Question about RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
Replace pto shaft seal on 3610 ford tractor - RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2
2 Suggested Answers
  • 5681 Answers
SOURCE: my to30 P.T.O shaft is
Hello, I have in front of me a catalog for Valu-Bilt.Com, a tractor supply company for all makes. Your Seal can be one of several depending on the Serial number of your tractor. There phone number is 1-888-828-3276.
The Catalog I have shows a Model 35, but I see you have a Model 30. I believe the transmissions were different between the 30 and 35, but see no reason for the rear end to change. The later Model 35 had more gears like a Sherman unit. The Model 35 had a model with 2 extra forward gears and the model used as a Front Loader had 2 extra in both Forward and Reverse.
Now Ferguson and Ford were similar, with the Ferguson having more innovations. Check with a Ford Dealer for PTO seals. The Continental engine was desired as it had Overhead valves and more power over the Ford.
You may also get lucky with Tractor Supply who carry some parts. One additional thing is the number of teeth on the PTO shaft. The book shows a 17 tooth, 25 Spline as 1868528M1 for the Model 30 PTO shaft. The Model 35 has 10 Splines in both a 17 and 19 tooth shaft.
So it is possible you may not even have the original PTO seal if someone put in a part for a Model T35.
I hope this is helpful and would like to know if you found your part. Thanks
Posted on Jul 03, 2011
Change seal for PTO kubota f3680
Remove the PTO shaft extension from the shaft put a drain pan under to catch the oil Tap a chisel or other tapered tool in behind the seal flange and work the seal out install a new seal an re-install oil up to full level
Jun 13, 2015 | Kubota Garden
How to replace pto shaft
how to replace pto shaft on 6640 new holland tractor
Mar 17, 2015 | 2000 Series Fiberglass Canopy Kit for...
Pto wiggles the shaft ii loose
Replace Bearing and seal
Feb 02, 2011 | Ford 8N Tractor
Is there a way to operiate the hydro to raise and lower with out the PTO spinning
If your tractor does not have "live pto", then neither the pto shaft, nor lift arms when the clutch is depressed.
I don't think any 2n's, 9n's, or 8n's came equipped with a live pto.
Hope this helped.
Jan 23, 2011 | Ford 8N Tractor
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
RTO Massey-Ferguson Tractor TE20, TO20, TO30, ITFE2 Logo
56 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
