Question about Kenmore 22422 Top Load Washer
Kenmore Series 90 won't spin
This machine agitates and drains fine but the tub won't spin.
I have verified that the lid switch is good. I have also replaced the motor coupling.
  • 65 Answers
AS LONG AS THE MOTOR RUNS, I WOULD CHECK THE CLUTCH RIGHT UNDER THE TUB TO SEE IF OIL HAS LEAKED INTO THE PADS CAUSING IT TO SLIP. IF NO OIL OR EXCESSIVE PAD DUST INDICATING WEAR, IT MAY BE A PROBLEM IN THE TRANSMISSION.
Posted on Jan 27, 2009
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore washer 80 series stopped draining
So it will agitate and fill but the motor won't run during drain and spin?
If so, the likely cause is a bad lid switch. The paddle that the probe hits when the lid is down moves a small switch. That switch can do two things
1. fail internally. It will look fine outside but it won't close the circuit
2. the screw holes snap and it hangs off the wires, the probe no longer hits the paddle and the switch stays open.
The lid switch is cheap and very easy to repair.
Nov 10, 2011 | Kenmore Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Washes fine, drains, will not spin
Well, it sounds like the lid interlock switch is bad. This switch keeps the machine from spinning when the lid is raised. When the switch is bad the washer thinks the lid is up.
Yes, if you have reasonable skills & experience you can fix it yourself.
Look for a hole in the rim under the lid. The switch is under that hole.
May 02, 2009 | Washing Machines
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
55 people viewed this question
Sal De
fordexpert
Robert Rankin
