Question about xheli Syma S031 Outdoor RC Helicopter
My s031 helicopter will not get off the ground.
The blades will spin fast, and it looks like it wants to go upwards, but it only gets an inch or so off the ground if its lucky. Why wont it fly upwards?
5 Suggested Answers
  • 4 Answers
SOURCE: LOOKING FOR A BATTERY FOR MY COBRA S031 HELICOPTER
rcforallin - ebay purple series
Posted on Feb 17, 2011
  • 52 Answers
SOURCE: the light on the charger
Mine has also done this. The charger units for these helicopters are mass produced and therefore have a failure rate. I pugged mine in to the mains supply today and it sounded different, as in it 'popped'. The LED failed to light. When I plugged it into my models battery, it went green, even though the battery was low in voltage.
I metered my charger output and it is dead. My S031 is only two weeks old but to get to the shop is a nightmare so I may just open it up and repair it myself (I'm fine with electronics). However, I am not sure if my new battery pack is okay or not, so I run the risk of visually voiding my charger warranty. I have had issues with all of my Syma models and may just get a refund and move on to swashplate 6ch+ machines.
If your charger/S031 is new, I would suggest you return it to the store you purchased it from. Electronics this day and age are a joke and the quality control used is appalling, especially in cheap Japanese models alas.
The charger is sealed and will need to be broken open to access the electronics. Dangerous voltages are inside so I'd suggest you just return it for an exchange.
Posted on Feb 20, 2011
SOURCE: hi i have a S031
i have the same problem and the button is in the off postion
Posted on Apr 02, 2011
josh943
SOURCE: top blades wont rotate and cannot get off the
are you the same guy as over on Amazon? http://www.amazon.com/gp/pdp/profile/A2AB68HFWB22D9/ref=cm_cr_dp_pdp
If you are can you email me? I have tried to email you on Amazon and no luck. my email is memaclover@gmail.com. use a bunch of periods (.............) for the subject line cause that email address gets a lot of spam.
Thanks,
Posted on Nov 26, 2011
My S031 when powered up floats backwards and drifts sideways, just put on new blades did not fix the problem can anyone help
Helicopters are not easy to fly, they are not naturally stable. New blades do not solve the problem, this can only be achieved by training and very delicate movements of the cyclic pitch control. I recommend to use a larger skid (broader) or some light device that enlarges the skid surface (to avoid tilting and damage). But be sure that a coaxial helicopter is easier to fly than any conventional model with just one main rotor and anti-torque tail rotor.
Jan 28, 2015 | Syma S031 Gyro 3 CH RC Helicopter Orange
Syma s031
Make sure the battery is connected and the Helicopter and remote are both turned on on the same channel. Antenna is secure and extended.
May 11, 2014 | Syma S031 Gyro Metal Frame 3.5 CH RC...
Volitation helicopter just spins to the left on ground and will not lift off seems top blades are spinning much faster then bottom
If one blade is spinning faster than another, then the helicopter won't lift off. The first thing to check is the gears driving the blade shafts. It could be that one of the gears is not set properly, or there is something caught near the shaft. Pet hair can often wrap around the shaft and cause drag. If the gears appear to be in the correct positions, and meshing with the pinions (small gears) on the motors, and there is nothing wrapped around the shaft, such as hair, I would slowly increase power and see if both motors start spinning at the same time. If they don't, there could be a problem with the motor, or the controller board. If this is the case, it may be repairable, but might be just as cheap to replace the whole helicopter.
Hope this helps!
Aug 29, 2013 | xheli 9053 Outdoor Volitation Metal...
The light on the charger for my helicopter syma S031 with gyroscope remains green even though it needs charging
Jan 16, 2011 | xheli Syma S031 Outdoor RC Helicopter
I have a brand new Syma model S031G model toy helicopter. I have no instruction manual. It has been charged and the lights work. My remote has new batteries. But it will not make the blades rotate. Can you...
Looks like a board circuit problem. If its new, you have to return it and replace it with another one, try it before going home.
Try this, open the board, there are two trimming resistor adjustment, one for the rear motor and the other one controls the main motor, try to adjust it while your switching the remote controller to lift.
If that does not work. The little servo on the board are busted and you need to return the product!
Thanks for using Fixya!
Dec 15, 2010 | xheli Syma S031 Outdoor RC Helicopter
Hi my helicopter is 9053 , my helicopter working but dont rise , meanwhile it s charging is full , please help me for how to rise many thanks
if the blades are turning and it wont rise check the top blade turn with you hand and hold the lower gear if it spins its loose the clue inside dont hold the turn blades.
solution: get a small drill bit not to big and a drill at the middle of the shaft by the black part make a hole down to the metal shaft and a littel bit into the shaft know get a small screw that woul fir the hold you just made and in to the shaft and it will hold and wala its fixed
Jun 09, 2010 | xheli 9053 Outdoor Volitation Metal...
Helicopter is unbalanced
Hi. This is called "talk" its when the helicopter starts spinning instead of the blades, remote control helicopters and real ones.To stop this from happening you need to make sure the tail Rotor is going correctly OR probely the best thing to do would be take it back to the shop and get a hole new one.
Aug 15, 2009 | Sky I Blade Mini IR Helicopter W/ Remote...
xheli Syma S031 Outdoor RC Helicopter Logo
46 people viewed this question
Top xheli Toys Experts
MeAndMyBrain
Level 1 Expert
Tom Chichester
Rani wadia
Rani wadia
Are you a xheli Toy Expert? Answer questions, earn points and help others
