and saddle bag rack. what is the best way to drill the holes for mounting these racks,without cracking the paint or fiberglass?
start with the smallest drill bit possible . it is best to use three sizes in drill bits to get to the final size you need. drill slowly with less pressure than you would normally use.
May 17, 2009 | 1984 Honda GL 1200 Aspencade Gold Wing
Craftsman 3/8 in. Drill Press Bit, Mortising Chisel Logo
628 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
